Home » Eclipse Projects » e(fx)clipse » Install missing dependencies(Missing )
Install missing dependencies [message #1086043] Tue, 13 August 2013 14:26 Go to next message
I would love some help - I'm sitting in one of Paul Anderson's JavaFX classes and trying to setup in Eclipse instead of using NetBeans. I am trying to install e(fx)clipse from the nightly builds site. The install fails due to lack of the org.eclipse.xtext.ui 0.0.0.
My update sites enabled are:
http://download.eclipse.org/eclipse/updates/4.3
http://download.eclipse.org/efxclipse/updates-nightly/site/
http://download.eclipse.org/efxclipse/runtime-nightly/site/
I am selecting this option:
e(fx)clipse - IDE - Kepler 0.9.0.201308040611
Environment:
Running Win7 Home Premium 64bit
Eclipse 4.3 Kepler
Using jdk 1.7.0_25 inside Eclipse, but Eclipse is running on JRE
The error message is:
Cannot complete the install because one or more required items could not be found.
  Software being installed: e(fx)clipse - IDE - Kepler 0.9.0.201308040611 (org.eclipse.fx.ide.all.kepler.feature.feature.group 0.9.0.201308040611)
  Missing requirement: FXGraph UI 0.9.0.201308040611 (org.eclipse.fx.ide.fxgraph.ui 0.9.0.201308040611) requires 'bundle org.eclipse.xtext.ui 0.0.0' but it could not be found
  Cannot satisfy dependency:
    From: e(fx)clipse - IDE - Kepler 0.9.0.201308040611 (org.eclipse.fx.ide.all.kepler.feature.feature.group 0.9.0.201308040611)
    To: org.eclipse.fx.ide.fxgraph.feature.feature.group [0.9.0.201308040611]
    From: e(fx)clipse - IDE - FXGraph 0.9.0.201308040611 (org.eclipse.fx.ide.fxgraph.feature.feature.group 0.9.0.201308040611)
    To: org.eclipse.fx.ide.fxgraph.ui [0.9.0.201308040611]
Re: Install missing dependencies [message #1086446 is a reply to message #1086043] Wed, 14 August 2013 04:03 Go to previous messageGo to next message
Easiest solution is to download
http://downloads.efxclipse.org/eclipse.org/sdks/nightly/ which is a
completely prebuild Eclipse 4.3 including xtext, efxclipse and a bit more.
If you need xtext you need to add the Kepler updatesite which is at
http://download.eclipse.org/releases/kepler
Tom
> Environment:
> Eclipse 4.3 Kepler
> be found.
Re: Install missing dependencies [message #1087002 is a reply to message #1086446] Wed, 14 August 2013 22:23 Go to previous messageGo to next message
The full download of the preconfigured 4.3 with e(fx)clipse did the trick.
Comparing this version to the regular 4.3 I already have, I see that I am getting p2 errors in the "broken" version of Eclipse when I point to the Kepler directory, so it appears the problem is in p2 or equinox in my install, totally unrelated to e(fx)clipse - it just couldn't read that update site properly to get the dependency.
Thanks for your assistance. My brief look at the e(fx)clipse capabilities reassure me that switching to NetBeans wouldn't be any improvement over Eclipse and I can stay in my usual environment.
Re: Install missing dependencies [message #1087196 is a reply to message #1087002] Thu, 15 August 2013 05:12 Go to previous message
Hi George,
We are steadily improving and have cool new features in the upcoming
release 0.9.0, e.g. the preview will allow you preview your stuff in
different resolutions (fixed Java7 problems just last night) and more in
the pipeline for 1.0 (maven, robovm, gradient editing, css editor
improvements).
Tom
Re: Install missing dependencies [message #1739772 is a reply to message #1086446] Wed, 14 August 2013 22:23 Go to previous message
Re: Install missing dependencies [message #1739773 is a reply to message #1087002] Thu, 15 August 2013 05:12 Go to previous message
Hi George,
improvements).
Tom
Previous Topic:Install missing dependencies
Next Topic:Running and exporting Tutorial 3 (Java8) problems
Current Time: Sat Sep 13 21:59:48 EDT 2025
Powered by FUDForum. Page generated in 0.03943 seconds
