JAXB : EclipseLink-3002 while unmarshalling xml even JAXB RI works [message #1092049] |
Thu, 22 August 2013 05:07  |
I have generated Java classes from a xsd file using jaxb-compiler
then while unmarshalling a valid xml file (against same xsd), I have stack trace provided above.
By debugging the code it seems that as xml is "human readable" meaning like this
<tag>
<subtag/>
<tag>
eclipselink wrongly try to bind "/n/t" instead of binding subtag directly
If I unmarshall using same xml and same generated java with JAXB RI, it works as expected,
Do you have an idea on what could be the problem, and how I could solve it ?
Local Exception Stack:
Exception [EclipseLink-3002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [], of class [class java.lang.String], from mapping [org.eclipse.persistence.oxm.mappings.XMLDirectMapping[complexAtomicAttributeTemplate-->complexAtomicAttributeTemplate/text()]] with descriptor [XMLDescriptor(test.gen.moxy.ComplexViewAttributeDefinition --> [])], could not be converted to [class test.gen.moxy.TplComplexAtomicAttr].
at org.eclipse.persistence.exceptions.ConversionException.couldNotBeConverted(ConversionException.java:71)
at org.eclipse.persistence.internal.helper.ConversionManager.convertObject(ConversionManager.java:169)
at org.eclipse.persistence.internal.oxm.XMLConversionManager.convertObject(XMLConversionManager.java:183)
at org.eclipse.persistence.internal.databaseaccess.DatasourcePlatform.convertObject(DatasourcePlatform.java:160)
at org.eclipse.persistence.oxm.mappings.XMLDirectMapping.getAttributeValue(XMLDirectMapping.java:293)
at org.eclipse.persistence.internal.oxm.XMLDirectMappingNodeValue.endElement(XMLDirectMappingNodeValue.java:182)
at org.eclipse.persistence.oxm.record.UnmarshalRecord.startElement(UnmarshalRecord.java:635)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:506)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:376)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2717)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:116)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at org.eclipse.persistence.internal.oxm.record.XMLReader.parse(XMLReader.java:157)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:753)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:333)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:320)
at org.eclipse.persistence.internal.oxm.record.SAXUnmarshaller.unmarshal(SAXUnmarshaller.java:280)
at org.eclipse.persistence.oxm.XMLUnmarshaller.unmarshal(XMLUnmarshaller.java:306)
at org.eclipse.persistence.jaxb.JAXBUnmarshaller.unmarshal(JAXBUnmarshaller.java:115)
[Updated on: Thu, 22 August 2013 05:09] by Moderator
FUDForum. Page generated in 0.08326 seconds
