Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Problems with Builder in Kepler
[Acceleo] Problems with Builder in Kepler [message #1090707] Tue, 20 August 2013 10:29 Go to next message
Dear all,
I am migrating our software from Indigo to Kepler and I encountered the
following error when trying to build the Acceleo project:
Errors occurred during the build.
Errors running builder 'Acceleo Builder' on project 'xxx'.
The feature 'et(Parameter)' is not a valid feature
As a result I do not have an output files generated.
I cannot interpret this error message at all. Again, the very same project
worked in Indigo.
Thanks for any help in advance
Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1090768 is a reply to message #1090707] Tue, 20 August 2013 12:06 Go to previous messageGo to next message
This is the missing first letter problem. "Set(Parameter)" would have
been sensible.
Something somewhere has got a byte offset and it causes chaos. The
problem eventually goes away once you rebuild everything enough times.
I've not managed to work out where the inconsistency is.
Try cleaning, restarting, wiping the bin folders with your OS, switch
backwards and forwards between binary/ASCII emtl files, changing JRE to
some other version and back again, make sure your Kepler compiler
preferences are the same as on Indigo ...
Ed Willink
On 20/08/2013 15:29, Marc-Florian Wendland wrote:
> Dear all,
> the following error when trying to build the Acceleo project:
> project worked in Indigo.
> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413035 is a reply to message #1090768] Wed, 27 August 2014 12:01 Go to previous messageGo to next message
Hi all,
I eventually figured out the reason why the first character gets lost. It
has nothing to do whatsoever with Acceleo compiler settings, encoding
scheme, Eclipse or Java version or XMI parsing. The very reason for this is
a technical deficiency of Acceleo to load/work with metamodels that are
located in the workspace and not deployed in the Eclipse instance. After
removing each and every reference to a locally available metamodel (I simply
deployed the metamodels in my development environment) everything is fine
with Acceleo.
I debugged the location were the first character (in my case, instead of
TestPlan Acceleo looked for estPlan) gets lost. It happens in this method:
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eObjectForURIFragmentSegment(String
uriFragmentSegment), lines 507 and 511
In line 551, the first character is actually cut off.
Again, this problem does not occur if one only worked with deployed models
in the Acceleo modules. Any reference to a locally deployed model is
problematic.
Is this a known issue? Shall I add a critical (I really think such
fundamental issue is critical to Acceleo) Bugzilla for this problem.
Marc-Florian
"Ed Willink" wrote in message news:kv0472$u3i$1@xxxxxxxxe.org...
been sensible.
Ed Willink
> Dear all,
> worked in Indigo.
> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413036 is a reply to message #1090768] Wed, 27 August 2014 12:01 Go to previous messageGo to next message
Hi all,
with Acceleo.
problematic.
Marc-Florian
been sensible.
Ed Willink
> Dear all,
> worked in Indigo.
> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413037 is a reply to message #1090768] Wed, 27 August 2014 12:02 Go to previous messageGo to next message
Hi all,
with Acceleo.
problematic.
Marc-Florian
been sensible.
Ed Willink
> Dear all,
> worked in Indigo.
> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413038 is a reply to message #1090768] Wed, 27 August 2014 12:02 Go to previous messageGo to next message
Hi all,
with Acceleo.
problematic.
Marc-Florian
been sensible.
Ed Willink
> Dear all,
> worked in Indigo.
> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413064 is a reply to message #1413038] Wed, 27 August 2014 13:34 Go to previous messageGo to next message
Well-debugged.
A few users have encountered this.
It's certainly really irritating when it happens, but it does seem to go
away after enough rebuild/re-install cycles, so perhaps only major.
Absolutely worth a Bugzilla.
Ed Willink
On 27/08/2014 17:02, Marc-Florian Wendland wrote:
> Hi all,
> simply
> with Acceleo.
> problematic.
> Best regards,
> Marc-Florian
> Hi
> been sensible.
> Regards
> Ed Willink
>> Dear all,
>> project
>> worked in Indigo.
>> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413370 is a reply to message #1090768] Thu, 28 August 2014 07:17 Go to previous messageGo to next message
Hi all,
with Acceleo.
problematic.
Marc-Florian
been sensible.
Ed Willink
> Dear all,
> worked in Indigo.
> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413371 is a reply to message #1413064] Thu, 28 August 2014 07:19 Go to previous messageGo to next message
Hi Ed,
no, it does not got away. It will only go away if the models are not located
in the local workspace. Did you encountered a different behavior?
Maybe someone from the Acceleo team could say a word about this?
Marc-Florian
ps. Sorry for re-sending the mail over and over again. My client told me it
was not sent, so I retried.
"Ed Willink" wrote in message news:ltl4re$5nf$1@xxxxxxxxe.org...
Well-debugged.
Ed Willink
> Hi all,
> is
> simply
> with Acceleo.
> problematic.
> Best regards,
> Marc-Florian
> Hi
> been sensible.
> Regards
> Ed Willink
>> Dear all,
>> project
>> worked in Indigo.
>> Marc-Florian
Re: [Acceleo] Problems with Builder in Kepler [message #1413420 is a reply to message #1413371] Thu, 28 August 2014 09:18 Go to previous message
[You're not the first to be fooled into redundant resends.]
If it doesn't go away then it must be a critical issue. Before I
eliminated Acceleo from my daily tool set, I had a working rule that
org.eclipse.ocl.ecore must not be an open project to avoid Acceleo
getting confused in regard to development and run-time OCL models.
IMHO, and there is Bugzilla response in which Obeo agreed, the URI
resolution in Acceleo is deeply flawed. It uses heuristics to try to
make references created and saved within Eclipse load and resolve
standalone. This is a difficult challenge that needs careful design such
as OCL's ProjectMap class. For simple cases the heuristics make the
inadequate design work, for complex cases they make a bad situation worse.
Ed Willink
On 28/08/2014 12:19, Marc-Florian Wendland wrote:
> Hi Ed,
> located in the local workspace. Did you encountered a different behavior?
> Regards,
> Marc-Florian
> it was not sent, so I retried.
> Hi
> Well-debugged.
> Regards
> Ed Willink
>> Hi all,
>> this is
>> simply
>> with Acceleo.
>> method:
>> models
>> problematic.
>> Best regards,
>> Marc-Florian
>> Hi
>> been sensible.
>> Regards
>> Ed Willink
>>> Dear all,
>>> project
>>> worked in Indigo.
>>> Marc-Florian
Previous Topic:[Acceleo] error in definition of Set
Next Topic:[Acceleo] Open source projects using acceleo?
Current Time: Wed Jul 23 16:59:25 EDT 2025
Powered by FUDForum. Page generated in 0.25880 seconds
