Home » Eclipse Projects » Rich Client Platform (RCP) » Console text is smeared
Console text is smeared [message #1089843] Mon, 19 August 2013 06:18 Go to next message
I'm trying to write to the console by getting a reference to the console's document and using the command:
consoleDoc.set(text)
Later, I add hyperlinks. This is all done in a thread using:
Display.getDefault().asyncExec(new Runnable() {public void run(){
	writeToConsole();
However, the text shows up smeared in the console (see attached screenshot).
Any idea why? Is this an Eclipse bug?
index.php/fa/15938/0/
  • Attachment: console.jpg
    (Size: 34.30KB, Downloaded 464 times)
Re: Console text is smeared [message #1091576 is a reply to message #1089843] Wed, 21 August 2013 13:34 Go to previous messageGo to next message
I am using the org.eclipse.ui.console.MessageConsole as well and write text to
org.eclipse.ui.console.MessageConsoleStream. You get the stream from the MessageConsole by calling
newMessageStream().
Writing to the stream might be better than set text directly to the document.
schrieb Avner H, Am 19.08.2013 16:14:
> writeToConsole();
Re: Console text is smeared [message #1092532 is a reply to message #1091576] Thu, 22 August 2013 19:22 Go to previous message
Thanks for the answer.
I tried that at first, but what I need to do is to write some text into the console and then add hyperlinks to the text. If I use MessageConsole then by the time I'm adding the hyperlinks the text that was written into the MessageConsole still hasn't appeared in the console itself, and I'm getting a bad location exception.
Previous Topic:Custom native launcher
Next Topic:Override or extend delete and save actions
Current Time: Fri Jul 18 15:36:04 EDT 2025
Powered by FUDForum. Page generated in 0.07661 seconds
