Home » Eclipse Projects » JFace » React on value change along with databinding
React on value change along with databinding [message #1086694] Wed, 14 August 2013 11:24 Go to next message
I have a databinding that's working perfectly. But now I want to react additional on my own if some values of several GUI elements change. Is it possible to act as some kind of subscriber to the databinding instead of using the eventlisteners of each SWT component?
Greetings
Johannes
Re: React on value change along with databinding [message #1097812 is a reply to message #1086694] Fri, 30 August 2013 03:27 Go to previous message
Hello Johannes,
for sure you can.
Each org.eclipse.core.databinding.observable.value.IObservableValue has an addValueChangeListener method, where you can attach your own custom org.eclipse.core.databinding.observable.value.IValueChangeListener.
For instance:
IObservableValue target = WidgetProperties.text(SWT.Modify).
  observe(textInstance);
target.addValueChangeListener(new IValueChangeListener(){
   public void handleValueChange(ValueChangeEvent valuechangeevent){
         Object newValue = valuechangeevent.diff.getNewValue();
If you have further questions, do not hesitate to ask them Wink
Simon
Previous Topic:Quick find (Ctrl + F) does not work for virtual Table Viewer
Next Topic:Metadata in TreeViewer
Current Time: Tue Jul 22 23:07:31 EDT 2025
Powered by FUDForum. Page generated in 2.17064 seconds
