Home » Archived » Visual Editor (VE) » VE - SWT
VE - SWT [message #109335] Tue, 11 October 2005 16:09 Go to next message
Originally posted by: bozgoren.turkcell.com
Unzipped: eclipse, emf, gef, ve. (latest release)
Import swt archive file as an existing project.
Can not see swt under New-Visual class.
Tried -clean option, Reset Perspective, update that i read from newsgroup.
Is there anyone have installed swt and can see swt under visual class?
I remember, i have installed eclipse and swt before, and can see swt for
visual design.
Thanks.
Re: VE - SWT [message #109348 is a reply to message #109335] Tue, 11 October 2005 18:23 Go to previous messageGo to next message
Instead of unzipping, it is better to use the update manager.
Go back to just Eclipse SDK 3.1.1. Use update manager and do Find and
Install new features. Eventually it will show Visual Editor, from there
select the Visual Editor and hit the "Add required" button. Then
install. This will get you VE 1.1.0
Then after install do Find and install updates for installed features.
This will get you VE 1.1.0.1.
After this everything will be installed correctly.
Burak OZGOREN wrote:
> Hello,
> visual design.
> Thanks.
Rich Kulp
Re: VE - SWT [message #109406 is a reply to message #109348] Wed, 12 October 2005 17:07 Go to previous message
Done with the SDK + update.
Thanks.
Re: VE - SWT [message #611169 is a reply to message #109335] Tue, 11 October 2005 18:23 Go to previous message
> Hello,
> visual design.
> Thanks.
Rich Kulp
Re: VE - SWT [message #611179 is a reply to message #109348] Wed, 12 October 2005 17:07 Go to previous message
Thanks.
Previous Topic:VE - SWT
Next Topic:Finish button stays disabled in VE Wizard
Current Time: Sun Nov 09 13:39:53 EST 2025
Powered by FUDForum. Page generated in 0.04478 seconds
