Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator
[CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #108933] Tue, 29 January 2008 08:02 Go to next message
Originally posted by: tom.eiswind.de
I just try to play around with CDO a little. forgive me if Im dumb but I
get the above Exception when I try to open the CDO Explorer
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #108945 is a reply to message #108933] Tue, 29 January 2008 08:36 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Thomas,
The mentioned class is not part of the current 0.8 stream of CDO. I
suggest that you check out the sources via All.psf, see
http://wiki.eclipse.org/CDO_Project_Resources#Sources . You can also
download the SDK zip, but one with a 0.8.x version/I-build!
Does that help?
Eike Stepper
http://wiki.eclipse.org/Net4j
> I get the above Exception when I try to open the CDO Explorer
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #108955 is a reply to message #108933] Tue, 29 January 2008 08:40 Go to previous messageGo to next message
Hi Thomas,
I also started playing around with CDO about one week ago.
It is quite tricky to get a working environment, because CDO 0.7.1
(which you get from the update site) is quite outdated and getting the
current integration builds up with the correct dependencies is also
quite hard ;-)
What worked for me was using a clean Eclipse 3.4M4 with the latest EMF
integration build and then importing the team project set all.psf from:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/develop/psf/pserver/All.psf?root=Modeling_P roject&content-type=text%2Fplain&view=co
(see also the description at
http://wiki.eclipse.org/CDO_Project_Resources#Sources).
Using that you can build and export the features yourself and be sure
that they run with your installation.
(BTW: don't try to build the doc and sdk features on windows as they
contain unix shell scripts).
Maybe Eike can comment on this, if there is an easier way to get CDO
running - this was my way which worked after trying and playing alot ;-)
Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #109008 is a reply to message #108955] Tue, 29 January 2008 09:10 Go to previous messageGo to next message
Hi Stefan, Thomas,
Hmm, I was not aware that there are difficulties with dependencies.
Could you please describe in more detail which version of CDO you wanted
to install into which version of Eclipse and which dependencies caused
the trouble?
The 0.7 stream of CDO is not maintained anymore although the respective
build-downloads should work with the dependencies given on the downloads
page.
The current 0.8 stream of CDO has dependencies on Eclipse 3.4, EMF 2.4
and Net4j 0.8. The HEAD of CVS should successfully build/run against
newer I-builds of Eclipse/EMF or at least against the most recent M-build.
Eike Stepper
Stefan Winkler schrieb:
> Hi Thomas,
> quite hard ;-)
> Cheers,
> Stefan
>> but I get the above Exception when I try to open the CDO Explorer
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #109019 is a reply to message #109008] Tue, 29 January 2008 09:15 Go to previous messageGo to next message
Forgot to mention:
If you have checked out all the sources you don't necessarily need to
create deployable plugins/features just to test CDO. There are launch
configs provided for a CDO server (configured via cdo-server.xml) and
two CDO clients.
Eike Stepper
Eike Stepper schrieb:
> Hi Stefan, Thomas,
> wanted to install into which version of Eclipse and which dependencies
> caused the trouble?
> respective build-downloads should work with the dependencies given on
> the downloads page.
> M-build.
> Regards,
> Eike Stepper
>> Hi Thomas,
>> the current integration builds up with the correct dependencies is
>> also quite hard ;-)
>> EMF integration build and then importing the team project set all.psf
>> from:
>> Cheers,
>> Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #109060 is a reply to message #109019] Tue, 29 January 2008 09:24 Go to previous messageGo to next message
Ok thats good to know, as I downloaded for 3.3. so I will take a time
and setup 3.4.M4 to play with it. Thanks !
> Forgot to mention:
> two CDO clients.
> Regards,
> Eike Stepper
>> Hi Stefan, Thomas,
>> caused the trouble?
>> the downloads page.
>> M-build.
>> Regards,
>> Eike Stepper
>>> Hi Thomas,
>>> also quite hard ;-)
>>> from:
>>> Cheers,
>>> Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #109108 is a reply to message #109008] Tue, 29 January 2008 09:42 Go to previous message
Hi Eike,
> caused the trouble?
I think part of the problem was that the source you provided in the
other thread didn't work for me at first.
I got very strange errors e.g. that an indirectly referenced class file
could not be found and at the same time I could not figure out what was
missing, because I had added every single *.cdo.* and *.net4j.* plugin
to the dependencies without any effect. So I tried to do a clean install
with Eclipse 3.3 which also failed for some reason I cannot remember.
Anyway, it did take me several tries to get a working environment ...
Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #614137 is a reply to message #108933] Tue, 29 January 2008 08:36 Go to previous message
Hi Thomas,
Does that help?
Eike Stepper
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #614138 is a reply to message #108933] Tue, 29 January 2008 08:40 Go to previous message
Hi Thomas,
quite hard ;-)
Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #614142 is a reply to message #108955] Tue, 29 January 2008 09:10 Go to previous message
Hi Stefan, Thomas,
the trouble?
page.
Eike Stepper
> Hi Thomas,
> quite hard ;-)
> Cheers,
> Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #614143 is a reply to message #109008] Tue, 29 January 2008 09:15 Go to previous message
Forgot to mention:
two CDO clients.
Eike Stepper
> Hi Stefan, Thomas,
> caused the trouble?
> the downloads page.
> M-build.
> Regards,
> Eike Stepper
>> Hi Thomas,
>> also quite hard ;-)
>> from:
>> Cheers,
>> Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #614146 is a reply to message #109019] Tue, 29 January 2008 09:24 Go to previous message
> Forgot to mention:
> two CDO clients.
> Regards,
> Eike Stepper
>> Hi Stefan, Thomas,
>> caused the trouble?
>> the downloads page.
>> M-build.
>> Regards,
>> Eike Stepper
>>> Hi Thomas,
>>> also quite hard ;-)
>>> from:
>>> Cheers,
>>> Stefan
Re: [CDO] java.lang.NoClassDefFoundError: org/eclipse/emf/cdo/client/internal/ClientActivator [message #614150 is a reply to message #109008] Tue, 29 January 2008 09:42 Go to previous message
Hi Eike,
> caused the trouble?
Stefan
Previous Topic:Re: Modeling tools
Next Topic:[Ecore Tools] Error by EMFT
Current Time: Fri Jul 18 15:53:01 EDT 2025
Powered by FUDForum. Page generated in 0.31912 seconds
