Home » Newcomers » Newcomers » Exception switching perspectives after upgrade to Juno
Exception switching perspectives after upgrade to Juno [message #1077233] Thu, 01 August 2013 08:08 Go to next message
Dear all,
I upgraded yesterday from Indigo to Juno, and while so far everything seems to be working ok, I'm getting an exception every time I switch perspectives:
An error has occurred. See error log for more details.
org.eclipse.ui.internal.WorkbenchPage.findPerspective(Lorg/eclipse/ui/IPerspectiveDescriptor;)Lorg/eclipse/ui/internal/Perspective;
In the log there's the following:
!ENTRY org.eclipse.ui.workbench 4 2 2013-08-01 13:52:11.378
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.ui.internal.WorkbenchPage.findPerspective(Lorg/eclipse/ui/IPerspectiveDescriptor;)Lorg/eclipse/ui/internal/Perspective;
	at org.eclipse.papyrus.ui.perspectiveconfiguration.PapyrusPerspectiveListener.perspectiveActivated(PapyrusPerspectiveListener.java:117)
	at org.eclipse.ui.internal.PerspectiveListenerList$1.run(PerspectiveListenerList.java:74)
	at org.eclipse.core.runtime.Platform.run(Platform.java:857)
	at org.eclipse.ui.internal.PerspectiveListenerList.fireEvent(PerspectiveListenerList.java:58)
	at org.eclipse.ui.internal.PerspectiveListenerList.firePerspectiveActivated(PerspectiveListenerList.java:72)
	at org.eclipse.ui.internal.WorkbenchWindow.firePerspectiveActivated(WorkbenchWindow.java:1264)
	at org.eclipse.ui.internal.WorkbenchPage$4.handleEvent(WorkbenchPage.java:2805)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4299)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
	at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$13.widgetSelected(PerspectiveSwitcher.java:439)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3562)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3186)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I found the report of a similar problem at StackOverflow, where it is suggested a restart with the -clean option should bring things back to normal. In my case it didn't work out.
Any clues on how to solve this issue are welcome. Thank you.
[Updated on: Thu, 01 August 2013 08:10] by Moderator
Re: Exception switching perspectives after upgrade to Juno [message #1092002 is a reply to message #1077233] Thu, 22 August 2013 03:40 Go to previous messageGo to next message
I'm still struggling with this. Any information is welcome. Thanks.
Re: Exception changing perspectives after upgrading to June [message #1092022 is a reply to message #1077233] Thu, 22 August 2013 04:12 Go to previous messageGo to next message
Luís,
It looks like Papyrus allowed itself to be installed into Juno, but it
uses method methods of an internal class that doesn't exit in Juno.
Best you install an Indigo package and install Papyrus into that. But
it would make more sense to install Kepler versions of everything. it's
better to ask about Papyrus on their specific forum: eclipse.papyrus
On 01/08/2013 2:08 PM, Luís de Sousa wrote:
> Dear all,
> perspectives:
> Quote:
> !STACK 0
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> I found
> http://stackoverflow.com/questions/13570592/changing-perspective-causes-popup-error-debug-perspective-no-longer-functional,
Re: Exception changing perspectives after upgrading to June [message #1092076 is a reply to message #1092022] Thu, 22 August 2013 05:46 Go to previous messageGo to next message
Hi Ed, thank you for the reply.
After looking around I'm getting the idea that Papyrus wasn't updated, it is still marked as version 0.8.1, which is a bit old. This would concur with what you say; I'll try to force an update and veer this discussion to the modelling forum.
Btw, what do you mean by "Kepler versions"? Thanks.
Re: Exception changing perspectives after upgrading to June [message #1092103 is a reply to message #1092076] Thu, 22 August 2013 06:25 Go to previous message
Luís,
The latest release train is Kepler so if you're going to set up new
things, best to get a package from http://www.eclipse.org/downloads/ and
install update into that package from the kepler update site:
http://download.eclipse.org/releases/kepler
Previous Topic:Enabling Java Validator
Next Topic:Eclipse Birt Report 4.3
Current Time: Sat Jul 26 01:58:10 EDT 2025
Powered by FUDForum. Page generated in 0.10550 seconds
