Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Setup Webserver and EMF Client with JSONTexoResource
[Texo] Setup Webserver and EMF Client with JSONTexoResource [message #1086480] Wed, 14 August 2013 04:58 Go to next message
Hello everybody,
a few days ago I came across Texo (@Martin: thanks for your great work). As explained on the wiki site, I tried to set up a 3 Tier architecture with a MySQL Database, a Tomcat Webserver and an EMF generated client. So far the webserver and its database connection are working without problems. The part I'm struggling with is the EMF generated client.
The steps I've taken until now:
1)Downloaded sample project org.eclipse.emf.texo.web.example from https : //github.com/mtaal/texo and deleted the folder WebContent/mobile (Do i need this one?)
2)Set up webserver, database and generated test data according to this site: http : //wiki.eclipse.org/Texo/JSON_REST_Web_Services (everything works fine)
3)Generated an EMF Client via creating a genmodel from the files identifiable.ecore and library.ecore (The same i use to generate the JPA annotated model code)
4)Created a JSONTexoFactoryImpl
public class JSONTexoResourceFactoryImpl implements Factory {
	public Resource createResource(URI uri) {
		JSONTexoResource res = new JSONTexoResource();
		res.setURI(uri);
		return res;
5) Registered this Factory via
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap().put("http", new JSONTexoResourceFactoryImpl());
6) Tried to open the generated editor with an URIEditorInput
URIEditorInput input = new URIEditorInput(URI.createURI("http : //localhost:8080/org.eclipse.emf.texo.web.example/jsonws"));
try {
page.openEditor(input, "library.presentation.LibraryEditorID");
} catch (PartInitException e) {
	e.printStackTrace();
The editor came up but had no content, so I changed the input into
URIEditorInput input = new URIEditorInput(URI.createURI("http : //localhost:8080/org.eclipse.emf.texo.web.example/jsonws?type=library_Library"));
Now the editor showed up with the libraries I had in my database, but i couldn't expand those elements to show their children (books / writer). I also tried this setup with Book or Writer as root elements, but this didn't work either.
The expected behaviour, in my opinion, would be, that the editor would work as if I invoked it with a local resource. Libraries would be the root elements and with a click on them I can expand them to show their child elements.
Did I miss some steps until now? Did I do something wrong? Is the described behaviour expected? Is there an example project that shows the proper use of the JSONTexoResource?
I hope you can give me a hint in the right direction.
Any help is appreciated and thanks a lot in advance for your effort.
Thomas Driessen
Re: [Texo] Setup Webserver and EMF Client with JSONTexoResource [message #1086891 is a reply to message #1086480] Wed, 14 August 2013 18:09 Go to previous messageGo to next message
Hi Thomas,
It should work as you expect, I can't really see why it does not happen, the books/writers containment elist should be
resolved. So not sure why it does not happen. Can you debug into to the code to see if indeed resolving takes place and
that the library indeed has book/writer proxies in the lists?
You can put breakpoints in the getEObject methods in the TexoResource.
gr. Martin
On 08/14/2013 05:34 PM, Thomas Driessen wrote:
> Hello everybody,
> @Override
> res.setURI(uri);
> return res;
> try {
> Best regards, Thomas Driessen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Setup Webserver and EMF Client with JSONTexoResource [message #1086900 is a reply to message #1086891] Wed, 14 August 2013 18:27 Go to previous messageGo to next message
Hey Martin,
thanks for your quick response. I'm on vacation until sunday, but on monday I'll give your advice a try Smile
I'll write back if i got some news on this topic.
Thomas
Re: [Texo] Setup Webserver and EMF Client with JSONTexoResource [message #1089991 is a reply to message #1086900] Mon, 19 August 2013 10:58 Go to previous messageGo to next message
Hi Martin,
after some debugging I found out, that the method getEClassFromQualifiedName in the class ModelUtils returns the wrong Library EClass (org.eclipse.m2m.internal.qvt.oml.expressions.Library). The Javadoc of this method already points out that this can happen, if the given name is not qualified via its epackage ns prefix.
As I'm using qualified names (in my case library|Library), might it be, that the second for-loop of the method getEClassFromQualifiedName is missing a check for equality of namespaces?
    for (Object key : new HashSet<Object>(ModelResolver.getInstance().getEPackageRegistry().keySet())) {
      final EPackage ePackage = ModelResolver.getInstance().getEPackageRegistry().getEPackage((String) key);
      //Here i would expect something like the following
      //if (nameSpacePrefix != null && !ePackage.getNsPrefix().equals(nameSpacePrefix)) {
      //  continue;
      for (EClassifier eClassifier : ePackage.getEClassifiers()) {
        if (eClassifier.getName().equals(eClassName)) {
          return (EClass) eClassifier;
Thomas
Re: [Texo] Setup Webserver and EMF Client with JSONTexoResource [message #1090248 is a reply to message #1089991] Mon, 19 August 2013 18:54 Go to previous messageGo to next message
Hi Thomas,
I published a new build which should solve (I made the change you proposed), can you try again?
gr. Martin
On 08/19/2013 04:58 PM, Thomas Driessen wrote:
> Hi Martin,
> // continue;
> Best regards,
> Thomas
The Netherlands
Re: [Texo] Setup Webserver and EMF Client with JSONTexoResource [message #1090497 is a reply to message #1090248] Tue, 20 August 2013 04:10 Go to previous message
Hi Martin,
thanks a lot for this quick Fix. Now everything works as expected.
Thanks for this great Framework Smile
Thomas
Previous Topic:[Texo] How to reference another object when inserting with post
Next Topic:why i am getting this error
Current Time: Sat Jul 26 21:27:43 EDT 2025
Powered by FUDForum. Page generated in 0.31203 seconds
