Home » Eclipse Projects » Eclipse Platform » Menu only appears in debug perspective
Menu only appears in debug perspective [message #108629] |
Fri, 08 August 2003 04:12  |
Originally posted by: m.bauer.signsoft.com
im trying to integrate a new menu on the menu bar, but it only appears in
the dbug perspectiv. Is there somethin i am missing in my plugin.xml?
Relevant sorce code snippet as following:
extension point="org.eclipse.ui.actionSets">
<actionSet label="Sample Action Set"
id="eclipse.actionSet"
visible="true">
<menu label="My menu"
id="myMenu">
<separator
name="group1">
</separator>
</menu>
<action label="Preferences" icon="icons/sample.gif"
class="foo.bar.JDOAction"
menubarPath="myMenu/group1" toolbarPath="intelliBO"
id="actions.JDOAction"/>
</actionSet>
Thanks for your help.
Michael Bauer
Re: Menu only appears in debug perspective [message #108697 is a reply to message #108671] |
Fri, 08 August 2003 04:40   |
Originally posted by: mh.nixspam.com
Don't know, here is my coding:
package com.xxx.actions;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.IWorkbenchWindowActionDelegate;
* Our sample action implements workbench action delegate.
* The action proxy will be created by the workbench and
* shown in the UI. When the user tries to use the action,
* this delegate will be created and execution will be
* delegated to it.
* @see IWorkbenchWindowActionDelegate
public class CheckBOAction implements IWorkbenchWindowActionDelegate {
private IWorkbenchWindow window;
* The constructor.
public CheckBOAction() {
* The action has been activated. The argument of the
* method represents the 'real' action sitting
* in the workbench UI.
* @see IWorkbenchWindowActionDelegate#run
public void run(IAction action) {
MessageDialog.openInformation(
window.getShell(),
"Whatever Action",
"Checking object...!");
* Selection in the workbench has been changed. We
* can change the state of the 'real' action here
* if we want, but this can only happen after
* the delegate has been created.
* @see IWorkbenchWindowActionDelegate#selectionChanged
public void selectionChanged(IAction action, ISelection selection) {
* We can use this method to dispose of any system
* resources we previously allocated.
* @see IWorkbenchWindowActionDelegate#dispose
public void dispose() {
* We will cache window object in order to
* be able to provide parent shell for the message dialog.
* @see IWorkbenchWindowActionDelegate#init
public void init(IWorkbenchWindow window) {
this.window = window;
"Michael Bauer" <m.bauer@signsoft.com> wrote in message
news:bgvn8i$umb$1@eclipse.org...
> Hi, seems to be similar. But what is the problem then? Do I have to
subclass
> i different class? I used IWorkbenchWindowActionDelegate. Code of the
class
> looks like this:
> public class MyAction implements IWorkbenchWindowActionDelegate {
> * The constructor.
> public MyAction() {
> MessageDialog.openInformation(null,null,"It works");
> But I dont think that this problem is correlated to the class due of that
> the menu entry is only defined in the plugin.xml.
> Michael
> "Mario Herger" <mh@nixspam.com> schrieb im Newsbeitrag
> news:bgvmja$tvt$1@eclipse.org...
> > Looks good for me at the first glance, my code looks similar and works;
> here
> > it is, compare it:
> > <extension
> > <actionSet
> > label="Business Objects"
> > visible="true"
> > id="com.xxx.actionSet">
> > <menu
> > label="&Check Consistency"
> > id="checkBOMenu">
> > <separator
> > name="checkBOGroup">
> > </separator>
> > </menu>
> > <action
> > icon="icons/ok.gif"
> > tooltip="Check Consistency"
> > class="com.xxx.actions.CheckBOAction"
> > menubarPath="checkBOMenu/checkBOGroup"
> > toolbarPath="checkBOGroup"
> > id="com.xxx.actions.CheckBOAction">
> > </action>
> > </actionSet>
> > </extension>
> > Mario
> > news:bgvldb$s5n$1@eclipse.org...
> > > Hi,
> in
> > > visible="true">
> > > id="myMenu">
> > > <separator
> > > name="group1">
> > > </separator>
> > > </menu>
> > > </actionSet>
> > > Michael Bauer
Re: Menu only appears in debug perspective [message #108840 is a reply to message #108697] |
Fri, 08 August 2003 09:11   |
Originally posted by: s-correia.chronopost.fr
Maybe you should use a perspective extension to tell in which perspective
your action set should appear:
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="org.eclipse.ui.resourcePerspective">
<actionSet
id="your.actionSet.id">
</actionSet>
</perspectiveExtension>
</extension>
Seb.
> * delegated to it.
> * The constructor.
> window.getShell(),
> "Whatever Action",
> subclass
> class
> > looks like this:
> > * The constructor.
> > public MyAction() {
> > Michael
> > here
> > > it is, compare it:
> > > <extension
> > > <actionSet
> > > visible="true"
> > > <menu
> > > id="checkBOMenu">
> > > <separator
> > > </separator>
> > > </menu>
> > > <action
> > > icon="icons/ok.gif"
> > > </action>
> > > </actionSet>
> > > </extension>
> > > Mario
> > > > Hi,
> > in
> > > > visible="true">
> > > > id="myMenu">
> > > > <separator
> > > > name="group1">
> > > > </separator>
> > > > </menu>
> > > > </actionSet>
> > > > Michael Bauer
Re: Menu only appears in debug perspective [message #108880 is a reply to message #108840] |
Fri, 08 August 2003 09:42   |
thanks fore your reply. It is real strange. I added the extension, but
nothing happened. The only thing is, that my action set now isn't displayed
in any perspective.
If anyone got another hitn i would be thankful.
Michael Bauer
"Sebastiao" <s-correia@chronopost.fr> schrieb im Newsbeitrag
news:bh07hr$g2d$1@eclipse.org...
> <extension
> <actionSet
> </actionSet>
> </extension>
> Seb.
> > * delegated to it.
> > * The constructor.
> > window.getShell(),
> > "Whatever Action",
> > subclass
> > class
> > > looks like this:
> > > * The constructor.
> > > public MyAction() {
that
> > > Michael
works;
> > > here
> > > > it is, compare it:
> > > > <extension
> > > > <actionSet
> > > > visible="true"
> > > > <menu
> > > > id="checkBOMenu">
> > > > <separator
> > > > </separator>
> > > > </menu>
> > > > <action
> > > > icon="icons/ok.gif"
> > > > </action>
> > > > </actionSet>
> > > > </extension>
> > > > Mario
> > > > > Hi,
appears
> > > in
plugin.xml?
> > > > > visible="true">
> > > > > id="myMenu">
> > > > > <separator
> > > > > name="group1">
> > > > > </separator>
> > > > > </menu>
> > > > > </actionSet>
> > > > > Michael Bauer
Re: Menu only appears in debug perspective [message #108906 is a reply to message #108893] |
Fri, 08 August 2003 09:45  |
well. Thanks. This was the solution. I didnt even expect, that eclipse also
hides the information about new items over sessions.
Thanks very much.
Michael Bauer
"Dave Wegener" <wegener@cboenospam.com> schrieb im Newsbeitrag
news:bh09d5$i2r$1@eclipse.org...
> Michael Bauer wrote:
> > Hi,
in
> > visible="true">
> > id="myMenu">
> > <separator
> > name="group1">
> > </separator>
> > </menu>
> > </actionSet>
> > Michael Bauer
> Have you tried closing and opening your view? Eclipse doesn't
> automatically add new items to views once they have been customized.
> Dave
Current Time: Tue Jun 24 02:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.26742 seconds
