Home » Eclipse Projects » Remote Application Platform (RAP) » How to specify Composite background image in CSS.
How to specify Composite background image in CSS. [message #1094333] Sun, 25 August 2013 10:22 Go to next message
I am trying to move the definition of a Composite background image from code to CSS. In order to do so I created the CSS definition below...
.backgroundimage{
	background-image: url( images/my-image.jpg );
... and changed the code as follows:
		Composite theImage = null;
		Image bodyImage = null;
		try {
			theImage = new Composite(wrapper, SWT.NONE);
			// TODO: Need to read image from css. This doesn't work (yet)...
			theImage.setData(RWT.CUSTOM_VARIANT, "backgroundimage");
			// bodyImage = new Image(Display.getCurrent(),
			//		getClass().getClassLoader().getResourceAsStream("images/my-image.jpg"));
		} catch (SWTException swte) {
			// for WindowBuilder test.
			bodyImage = new Image(stack.getDisplay(), 709, 475);
When I run the app though I see the following error message appear:
org.w3c.css.sac.CSSException: Failed to read property background-image: Failed to read image: images/my-image.jpg
So there is clearly something wrong with the definition of the image location. I followed the instructions from this site: http://help.eclipse.org/indigo/index.jsp?topic=/org.eclipse.rap.help/help/html/advanced/theming.html
and verified that the image is in the specified location.
This made me think that it is probably the jetty bundle that can't find the image, and that I would need a fragment. But after creating the fragment I get the exact same result.
4	ACTIVE      org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442
	            Fragments=76
stop 4
osgi> start 4
I also tried to register the image as a resource and than use swt-resources/my-image.jpg. Same difference.
So now I am officially lost!
Any suggestions are highly appreciated.
Kind Regards,
Erwin
Re: How to specify Composite background image in CSS. [message #1094342 is a reply to message #1094333] Sun, 25 August 2013 10:41 Go to previous messageGo to next message
Hi Erwin,
first your background-image definition should be applied to Composite
CSS element like:
Composite.backgroundimage{
Second - try to remove the "-" from the image name.
HTH,
Ivan
On 8/25/2013 5:22 PM, Erwin Hogeweg wrote:
> backgroundimage{
> try {
> (yet)...
> Fragments=76
> stop 4
> osgi> start 4
> Kind Regards,
> Erwin
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: How to specify Composite background image in CSS. [message #1094392 is a reply to message #1094342] Sun, 25 August 2013 12:35 Go to previous messageGo to next message
Thanks Ivan,
I tried both suggestions, but with the same result:
org.w3c.css.sac.CSSException: Failed to read property background-image: Failed to read image: images/myimage.jpg
Erwin
Re: How to specify Composite background image in CSS. [message #1094767 is a reply to message #1094392] Mon, 26 August 2013 02:52 Go to previous messageGo to next message
Hi Erwin,
and where the image is located in your bundle ("images" folder in the
root of your bundle)? You could have a look at
"org.eclipse.rap.design.example" bundle for an example of complete
custom theme - fancy/business.
HTH,
Ivan
On 8/25/2013 7:35 PM, Erwin Hogeweg wrote:
> Thanks Ivan,
> Regards,
> Erwin
Ivan Furnadjiev
Re: How to specify Composite background image in CSS. [message #1095247 is a reply to message #1094767] Mon, 26 August 2013 16:46 Go to previous message
Thanks Ivan,
> You could have a look at "org.eclipse.rap.design.example" bundle for an example of complete custom theme - fancy/business.
That helped a lot. Of course it was a user error. It is loading the image now.
Erwin
Previous Topic:[ANN] RAP 2.2M1 published
Next Topic:Configure custom HTTP Header in RWTServlet main response
Current Time: Wed Jul 23 20:22:01 EDT 2025
Powered by FUDForum. Page generated in 0.04284 seconds
