Home » Modeling » OCL » Checking OCL programmatically(Problem setting correct context)
Checking OCL programmatically [message #1086603] |
Wed, 14 August 2013 08:14  |
I am trying to perform an OCL check on a UML model programmatically. For this I am using the OCL class from the Pivot package (org.eclipse.ocl.examples.pivot.OCL). The model and profile were created using Papyrus. The model and profile I've created are attached to this message. The validation works as it should using the Papyrus GUI and the default UML2 Editor GUI. However, when trying to simulate the GUI the code fails.
It seems however that I am setting the context in the OCLHelper incorrect, which results in a ParserException when the query is created from the OCLHelper. At the moment my context gets set to Stereotype, but I would expect it to be Stereotype1 from my attached profile. The error message I get from the diagnostic is:
Errors in 'self.number < 10'
1: Unresolved Property 'uml::Stereotype::number'
My conclusion is that I am probably missing some essential steps to make this work, but so far I haven't found any solution to this anywhere. Actually it is quite hard to find a clear enough example of the call order to make this work.
Below is the code I use for the OCL check:
import org.eclipse.emf.common.util.Diagnostic;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.TreeIterator;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.ocl.examples.pivot.ExpressionInOCL;
import org.eclipse.ocl.examples.pivot.OCL;
import org.eclipse.ocl.examples.pivot.ParserException;
import org.eclipse.ocl.examples.pivot.helper.OCLHelper;
import org.eclipse.ocl.examples.pivot.manager.MetaModelManager;
import org.eclipse.ocl.examples.pivot.utilities.PivotEnvironment;
import org.eclipse.ocl.examples.pivot.utilities.PivotEnvironmentFactory;
import org.eclipse.ocl.examples.pivot.utilities.PivotUtil;
import org.eclipse.uml2.uml.Constraint;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.NamedElement;
import org.eclipse.uml2.uml.Namespace;
import org.eclipse.uml2.uml.OpaqueExpression;
import org.eclipse.uml2.uml.Profile;
public void validate(Model model) {
final Model myModel = model;
EList<Constraint> constraints = new BasicEList<Constraint>(myModel.getOwnedRules());
// Get all OCL rules from the model
final TreeIterator<EObject> iterator = myModel.eAllContents();
while(iterator.hasNext()){
EObject tempObject = iterator.next();
if (tempObject instanceof NamedElement) {
NamedElement ne = (NamedElement) tempObject;
if(ne.getNamespace() != null) {
final EList<Constraint> temp = ne.getNamespace().getOwnedRules();
if(!constraints.containsAll(temp)){
constraints.addAll(temp);
// Get all OCL rules from the profiles applied to the model
for(Profile profile : myModel.getAllAppliedProfiles()){
final TreeIterator<EObject> profileIterator = profile.eAllContents();
while(profileIterator.hasNext()){
EObject tempObject = profileIterator.next();
// Check if any OCL constraint is violated
for (Constraint constraint : constraints) {
String constraintName = constraint.getName();
if (constraint.getSpecification() instanceof OpaqueExpression) {
OpaqueExpression opaqueExpression = ((OpaqueExpression) constraint.getSpecification());
// Find the body named OCL
int indexOfOCLBody = -1;
for (int i = 0; i < opaqueExpression.getLanguages().size() && indexOfOCLBody == -1; i++) {
if (opaqueExpression.getLanguages().get(i).equals("OCL")) {
indexOfOCLBody = i;
// If the body was found, continue the check
if (indexOfOCLBody != -1) {
final String expression = opaqueExpression.getBodies().get(indexOfOCLBody);
final Namespace contextObject = constraint.getContext();
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.getResource(myModel.eResource().getURI(), true);
MetaModelManager metaModelManager = PivotUtil.getMetaModelManager(resource);
PivotEnvironmentFactory envFactory = new PivotEnvironmentFactory(null, metaModelManager);
PivotEnvironment environment = envFactory.createEnvironment();
OCL.initialize(null);
OCL ocl = OCL.newInstance(environment);
OCLHelper oclHelper = ocl.createOCLHelper(contextObject);
oclHelper.setContext(contextObject.eClass());
try {
// Turn the expression into a query and evaluate it
ExpressionInOCL createQuery = oclHelper.createQuery(expression);
Object result = ocl.evaluate(contextObject, createQuery);
} catch (ParserException e) {
Diagnostic diagnostic = e.getDiagnostic();
System.out.println(diagnostic.getMessage());
Does anyone know why this isn't working? Thanks in advance!
Boel
Re: Checking OCL programmatically [message #1086612 is a reply to message #1086603] |
Wed, 14 August 2013 08:30   |
HI
Please attach a zipped project rather than files from which I have to
construct the project.
Ed Willink
On 14/08/2013 13:14, Boel N wrote:
> indexOfOCLBody = i;
> try {
> Regards,
> Boel
Re: Checking OCL programmatically [message #1097763 is a reply to message #1097283] |
Fri, 30 August 2013 02:11   |
Yes. I got distracted by the bug that crept in that prevented me
verifying my suspicion that 'self.number < 10' was at fault. That bug is
fixed in M1.
As often happens the error message very accurate. There is no 'number'
property in a 'uml::Stereotype', the property is in the application
of/instance of a particular Stereotype.
The code iterates over all the Constraints and validates the declared
constraint context. Having found a constraint, it should search for all
instances of the declared constraint context and validate them. Model
searches are not very clever, so it is better to iterate over the model
and nest over the constraints since the constraints are more cacheable.
Overall the code has severe performance issues that will become a
concern once you use it for your intended purpose.
A MetaModelManager is a heavyweight object that provides efficient
uniform access to your metamodels. Never create more than one if you can
possibly avoid it, so hoist it outside your loops.
Similarly the OCL facade object should be reused.
Similarly other initialization code.
Ed Willink
On 29/08/2013 14:38, Ronan B wrote:
> I'm following this up on Boel's behalf. After updating to
> http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/4.2.0/S201308191305/mdt-ocl-Update-4.2.0M1.zip
> I see no change in behaviour. I get the exact same issue
> To be honest I don't think the issue required an MDT OCL update as the
> validation works in Papyrus and the standard UML2 tree editor, when
> using their validate menus. However, when running the code that Boel
> wrote (attached in the plugin provided) validation does not work.
> Any ideas?
> Regards,
> Ronan
Re: Checking OCL programmatically [message #1100745 is a reply to message #1100631] |
Tue, 03 September 2013 10:36   |
At last I have something working. Some quick questions before I show what I did.
1) You said I should just call Resource asResource = ocl.parse(uri); You're assuming I have the possibility to have all my OCL in a seperate document I guess? This is not the case. I'm clearly doing this work as I have UML models with OCL embedded in them. This is why you guys put all the effort into the Pivot isn't it?
2) As you will see in the code I use UML2Pivot.importFromUML(metaModelManager, "xx", sa) to get the Pivot version of my Stereotype Application. This is combination with not setting an explicit context is the only way I could get the code working. Is this what you expect? A side question what use is the alias? Just curious
Here is what I came up with to get soemthing working. I have not tested this so much so i'm sure there are some issues:
package oclplugin.logic;
import org.eclipse.emf.common.util.BasicEList;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.ocl.examples.pivot.uml.UML2Pivot;
import org.eclipse.uml2.uml.Element;
import org.eclipse.uml2.uml.Stereotype;
public class OCLValidator {
//set up the required pivot/metamodel/model/OCL environment
getOCLRulesFromModel(myModel, constraints);
getOCLRulesFromAppliedProfiles(myModel, constraints);
//Now that we have all the constrains see if any are violated in the model
String expression = getOCLExpressionFromConstraint(constraint);
//loop over the elements the constraint constrains
final EList<Element> ceList = constraint.getConstrainedElements();
for(Element ce : ceList)
System.out.println(ce);//TODO:Remove this later it is here just for sanity
OCLHelper oclHelper = null;
//stereotypes must be handled specially
if(ce instanceof Stereotype)
//look for all the elements in the model that have the stereotype applied
final EList<Element> oeList = myModel.allOwnedElements();
for(Element oe : oeList)
if(oe.isStereotypeApplied((Stereotype)ce))
final EList<EObject> saList = oe.getStereotypeApplications();
for(EObject sa : saList)
//make the EObject work with the Pivot concept i.e. so the stereotype properties are available
org.eclipse.ocl.examples.pivot.Element psa= null;
try
psa = UML2Pivot.importFromUML(metaModelManager, "xx", sa);//TODO:What use if the alias??
catch(Exception e)//TODO:Maybe handle this better
e.printStackTrace();
if(psa != null)
oclHelper = ocl.createOCLHelper(psa);
//finally let's run the OCL!!
evaluateOCL(ocl,oclHelper,expression,psa);
else
oclHelper = ocl.createOCLHelper(ce);
oclHelper.setContext(ce.eClass());//Note:We only set the context for non Stereotype Applications
evaluateOCL(ocl,oclHelper,expression,ce);
private EList<Constraint> getOCLRulesFromAppliedProfiles(Model myModel, EList<Constraint> constraints)
return constraints;
private EList<Constraint> getOCLRulesFromModel(Model myModel, EList<Constraint> constraints)
return constraints;
private String getOCLExpressionFromConstraint(Constraint constraint)
indexOfOCLBody = i;
return opaqueExpression.getBodies().get(indexOfOCLBody);
return null;//there was no proper OCL to be found
private void evaluateOCL(OCL ocl,OCLHelper oclHelper,String expression, Object context)
try {
Object result = ocl.evaluate(context, createQuery);
System.out.println("result: "+result);
Ronan
Re: Checking OCL programmatically [message #1101291 is a reply to message #1100745] |
Wed, 04 September 2013 05:02  |
Thanks for getting back.
I've added https://bugs.eclipse.org/bugs/show_bug.cgi?id=351214#c1 to my
queue of things that I really must get round to.
Ed Willink
> Resource resource =
> metaModelManager);
> the model
> in the model
> String expression =
> psa= null;
> try
> psa =
> the alias??
> this better
> if(psa != null)
> else
> return constraints;
> if
> return constraints;
> for (int i = 0; i <
> if
> indexOfOCLBody = i;
> return
> try {
Current Time: Thu Jul 24 21:54:06 EDT 2025
Powered by FUDForum. Page generated in 0.11279 seconds
