Home » Eclipse Projects » JFace » Metadata in TreeViewer(Retrieve data from node in TreeViewer (in e4) on RMB click)
Metadata in TreeViewer [message #1087593] Thu, 15 August 2013 18:05 Go to next message
I have been trying to figure this out for a couple of days:
I have a TreeViewer with nodes that extend:
public abstract class TreeNode implements ITreeNode, IAdaptable
public ITreeNode getParent() {
return fParent;
I would like to store a unique database table key for each item in the tree (as well as the item name) and retrieve the key on RMB selection of the item so that I can show a popup with details of the selected item. The names could be duplicates so a unique key is required.
As I want to get the key on RMB click (not doubleclick where I could use IStructuredSelection) I can't access the selected node to check against node model objects, RMB is SWT world.
Also as TreeLabelProvider does not have a getData() method there is no way to retrieve data as per SWT treeItem.
As far as I can tell my options are:
1) Use SWT Tree and TreeItem instead of TreeViewer and build the tree manually and use .setData(uniqueKey) of the TreeItems.
2) Use IPropertySource from eclipse 3.x but I need to research more to see If I would be able to link up a RMB click to SelectionService. Also I would prefer to keep the application pure e4.
3) Extend jface.viewers.StructureViewer? to implement a right mouse button listener - which might be fun but seems a bit more than I can chew at the moment.
Has anyone else come accross this issue and found a solution using TreeViewer?
Re: Metadata in TreeViewer [message #1087606 is a reply to message #1087593] Thu, 15 August 2013 18:23 Go to previous messageGo to next message
I worked this out 5 min after posting Smile - use MenuManager then you can access the node model.
MenuManager menuMgr = new MenuManager();
Menu menu = menuMgr.createContextMenu(viewer.getControl());
menuMgr.addMenuListener(new IMenuListener() {
public void menuAboutToShow(IMenuManager manager) {
if(viewer.getSelection().isEmpty()) {
return;
if(viewer.getSelection() instanceof IStructuredSelection) {
IStructuredSelection selection = (IStructuredSelection)viewer.getSelection();
Object selectedNode = selection.getFirstElement();
if(selectedNode instanceof TestObject){
TestObject testObject = (TestObject)selectedNode;
logger.debug("--menuAboutToShow() testObject "+testObject.getName());
Re: Metadata in TreeViewer [message #1089268 is a reply to message #1087606] Sun, 18 August 2013 08:39 Go to previous message
PS,
I then changed to use pure e4 - as per my post on ContextMenu in the e4 forum.
Previous Topic:React on value change along with databinding
Next Topic:TableViewer not preserved sorting
Current Time: Sat Jul 26 02:39:17 EDT 2025
Powered by FUDForum. Page generated in 0.25012 seconds
