How to define mapping for JAXWS web service call [message #1084906] |
Mon, 12 August 2013 03:50  |
I am trying to call a JAX-WS websevice. Following Stardust documents System Integration/Synchronous Web Services.
1. Added WS Application, able to load all the required details.
2. Created in and out XML Data using WSDL (XSD Envelope) option.
When starting the process getting below error.
org.eclipse.stardust.common.error.PublicException: Invalid XML access point.: : Content is not allowed in prolog
I think something is wrong with my mappings and Access points.
Please let me know what I can provide you to look into it.
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1085779 is a reply to message #1085680] |
Tue, 13 August 2013 07:06   |
Rob,
1. No I was not doing it this way, Thanks for your instructions.
I think I am making progress here.
Earlier it used to complain about 'Invalid Access point', but now my first activity got completed successfully.
Still getting error for activity which call WSDL.
Here is the stacktrace.
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'InputValue', oid: 7 (process instance = 5): Application-->Completed.
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - Remove from worklists: Activity instance 'InputValue', oid: 7 (process instance = 5)
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'CallWSDL', oid: 8 (process instance = 5): Created-->Created.
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'CallWSDL', oid: 8 (process instance = 5): Created-->Application.
16:27:47 WARN [ttp-8080-8] ApplicationException -
org.xml.sax.SAXParseException; systemId: file:///C:/eclipse-kepler/; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
at org.apache.xerces.impl.XMLScanner.reportFatalError(Unknown Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl$PrologDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.eclipse.stardust.engine.core.runtime.utils.XmlUtils.parseSource(XmlUtils.java:816)
at org.eclipse.stardust.engine.core.runtime.utils.XmlUtils.parseString(XmlUtils.java:756)
at org.eclipse.stardust.engine.core.runtime.utils.XmlUtils.parseString(XmlUtils.java:731)
at org.eclipse.stardust.engine.extensions.jaxws.app.WebserviceApplicationInstance.setInAccessPointValue(WebserviceApplicationInstance.java:643)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.processInDataMappings(ActivityInstanceBean.java:1569)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1405)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1223)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invoke(ActivityInstanceBean.java:1020)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.doStartActivity(ActivityInstanceBean.java:1010)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.start(ActivityInstanceBean.java:971)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runCurrentActivity(ActivityThread.java:748)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.run(ActivityThread.java:330)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.schedule(ActivityThread.java:118)
at org.eclipse.stardust.engine.core.runtime.audittrail.management.ActivityInstanceUtils.complete(ActivityInstanceUtils.java:363)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:905)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:790)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.GuardingInterceptor.invoke(GuardingInterceptor.java:55)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.performCall(AbstractLoginInterceptor.java:171)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.invoke(AbstractLoginInterceptor.java:109)
at org.eclipse.stardust.engine.api.spring.SpringBeanLoginInterceptor.invoke(SpringBeanLoginInterceptor.java:67)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:143)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:48)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:87)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:341)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:81)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:55)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:66)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:130)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:51)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at com.sun.proxy.$Proxy123.complete(Unknown Source)
at org.eclipse.stardust.engine.api.spring.WorkflowServiceBean.complete(WorkflowServiceBean.java:68)
at org.eclipse.stardust.engine.api.spring.SpringServiceFactory$SpringServiceInvocationHandler.invoke(SpringServiceFactory.java:178)
at org.eclipse.stardust.ui.web.processportal.common.PPUtils.complete(PPUtils.java:438)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivityContinue(ActivityDetailsBean.java:1478)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.access$1000(ActivityDetailsBean.java:138)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean$7.handleEvent(ActivityDetailsBean.java:1455)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMappingContinue(ActivityDetailsBean.java:1694)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMapping(ActivityDetailsBean.java:1675)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1440)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.processActivityInstance(ActivityDetailsBean.java:1552)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.showMappedDocumentWarningAndProcessActivity(ActivityDetailsBean.java:1606)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeAction(ActivityDetailsBean.java:1424)
at com.sun.el.parser.AstValue.invoke(AstValue.java:130)
at com.sun.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:274)
at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68)
at com.sun.facelets.el.LegacyMethodBinding.invoke(LegacyMethodBinding.java:69)
at javax.faces.component.UICommand.broadcast(UICommand.java:89)
at org.eclipse.stardust.ui.web.common.app.tags.TabScopedComponent.broadcast(TabScopedComponent.java:148)
at javax.faces.component.UIViewRoot._broadcastForPhase(UIViewRoot.java:97)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:171)
at org.apache.myfaces.lifecycle.InvokeApplicationExecutor.execute(InvokeApplicationExecutor.java:32)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:50)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:169)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:110)
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:65)
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51)
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:62)
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55)
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107)
at com.icesoft.faces.webapp.http.servlet.BlockExpiredSessionRequests.service(BlockExpiredSessionRequests.java:53)
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:723)
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:71)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
16:27:47 WARN [ttp-8080-8] AuditTrailLogger - org.eclipse.stardust.common.error.PublicException: : Content is not allowed in prolog. (User: motu (Realm: carnot) (Of the Universe, Master))
16:27:47 INFO [ttp-8080-8] ProcessInstanceBean - State change for Process instance = 5 (Process Definition: Process Definition 1): Active-->Interrupted.
16:27:47 INFO [ttp-8080-8] AuditTrailLogger - Process instance interrupted. (User: motu (Realm: carnot) (Of the Universe, Master))
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'CallWSDL', oid: 8 (process instance = 5): Application-->Interrupted.
16:27:48 WARN [ttp-8080-8] AuditTrailLogger - Activity thread interrupted at 'Activity: Call WSDL', reason: org.eclipse.stardust.common.error.PublicException: : Content is not allowed in prolog. (User: motu (Realm: carnot) (Of the Universe, Master))
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1091869 is a reply to message #1089889] |
Thu, 22 August 2013 00:05  |
Ravinderjit,
I downloaded the projects, but did not deploy both of them. To reduce possible error source and to be quicker I
- used hello.wsdl and mocked the service with SOAP UI under the same url (http://localhost:9090/ws/hello?WSDL)
- created a plain vanilla RAD project
- added the hello.xsd from your project to the project's src folder so the modeler could resolve the references to the structured types
- opened your process model, made sure the WSDL loaded without errors from the unchanged URL
- double checked data mappings on the activiy (made no changes)
- started my server and deployed the model
- logged in an ran the process
- stepped through the process.
The request reached SOAP UI successfully and the response was correctly processed by the engine and displayed in the second manual activity.
Could you try if the same works for you?
If yes, in the next step can you replace the service mock with the actual service you generated (no other changes) and see if it still works?
Rob
[Updated on: Thu, 22 August 2013 00:24] by Moderator
FUDForum. Page generated in 3.47729 seconds
