Home » Eclipse Projects » Remote Application Platform (RAP) » Trouble with the new Client API
Trouble with the new Client API [message #1085960] Tue, 13 August 2013 11:46 Go to next message
Hi, I tried to ask this a while ago, but as I came back to my problem it's still there.
I tried to create a widget based on select2.js with the new client api. What I see is, that when I have multiple widgets on screen, more or less reproducible onRender of some widgets does not get called, but then it gets called on a later post request for e.g. when i resize.
I created a simple example to show the problem and I really hope you can afford a longer minute to check it out. Its really a nice thing having this dropdown, and I hope it could make it into the rap community. Let me know if I can be of assistance.
The example is on https://github.com/eiswind/select2-rap. Just checkout, set targetplatform, launch as rwt.
You'll hopefully see that the second widget appears on resize. There are some console logs in there from them I just see that on render is not being called.
Cheers
Thomas (holiday coding session)
[Updated on: Tue, 13 August 2013 11:47] by Moderator
Re: Trouble with the new Client API [message #1086470 is a reply to message #1085960] Wed, 14 August 2013 04:44 Go to previous messageGo to next message
Hi.
If you are (relatively) sure that "render" is not fired if it should
please open a bug to track this issue. If it's a bug we might get it
into a Service Release.
Greetings,
Tim
Am 13.08.2013 17:46, schrieb Thomas Kratz:
> it's still there.
> What I see is, the if I have multiple widgets on screen, more or less
> reproducable onRender of some widgets does not get called, but then it
> being called.
> Cheers
Tim Buschtöns
Twitter: @EclipseRAP
Re: Trouble with the new Client API [message #1086520 is a reply to message #1086470] Wed, 14 August 2013 05:49 Go to previous message
Thanks Tim for your support.
I just filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=415040
Previous Topic:Adding a MouseMove Listener to a Remote Object-based Custom Widget
Next Topic:Can't Revert from Rap 2.1 to RAP 1.5
Current Time: Sun Jul 27 22:27:52 EDT 2025
Powered by FUDForum. Page generated in 0.04624 seconds
