Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Example download
[Teneo] Example download [message #1090410] Tue, 20 August 2013 01:07 Go to next message
Could someone please help me how to download the teneo/eclipse example ?
The CVS link from below does not seem to work
http://wiki.eclipse.org/Teneo/EclipseLink#Obtaining_the_Example
John D
Re: [Teneo] Example download [message #1091696 is a reply to message #1090410] Wed, 21 August 2013 17:39 Go to previous messageGo to next message
Hi John,
Teneo-Eclipselink integration is not supported. The one to use is this one:
http://wiki.eclipse.org/Teneo/Hibernate
Or if you prefer EclipseLink in combination with EMF you can take a look at the Texo project:
http://wiki.eclipse.org/Texo
gr. Martin
> John D
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Example download [message #1092216 is a reply to message #1091696] Thu, 22 August 2013 09:30 Go to previous messageGo to next message
Thanks a lot Martin for the info.
I did try out Texo before, but I faced a couple of issues with it like below
1. Maintain a separate set of model elements which do not follow the same hierarchy as my original model. eg: If I have a case like
interface C extends A,B {}
in EMF,but Texo generated
class C extends A
but all the properties of B were copied to C. So when I read from the database, I cannot cast C to B.
2. I do not need a JSON serialization of the data as I have a standalone RCP applicaiton.
So far from what I have tried with Teneo(thanks to the pointer to the teneo/hibernate tutorials Smile) it looks pretty good to me. So we are positive about adopting Teneo in our project now. However, we are still trying out more tests to check other characteristics like performance, scalability, searching, complex analysis on DB data etc.
Please suggest if there is any other major points (limitations ?)of Teneo which I should take into account before deciding.
John D
Re: [Teneo] Example download [message #1092387 is a reply to message #1092216] Thu, 22 August 2013 14:27 Go to previous message
Hi John,
Yes your first remark is completely correct, this has been an explicit Texo design choice for now.
I can't think of limitations for Teneo...
gr. Martin
> a case like interface C extends A,B {} in EMF,but Texo generated class C extends A but all the properties of B were
> So far from what I have tried with Teneo(thanks to the pointer to the teneo/hibernate tutorials :)) it looks pretty good
> John D
The Netherlands
Previous Topic:why i am getting this error
Next Topic:[Texo] Autogenerated addTo... fails silently
Current Time: Wed Jul 23 07:45:23 EDT 2025
Powered by FUDForum. Page generated in 0.07234 seconds
