Home » Eclipse Projects » EGit / JGit » Clone a Git repository is slow
Clone a Git repository is slow [message #1085905] Tue, 13 August 2013 10:21 Go to next message
I wonder if I'm alone with this problem, but cloning a Git repository is very slow (I have tested EGit 2.2 as well as EGit 3.0.1, the version of Eclipse is 4.2).
The clone operation first runs quite fast to 99%, but then seems to be stuck at 100% for a long time without any visible reason. Eventually the cloning does finish though.
The same clone operation run on Unix level takes about 1 minute.
Any ideas on how to debug further?
Antti
Re: Clone a Git repository is slow [message #1086766 is a reply to message #1085905] Wed, 14 August 2013 13:33 Go to previous messageGo to next message
It's most likely this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=394078
CU
Andrey
Re: Clone a Git repository is slow [message #1087063 is a reply to message #1085905] Thu, 15 August 2013 00:49 Go to previous message
Hi Andrey,
It definitely sounds like the same issue!
I didn't actually realize that I should also browse through the JGit Bug list (on top of EGit and Eclipse) so thanks for pointing me to the right direction.
/// Antti
Previous Topic:Cannot retrieve file from SHA-1 string
Next Topic:Request: make available relevant Team features in Maven module projects
Current Time: Sun Jul 27 11:53:55 EDT 2025
Powered by FUDForum. Page generated in 0.04184 seconds
