Home » Eclipse Projects » Eclipse 4 » Editors not restored on restart, not saved in workbench.xmi (new in 4.3)
Editors not restored on restart, not saved in workbench.xmi (new in 4.3) [message #1092488] Thu, 22 August 2013 17:42 Go to next message
Greetings. I work on an editor plugin, and since the 4.x stream we have run on the compatibility layer. Since I've migrated to the latest Kepler release, I am not seeing open editors restored on a restart of Eclipse. Taking a look in the workbench.xmi file, the editors open are clearly not being saved.
When working in a 4.2.1 build, the editors are saved in workbench.xmi, and thus they are being restored on a restart of Eclipse. Using the same source code for the editor plugin, and launching a debug instance with the same workspace.
Is there anything that could have changed in 4.2->4.3 that may have caused this? It could be something that changed that we were maybe getting away with in 4.2. I have come up empty so far. It doesn't seem to be a general problem with any CompatibilityEditor, because the JDT editor does not have this problem. Any help is appreciated...thanks.
- Ryan
Re: Editors not restored on restart, not saved in workbench.xmi (new in 4.3) [message #1095221 is a reply to message #1092488] Mon, 26 August 2013 15:59 Go to previous message
Are your editors onto 'resources' (i.e. files) ? We haven't heard of this being a general issue so I'm
guessing that all the EPP editors work...Wink.
One possibility is that you're not storing enough information to be able to re-locate the editor's 'input'. Another is that the system somehow thinks your editors are to 'external' resources (these are explicitly removed on close).
Previous Topic:PropertyDialog for e4 app
Next Topic:Dependency Injection problem
Current Time: Sat Jul 26 21:31:17 EDT 2025
Powered by FUDForum. Page generated in 0.50819 seconds
