Home » Eclipse Projects » e(fx)clipse » Problem with cssext.cssExtDsl(at.bestsolution.efxclipse.tooling.css.cssext.CssExtDsl)
Problem with cssext.cssExtDsl [message #1091249] |
Wed, 21 August 2013 04:31  |
Hello!
I am working on a project where we are producing an eclipse application (we are using e(fx)clipse as base) which actively uses xtext/xpand code generation and it has it's own code generation capabilities.
I am having problems with following exceptions that are occurring very often when I run our eclipse application, and I can't pinpoint what is the reason for this.
Also, inherited e(fx)clipse css editor is not "working" in our application, crashing with this exception:
org.eclipse.core.runtime.CoreException: Failed to create injector for at.bestsolution.efxclipse.tooling.css.CssDsl ExtensionFactory: at.bestsolution.efxclipse.tooling.css.ui.CssDslExecutableExtensionFactory
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:57)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
Here is the stack trace, maybe someone can help me resolve this issue.
MANAGER: Ext Manager #1
0 [Worker-1] ERROR at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator - Failed to create injector for at.bestsolution.efxclipse.tooling.css.cssext.CssExtDsl
!ENTRY org.apache.log4j 4 0 2013-08-21 09:31:07.157
!MESSAGE at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator - Failed to create injector for at.bestsolution.efxclipse.tooling.css.cssext.CssExtDsl
10 [Worker-1] ERROR at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator - Guice creation errors:
1) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.<init>(Unknown Source)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.class(Unknown Source)
while locating org.eclipse.xtext.common.services.TerminalsGrammarAccess
for parameter 1 at at.bestsolution.efxclipse.tooling.css.cssext.services.CssExtDslGrammarAccess.<init>(Unknown Source)
at at.bestsolution.efxclipse.tooling.css.cssext.services.CssExtDslGrammarAccess.class(Unknown Source)
while locating at.bestsolution.efxclipse.tooling.css.cssext.services.CssExtDslGrammarAccess
while locating org.eclipse.xtext.IGrammarAccess
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.grammarAccess(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
while locating org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar
Caused by: org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:57)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadGrammarFile(BaseEPackageAccess.java:44)
at org.eclipse.xtext.service.GrammarProvider.getGrammar(GrammarProvider.java:66)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.internalFindGrammar(TerminalsGrammarAccess.java:37)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.<init>(TerminalsGrammarAccess.java:33)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:85)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.Scopes$1$1.get(Scopes.java:65)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:84)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:54)
at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:53)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:110)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:94)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:204)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:198)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:198)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:179)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator.createInjector(CssExtDslActivator.java:67)
at at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator.getInjector(CssExtDslActivator.java:55)
at at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.DefaultCssExtProvider.<init>(DefaultCssExtProvider.java:31)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:270)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:331)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:141)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:139)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
at at.bestsolution.efxclipse.tooling.css.extapi.CssExt$OsgiCssExtServiceProvider.get(CssExt.java:48)
at at.bestsolution.efxclipse.tooling.css.extapi.CssExt$OsgiCssExtServiceProvider.get(CssExt.java:1)
at com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:55)
at at.bestsolution.efxclipse.tooling.css.ui.internal.CssDslActivator.createInjector(CssDslActivator.java:67)
at at.bestsolution.efxclipse.tooling.css.ui.internal.CssDslActivator.getInjector(CssDslActivator.java:55)
at at.bestsolution.efxclipse.tooling.css.ui.CssDslExecutableExtensionFactory.getInjector(CssDslExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:39)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:40)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:77)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:93)
at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:28)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl$1.getURI(Storage2UriMapperJavaImpl.java:217)
at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.handle(SourceAttachmentPackageFragmentRootWalker.java:279)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:100)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:88)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:65)
at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.traverse(SourceAttachmentPackageFragmentRootWalker.java:168)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeData(Storage2UriMapperJavaImpl.java:230)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.getCachedData(Storage2UriMapperJavaImpl.java:169)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.updateCache(Storage2UriMapperJavaImpl.java:323)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeCache(Storage2UriMapperJavaImpl.java:357)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.load(AbstractBuilderState.java:61)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.ensureLoaded(AbstractBuilderState.java:68)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.getExportedObjects(AbstractBuilderState.java:177)
at org.eclipse.xtext.builder.impl.DirtyStateAwareResourceDescriptions.getExportedObjects(DirtyStateAwareResourceDescriptions.java:143)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.isDerived(DeltaConverter.java:192)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convertCompilationUnit(DeltaConverter.java:164)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convertCompilationUnits(DeltaConverter.java:254)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convertCompilationUnits(DeltaConverter.java:258)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convert(DeltaConverter.java:124)
at org.eclipse.xtext.builder.impl.javasupport.JavaChangeQueueFiller.elementChanged(JavaChangeQueueFiller.java:37)
at org.eclipse.jdt.internal.core.DeltaProcessor$4.run(DeltaProcessor.java:1682)
at org.eclipse.jdt.internal.core.DeltaProcessor.notifyListeners(DeltaProcessor.java:1672)
at org.eclipse.jdt.internal.core.DeltaProcessor.firePostChangeDelta(DeltaProcessor.java:1506)
at org.eclipse.jdt.internal.core.DeltaProcessor.fire(DeltaProcessor.java:1482)
at org.eclipse.jdt.internal.core.DeltaProcessor.resourceChanged(DeltaProcessor.java:2094)
at org.eclipse.jdt.internal.core.DeltaProcessingState.resourceChanged(DeltaProcessingState.java:470)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:186)
at org.eclipse.core.internal.resources.SavedState.processResourceChangeEvents(SavedState.java:77)
at org.eclipse.jdt.internal.core.JavaModelManager$20.run(JavaModelManager.java:4943)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.jdt.internal.core.JavaModelManager$19.run(JavaModelManager.java:4935)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:182)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:26)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:52)
... 136 more
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2599)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2429)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1306)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1475)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 139 more
2) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
for parameter 0 at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.<init>(Unknown Source)
at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.class(Unknown Source)
while locating org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry
while locating org.eclipse.jface.text.templates.ContextTypeRegistry
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.contextTypeRegistry(Unknown Source)
... 146 more
... 149 more
3) Error injecting method, java.lang.NullPointerException
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(Unknown Source)
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(LanguageRegistrar.java:45)
at com.google.inject.internal.SingleMethodInjector$1.invoke(SingleMethodInjector.java:71)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:90)
3 errors
com.google.inject.CreationException: Guice creation errors:
Re: Problem with cssext.cssExtDsl [message #1091549 is a reply to message #1091249] |
Wed, 21 August 2013 12:44   |
Looks like the root problem you are having is that package Ecore-Package
"www.omg.org/XMI" is not found and because the CSS-Editor itself uses
the CSS-Ext language to define the possible css-properties, ... it will
fail as well.
Maybe someone on the xtext newsgroup can help us further? The
www.omg.org/XMI is the root namespace? Are you using a different version
of xtext? I ask because you mentionned xpand.
Tom
On 21.08.13 17:43, Aaron Schröder wrote:
> Hello!
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> 0 [Worker-1] ERROR
> !MESSAGE
> 10 [Worker-1] ERROR
> 2, 217)
> at
> Source)
> at
> Source)
> for parameter 1 at
> Source)
> at
> Source)
> while locating
> for field at
> Source)
> at
> while locating
> 2, 217)
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> 2, 217)
> at
> at
> at
> at
> at
> ... 136 more
> 2, 217)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> ... 139 more
> 2, 217)
> at
> Source)
> at
> Source)
> for parameter 1 at
> Source)
> at
> Source)
> while locating
> for parameter 0 at
> Source)
> at
> Source)
> while locating
> for field at
> Source)
> at
> while locating
> 2, 217)
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> 2, 217)
> at
> at
> at
> at
> at
> ... 146 more
> 2, 217)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> ... 149 more
> at
> Source)
> at
> while locating
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem with cssext.cssExtDsl [message #1093585 is a reply to message #1093531] |
Sat, 24 August 2013 05:43  |
Sure - if you have problems just come back here.
Tom
On 24.08.13 09:39, Aaron Schröder wrote:
> Yes, migration to Kepler and latest e(fx)clipse is probably going to be
> the "golden" solution, as we are planing to switch our entire project to
> everything "latest" in the next month anyway :). I am glad that our
> problem occurs because we mismatched xtext version and nothing more
> sinister is behind it.
> Thank you for all your help, if you are interested I can post how
> everything feels and works on Kepler and 0.9.0. on Monday?
Re: Problem with cssext.cssExtDsl [message #1742005 is a reply to message #1093228] |
Fri, 23 August 2013 15:52  |
Well 2.4.2 does not work well with 0.8.1 because we are using
experimental API - but IIRC only in fxgraph - anyways why not switching
to our eclipse version which uses Kepler as the base so it runs with the
latest and greatest Xtext/Xtend?
Tom
On 23.08.13 21:46, Aaron Schröder wrote:
> Hello Tom!
> Thank you for your prompt answer. I have took a look at installed
> plugins because you have mentioned the version of xtext. Maybe a reason
> for these exceptions is the version of xtext that we updated... We are
> using e(fx)clipse 0.8.1. and we have upgraded xtext from 2.3.1 -> 2.4.2.
> My next step is going to be a downgrade to 2.3.1 (i don't remember why
> have we done this upgrade of xtext, maybe some other component we are
> using required it), and if this makes a difference I will let you know!
Current Time: Sat Jul 26 11:58:56 EDT 2025
Powered by FUDForum. Page generated in 0.07189 seconds
