Home » Archived » BIRT » BIRT does not render for large data.
BIRT does not render for large data. [message #1069677] Tue, 16 July 2013 07:22 Go to next message
Hi,I am using BIRT 4.2 and have hosted the BIRT application on tomcat7, for few reports which have a large amount of data to be returned. BIRT does not show(render) anything. But for lesser data, it renders data and report could be downloaded .What could be the problem ? Any suggestions please.
Re: BIRT does not render for large data. [message #1070986 is a reply to message #1069677] Fri, 19 July 2013 00:57 Go to previous messageGo to next message
Have you looked in the log files for any errors?
Re: BIRT does not render for large data. [message #1081841 is a reply to message #1069677] Wed, 07 August 2013 15:15 Go to previous messageGo to next message
Not sure of errors.Im rendering reports via Iframe and I am getting this issue in IE9 .When the data is less(fetched result is less), the report appears with the content(data)in it, but when the data to be rendered is more, the report is empty. Please help.
Re: BIRT does not render for large data. [message #1086306 is a reply to message #1081841] Wed, 14 August 2013 00:18 Go to previous messageGo to next message
Sorry for the delay. How many rows/columns are we talking? Does there seem to be a certain size that it stops working at?
Re: BIRT does not render for large data. [message #1087846 is a reply to message #1086306] Fri, 16 August 2013 03:15 Go to previous messageGo to next message
yes it renders data for 3-4 pages, each page consists of 30 records but when the data exceeds this it does not render any data.the reports is empty.
Re: BIRT does not render for large data. [message #1091862 is a reply to message #1087846] Wed, 21 August 2013 23:50 Go to previous messageGo to next message
That doesn't seem like an amount of data that would crash BIRT. Can you create a report that doesn't render because of the amount of data included using the sample database or another type of data that I can run the report from (scripted, flat file, etc) and pass me the data too? Thanks
Re: BIRT does not render for large data. [message #1092182 is a reply to message #1091862] Thu, 22 August 2013 08:28 Go to previous messageGo to next message
Hi Michael,the issue is resolved now,there was some problem with master page. I deleted and created a new master page and now all my reports are working fine in IE9. Thanks for your support.
Re: BIRT does not render for large data. [message #1093031 is a reply to message #1092182] Fri, 23 August 2013 09:16 Go to previous messageGo to next message
Great! Glad you found what was causing it! Smile
Re: BIRT does not render for large data. [message #1093032 is a reply to message #1092182] Fri, 23 August 2013 09:17 Go to previous messageGo to next message
Re: BIRT does not render for large data. [message #1093033 is a reply to message #1092182] Fri, 23 August 2013 09:19 Go to previous message
Sorry for the duplicate posts, the posts were not showing up. Smile
[Updated on: Fri, 23 August 2013 09:37] by Moderator
Previous Topic:BIRT Report - Run time configuration files
Next Topic:XML import iteration problem
Current Time: Fri Jul 25 05:29:44 EDT 2025
Powered by FUDForum. Page generated in 0.31677 seconds
