Home » Eclipse Projects » Eclipse Platform » customizing conext menu
Re: customizing conext menu [message #1100850 is a reply to message #1100720] |
Tue, 03 September 2013 13:43   |
Phil,
Are you still trying to remove things or to add things? Maybe someone
else can explain how to remove things; I've not tried to do that... If
you look in the plugin.xml for org.eclipse.emf.ecore.editor, you'll see
how it contributes actions that appear in every contact menu, e.g., this
contribution for creating a dynamic instance form an EClass.
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
id="org.eclipse.emf.ecore.editor.CreateDynamicInstance"
objectClass="org.eclipse.emf.ecore.EClass">
<action
id="org.eclipse.emf.ecore.editor.CreateDynamicInstanceAction"
label="%_UI_CreateDynamicInstance_menu_item"
menubarPath="additions"
class="org.eclipse.emf.ecore.action.CreateDynamicInstanceAction"
enablesFor="1"/>
</objectContribution>
</extension>
On 03/09/2013 3:51 PM, Phil H wrote:
> What kind of examples do you mean? I was able to figure out how to remove some entries, but there are still entries like "run as", "debug as", "Team" and so on (see attached image).
> I thought maybe commeting out "getSite().registerContextMenu(contextMenu, new UnwrappingSelectionProvider(viewer));" in createContextMenuFor(StructuredViewer viewer) would do the trick, but it hasn't changed anything.
> I also checked my plugin dependencies, but couldn't find anything which could contribute this menu entries.
> I don't really understand how your Jface approach should work. How can object contribution remove menu entries from ymmeditor?
Re: customizing conext menu [message #1102307 is a reply to message #1102293] |
Thu, 05 September 2013 12:11   |
Phi,
Comments below.
On 05/09/2013 5:57 PM, Phil H wrote:
> Hmm, that is really odd..So you don't have any menu entries like
> Wizards, Run As, Debus As, Team and son anymore?
No, those are contributed by other things in the platform and that call
registers the context menu to receive those contributions...
> I can't remember that I've added additional plugins..At all I give up
> with this..
When you launch, any plugin included in the launch configuration can
register extension in their plugin.xmls that contribute to these menu
items; by default that's all your bundles in the workspace and all the
bundles in your target platform, i.e., the debugger framework, the team
framework, and so on.
Re: customizing conext menu [message #1103034 is a reply to message #1102307] |
Fri, 06 September 2013 06:08   |
Hi Ed,
you're right, I just found out that there is another class which calling this method. Commeting out this removed all the contributed stuff like "Wizards" etc., but unfortunately also the menuitem which I contributed in the plugin.xml isn't shown anymore.
Just calling getSite().registerContextMenu("myCommandId", contextMenu, new UnwrappingSelectionProvider(viewer)); hasn't worked.
So I thought about filtering out the unwanted contributions with this code:
protected void createContextMenuFor(StructuredViewer viewer) {
MenuManager contextMenu = new MenuManager("#PopUp") {
public IContributionItem[] getItems() {
IContributionItem[] items = super.getItems();
List<IContributionItem> filteredItems = new ArrayList<IContributionItem>();
for (IContributionItem item : items) {
if (item != null && item.getId() != null && ((item.getId().startsWith("org.itea2"))))
filteredItems.add(item);
items = new IContributionItem[filteredItems.size()];
return filteredItems.toArray(items);
contextMenu.add(new Separator("additions"));
contextMenu.setRemoveAllWhenShown(true);
contextMenu.addMenuListener(this);
Menu menu = contextMenu.createContextMenu(viewer.getControl());
viewer.getControl().setMenu(menu);
int dndOperations = DND.DROP_COPY | DND.DROP_MOVE | DND.DROP_LINK;
Transfer[] transfers = new Transfer[] { LocalTransfer.getInstance() };
viewer.addDragSupport(dndOperations, transfers, new ViewerDragAdapter(viewer));
viewer.addDropSupport(dndOperations, transfers, new EditingDomainViewerDropAdapter(getEditingDomain(), viewer));
This works fine for my menuitem, but it turned out that using this filter (it doesn't matter which string is used in item.getId().startsWith("org.itea2")) results in a context menu without the EMF menu items like "New Child", "undo" etc.
Is there any workaround for this?
[Updated on: Fri, 06 September 2013 06:14] by Moderator
Re: customizing conext menu [message #1103691 is a reply to message #1103034] |
Sat, 07 September 2013 01:40   |
Phil,
Comment below.
On 06/09/2013 12:08 PM, Phil H wrote:
> Hi Ed,
Yes, that's to ge expected.
No, the ID you use is important.
> code:
> @Override
> filter (it doesn't matter which sring is used in
It looks like your filter filters out pretty much everything. Are you
actually using a debugger to observe what your filter is doing?
Re: customizing conext menu [message #1104080 is a reply to message #1103691] |
Sat, 07 September 2013 16:57  |
It seems that the EMF menu items have no ID, so the following has done the trick:
if ((item != null) && ((item.getId() == null) || (item.getId().startsWith("org.itea2")))) {
Current Time: Thu Jul 24 17:58:55 EDT 2025
Powered by FUDForum. Page generated in 0.14287 seconds
