Home » Newcomers » Newcomers » Stepping into java runtime classes
Stepping into java runtime classes [message #106309] Fri, 30 September 2005 06:04 Go to next message
Originally posted by: MichaelJMueller.gmail.com
Hello
I think that I understand the concept of step filters quite well. But it
does not seem to work the way documented. Even though I have step
filtering disabled I cannot step into any of the classes of the java
runtime system. Does anybody know how to do this.
Thanks. Mike
Re: Stepping into java runtime classes [message #106834 is a reply to message #106309] Mon, 03 October 2005 11:54 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
Michael J. Mueller wrote:
> Hello
I think we need some more details about it, because stepping into
library code is definitely something a lot of users do every day.
Help us narrow down what is different about your case...
HTH,
Eric
Re: Stepping into java runtime classes [message #108028 is a reply to message #106834] Fri, 07 October 2005 14:52 Go to previous messageGo to next message
> HTH,
> Eric
Thank you for answering. I want to stepping into library functions such as
java.util.ArrayList.add . I got the idea that step filter simply exist to
prevent someone from stepping into a function like this, because this code
is usually not what one is interested in. But even though I played around
with the step filter settings a lot, the debugger simply executed this
code as one step. It seems to me that the step filter setting are a
placebo.
Mike
Re: Stepping into java runtime classes [message #108700 is a reply to message #108028] Mon, 10 October 2005 14:39 Go to previous messageGo to next message
> as java.util.ArrayList.add . I got the idea that step filter simply
> exist to prevent someone from stepping into a function like this,
> because this code is usually not what one is interested in. But even
> though I played around with the step filter settings a lot, the debugger
> simply executed this code as one step. It seems to me that the step
> filter setting are a placebo.
It sounds as if you understand what step-filtering is for - to make
debugging easier by not stepping into certain packages/classes that are
uninteresting.
However, stepping into core Java code is something that many people do
every day, so it's not clear to me why you're having trouble.
Here is a screencast showing stepping into ArrayList:
http://www.rizzoweb.com/Eclipse/DebuggerStepping.html
Does that help you determine what you're doing differently?
One more question, are you using a JDK with source to run Eclipse and
your application within Eclipse? IF you're using a JRE and not a JDK,
perhaps Eclipse is skipping the core Java classes that it knows there is
no source for...<shrug>
HTH,
Eric
Re: Stepping into java runtime classes [message #109736 is a reply to message #108700] Sun, 16 October 2005 12:10 Go to previous message
> uninteresting.
This was the problem. By default eclipse use the following JRE
C:\Programme\Java\jre1.5.0_04 I changed this to the JRE
C:\Programme\Java\jdk1.5.0_04\jre and everything works out fine.
Thanks. Mike
Previous Topic:Eclipse -clean On OS X
Next Topic:Compare files: whitespace not ignored?
Current Time: Mon Nov 03 08:54:38 EST 2025
Powered by FUDForum. Page generated in 0.34752 seconds
