Home » Newcomers » Newcomers » Eclipse Web Service Dyanamic Project not getting synchronized
Eclipse Web Service Dyanamic Project not getting synchronized [message #1091879] Thu, 22 August 2013 00:21 Go to next message
I am new to Eclipse. I am developing some web services.e.g., MyService, using Dynamic Web project. I setup a local tomcat inside Eclipse at port 8081... I created Web Service and it seemed working. In addition to src and build folders, I do see webcontents folder and several folders under it including services/../MyService which are indication that my web service has been deployed under local tomcat.
I made some changes in java code. I do see class file date/time get updated under build/classes, but I do not see updates under webcontents/WEB-INF/services/MyService which has my classes, why? I do have hot update set to true in axis2.xxml file under MyService/.../webcontents/...
When I run my web service in Eclipse it does show the changes I have made in java code, so somehow they seem to be published to local tomcat; but I do not class date/time updated. I also added a new java class MyTest under Src. While it shows under build.. It does not show under contents?
1. How can I set automatic refresh of folders under webcontents ...
2. Why when I run my web services under Eclipse it runs just fine and shows the changes I made.
Thanks a lot.
Re: Eclipse Web Service Dyanamic Project not getting synchronized [message #1092246 is a reply to message #1091879] Thu, 22 August 2013 10:06 Go to previous message
> contents?
> Thanks a lot.
This question should be posted to the Eclipse web tool platform forum.
Previous Topic:Eclipse Birt Report 4.3
Next Topic:Is programmed in Eclipse 3.0 (3.1) program with v4.2 / v4.3 workable?
Current Time: Wed Jul 23 07:47:36 EDT 2025
Powered by FUDForum. Page generated in 0.08835 seconds
