Home » Archived » BIRT » Flat File Source
Flat File Source [message #1091104] Tue, 20 August 2013 23:49 Go to next message
I'm working on a report with a Flat File data source. The flat file can be generated by diferent people with an automatic file name each time. How can i sent the file name and file location as a parameter on the report?
I've tried to create a link between Home Folder and File URI on the Property Binding from de DataSource to a Report Parameters. It works for the file name, but doesn't work for the Home Folder. As soon as i linked File URI to a Report Parameter, Birt uses as default Home Folder the Resource Folder. How can i changes this parametrization?
Thanks.
Re: Flat File Source [message #1091913 is a reply to message #1091104] Thu, 22 August 2013 01:19 Go to previous messageGo to next message
What is your BIRT version?
Re: Flat File Source [message #1092128 is a reply to message #1091913] Thu, 22 August 2013 07:08 Go to previous messageGo to next message
Hello, i'm working on 3.7.2 versión.
Re: Flat File Source [message #1093091 is a reply to message #1091104] Fri, 23 August 2013 10:54 Go to previous message
Take a look at this design. I take two parameters and just set the file URI in the property binding section of the data source using the two parameters.
Previous Topic:BIRT Report - Run time configuration files
Next Topic:How to deploy the BIRT runtime into a Karaf OSGi container
Current Time: Fri Jul 18 19:32:05 EDT 2025
Powered by FUDForum. Page generated in 0.22883 seconds
