Home » Modeling » EMF » EClassifier ordering in generated EPackages
EClassifier ordering in generated EPackages [message #1085306] Mon, 12 August 2013 14:42 Go to next message
I noticed that the EClassifiers in a generated jave EPackage are ordered
differently than in the Ecore model from which the EPackage was
generated, it seems that EEnums always come last? Just out of curiosity,
is there a "real" reason behind that, or is it just a matter of
organization?
If I read EClassifers through the EPackages Genpackage, will the
ordering be consistent? (I noticed in the Genmodel editor, the Enums are
on the bottom too...)
Felix
Re: EClassifier ordering in generated EPackages [message #1085598 is a reply to message #1085306] Tue, 13 August 2013 01:34 Go to previous messageGo to next message
Felix,
Comments below.
On 12/08/2013 8:42 PM, Felix Dorner wrote:
> ordered differently than in the Ecore model from which the EPackage
> was generated, it seems that EEnums always come last?
Yes.
> Just out of curiosity, is there a "real" reason behind that, or is it
> just a matter of organization?
More of an organizational thing, e.g., from this in GenPackageImpl, and
because the GenPackage has separate containment features for GenClass,
GenDataType, and GenEnum.
public List<GenClassifier> getOrderedGenClassifiers()
List<GenClassifier> result = new
ArrayList<GenClassifier>(getOrderedGenClasses());
result.addAll(getGenEnums());
result.addAll(getGenDataTypes());
return result;
> are on the bottom too...)
Via the getOrderedGenClassifiers, yes.
> Felix
Re: EClassifier ordering in generated EPackages [message #1085723 is a reply to message #1085598] Tue, 13 August 2013 05:18 Go to previous messageGo to next message
looks much better now.
I do this and still there's some differences.
Since I have no idea where to look for the code generator/templates I
checked out GenPackageItemProvider where I observe the same ordering
inconsistencies:
getChildrenFeatures():
childrenFeatures.add(GenModelPackage.eINSTANCE.getGenPackage_NestedGenPackages());
childrenFeatures.add(GenModelPackage.eINSTANCE.getGenPackage_GenClasses());
childrenFeatures.add(GenModelPackage.eINSTANCE.getGenPackage_GenEnums());
childrenFeatures.add(GenModelPackage.eINSTANCE.getGenPackage_GenDataTypes());
I assume that the code generator uses something similar, and not
getOrderedGenClasses()/getOrderedGenClassifiers()), this would perfectly
explain my observations.
Felix
Re: EClassifier ordering in generated EPackages [message #1085804 is a reply to message #1085723] Tue, 13 August 2013 07:46 Go to previous messageGo to next message
Felix,
Comments below.
On 13/08/2013 11:18 AM, Felix Dorner wrote:
> inconsistencies:
That code is hand modified. Otherwise the feature order in the EClass
would be used.
> perfectly explain my observations.
I'm not sure what else you're observing...
> Felix
Re: EClassifier ordering in generated EPackages [message #1085982 is a reply to message #1085804] Tue, 13 August 2013 12:23 Go to previous messageGo to next message
If you create a package like this:
MyPackage
- BClass extends AClass
- AClass
And generate code for this, then MyPackage.eInstance.getEClassifiers()
returns a list [B, A], whereas myGenPackage.getOrderedGenClassifiers()
returns [A, B] because it reorders the EClasses so that subclasses come
after their superclasses.
Felix.
Re: EClassifier ordering in generated EPackages [message #1086025 is a reply to message #1085982] Tue, 13 August 2013 13:54 Go to previous message
Felix,
Comments below.
On 13/08/2013 6:23 PM, Felix Dorner wrote:
> MyPackage
> - AClass
> come after their superclasses.
Yes, in PackageClass.javajet, the package contents are created like
this, so the order will be their order in GenPackage.getGenClasses(), in
is reconciled to be ordered like they are in the EPackage.getEClassifiers.
public void createPackageContents()
if (isCreated) return;
isCreated = true;
<%if (!genPackage.getGenClasses().isEmpty()) {%>
// Create classes and their features
<%for (Iterator<GenClass>
c=genPackage.getGenClasses().iterator(); c.hasNext();) { GenClass
genClass = c.next();%>
But GenPackage segregates GenClass, GenEnum, and GenDataType into
separate containment features and that will be noticed in the generated
package contents' order.
> Felix.
Previous Topic:XCore : opposite to several fields
Next Topic:EMF: mixed complex type generates invalid XML
Current Time: Wed Jul 23 08:52:00 EDT 2025
Powered by FUDForum. Page generated in 0.08354 seconds
