How to run CVS tests [message #108565] |
Fri, 02 July 2004 01:13  |
Hello all,
I wish to know how to run the following CVS tests:
1.Commit
2.Tag Version and other CVS tests.
I am able to do these tests manually.
I am getting the below mentioned errors while running the Automated tests
for CVS in our server.
I have pasted the errors below.
The server reported an error while performing the "cvs update" command.
org.eclipse.team.internal.ccvs.core.connection.CVSServerExce ption: The
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolderMe mberFetcher.performErrorCheck(RemoteFolderMemberFetcher.java :166)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolderMe mberFetcher.fetchMembers(RemoteFolderMemberFetcher.java:88)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolderMe mberFetcher.fetchMembers(RemoteFolderMemberFetcher.java:73)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolder.g etMembers(RemoteFolder.java:218)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolderTr ee.getMembers(RemoteFolderTree.java:42)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolder.g etMembers(RemoteFolder.java:204)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolder.m embers(RemoteFolder.java:415)
at
org.eclipse.team.internal.ccvs.core.resources.RemoteFolder.e xists(RemoteFolder.java:110)
at
org.eclipse.team.internal.ccvs.ui.operations.ShareProjectOpe ration.createChild(ShareProjectOperation.java:125)
at
org.eclipse.team.internal.ccvs.ui.operations.ShareProjectOpe ration.ensureTreeExists(ShareProjectOperation.java:141)
at
org.eclipse.team.internal.ccvs.ui.operations.ShareProjectOpe ration.createRemoteFolder(ShareProjectOperation.java:91)
at
org.eclipse.team.internal.ccvs.ui.operations.ShareProjectOpe ration.execute(ShareProjectOperation.java:52)
at
org.eclipse.team.internal.ccvs.ui.operations.CVSOperation.ru n(CVSOperation.java:84)
at
org.eclipse.team.tests.ccvs.core.EclipseTest.executeHeadless (EclipseTest.java:830)
at
org.eclipse.team.tests.ccvs.core.EclipseTest.shareProject(Ec lipseTest.java:731)
at
org.eclipse.team.tests.ccvs.core.EclipseTest.mapNewProject(E clipseTest.java:718)
at
org.eclipse.team.tests.ccvs.core.EclipseTest.shareProject(Ec lipseTest.java:713)
at
org.eclipse.team.tests.ccvs.core.EclipseTest.createProject(E clipseTest.java:364)
at
org.eclipse.team.tests.ccvs.core.provider.ImportTest.testChe ckout(ImportTest.java:128)
at
at
at
org.eclipse.team.tests.ccvs.core.EclipseTest.runBare(Eclipse Test.java:891)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:2 2)
at junit.extensions.TestSetup$1.protect(TestSetup.java:19)
at junit.extensions.TestSetup.run(TestSetup.java:23)
at org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a:322)
at org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a:198)
at org.eclipse.test.EclipseTestRunner.main(EclipseTestRunner.ja va:133)
at org.eclipse.test.UITestApplication$3.run(UITestApplication.j ava:180)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2916)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2645)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1375)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1346)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:252)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.test.UITestApplication.runApplication(UITestAppl ication.java:123)
at org.eclipse.test.UITestApplication.run(UITestApplication.jav a:55)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
at
at
at org.eclipse.core.launcher.Main.basicRun(Main.java:186)
at org.eclipse.core.launcher.Main.run(Main.java:647)
at org.eclipse.core.launcher.Main.main(Main.java:631)
What I should do to run these tests without errors?
Anyhelp is greatly appreciated.
Thanks in advance,
Sriram.
Re: How to run CVS tests [message #108607 is a reply to message #108565] |
Fri, 02 July 2004 05:18  |
Sriram wrote:
> Hello all,
> 1.Commit
Maybe asking the question in the right newsgroup, to get more response?
The CVS is part of the Eclipse Platform not CDT.
Since in your posted faillog, the server reported the Error on 'cvs
update', I guess you should check the server settings in the automated
tests. Maybe you forgot to change the server or directory, the port
might be wrong, or the user/pwd combination, access-kind
(pserver/ext/extssh),...
FUDForum. Page generated in 0.07792 seconds
