Home » Archived » BIRT » birt-viewer in tomcat (2.0RC1)
birt-viewer in tomcat (2.0RC1) [message #108024] Thu, 12 January 2006 03:09 Go to next message
I have a report that is displayed in the eclipse viewer (2.0RC1) without
any errors. In the birt-viewer servlet under tomcat however I get the
following errors:
SEVERE: Message:The extension point
[org.eclipse.birt.report.model.encryptionHelper] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
12.01.2006 08:49:24 org.eclipse.birt.report.model.parser.ModuleReader
readModule
SEVERE: Parsed file was not found.
12.01.2006 08:49:24
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
SEVERE: invalid design file C:\Programme\Tomcat
5.5\webapps\birt-viewer\report\Stundenzettel.rptdesign
I have copied itext-1.3.jar to C:\Programme\Tomcat
5.5\webapps\birt-viewer\plugins\org.eclipse.birt.report.engi ne.pdf\lib,
then
axis.jar, axis-ant.jar, commons-discovery-0.2.jar, jaxrpc.jar, saaj.jar and
wsdl4j-1.5.1.jar to C:\Programme\Tomcat
5.5\webapps\birt-viewer\WEB-INF\lib and prototype.js to
C:\Programme\Tomcat 5.5\webapps\birt-viewer\ajax\lib. Am I missing
something?
Best regards
Paul
Re: birt-viewer in tomcat (2.0RC1) [message #108322 is a reply to message #108024] Thu, 12 January 2006 10:28 Go to previous messageGo to next message
Paul,
It looks like it is either a problem with finding the report or the file is
invalid.
Does it run the test report?
Jason Weathersby
BIRT PMC
"Paul Ziemann" <p.ziemann@interwall.net> wrote in message
news:afc70140862a90ecfbff00a50b36dd42$1@www.eclipse.org...
> Hello,
> following errors:
> code:EXTENSION_POINT_NOT_FOUND 12.01.2006 08:49:24
> org.eclipse.birt.report.model.parser.ModuleReader readModule
> 12.01.2006 08:49:24
> openReportDesign
> then
> and
> something?
> Best regards
> Paul
Re: birt-viewer in tomcat (2.0RC1) [message #108399 is a reply to message #108322] Thu, 12 January 2006 11:09 Go to previous messageGo to next message
Oh, it was a permission problem. Sorry and thank you!
Best regards
Paul
> invalid.
Re: birt-viewer in tomcat (2.0RC1) [message #108456 is a reply to message #108322] Thu, 12 January 2006 11:32 Go to previous messageGo to next message
Hello again,
the report is now found but the resulting page is empty. The only severe
log entry (except for EXTENSION_POINT_NOT_FOUND) is the following:
org.eclipse.birt.report.engine.data.dte.DataPresentationEngi ne doExecute
SEVERE: Can't load the report query
What might this mean?
Best regards
Paul
Re: birt-viewer in tomcat (2.0RC1) [message #108523 is a reply to message #108024] Thu, 12 January 2006 12:48 Go to previous messageGo to next message
Originally posted by: arash.barirani.verizonwireless.com
I had a number of variations of the the same error message.
These all turned out to be my problems:
1. Parameter mismatch and/or missing parameters.
2. BIRT engine home was pointing to the wrong place. It has to point to
the
directory under eclipse pluging... ( see below)
Below is Jason's email reply/solution to #2 above:
[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
[news.eclipse.birt] Re: Run report does not work under M3 ??
Date: Tue, 20 Dec 2005 12:17:39 -0500
Newsgroups: eclipse.birt
Organization: BIRT PMC
I believe this problem is occurring because the readme says to set the
engine home
directory to the viewer plugin. The viewer plugin was changed to load
classes from the Eclipse plugin directories. In order for this example to
work now, you will need to download the BIRT runtime and set engine home to
drive:\\directory\\birt-runtime-2.0M3\\birt-runtime-1_0_1\\R eport Engine
This location has all the required plugins.
Jason Weathersby
BIRT PMC
Re: birt-viewer in tomcat (2.0RC1) [message #108644 is a reply to message #108456] Thu, 12 January 2006 14:24 Go to previous messageGo to next message
Paul,
Does the test report work?
Jason
news:df277f1f5c3061731430d10fce7ecd7c$1@www.eclipse.org...
> Hello again,
> Best regards
> Paul
Re: birt-viewer in tomcat (2.0RC1) [message #108818 is a reply to message #108644] Fri, 13 January 2006 04:01 Go to previous messageGo to next message
Originally posted by: pziemann.neusta.de
yes, the test report works.
Paul
Jason Weathersby schrieb:
> Paul,
> Jason
>>Hello again,
>>Best regards
>>Paul
Re: birt-viewer in tomcat (2.0RC1) [message #108892 is a reply to message #108523] Fri, 13 January 2006 06:24 Go to previous messageGo to next message
the parameters I used are the same as in eclipse. I haven't heard of a
BIRT engine variable yet, where can I set it?
Paul
> the directory under eclipse pluging... ( see below)
> Index] [news.eclipse.birt] Re: Run report does not work under M3 ??
> From: "Jason Weathersby" <jweathersby@xxxxxxxxxxx> Date: Tue, 20 Dec
> 2005 12:17:39 -0500 Newsgroups: eclipse.birt Organization: BIRT PMC
> engine home
> to work now, you will need to download the BIRT runtime and set engine
> home to
> Jason Weathersby
> BIRT PMC
Re: birt-viewer in tomcat (2.0RC1) [message #108952 is a reply to message #108818] Fri, 13 January 2006 10:48 Go to previous messageGo to next message
Paul,
This doesnt appear to be a deployment problem, but a report problem.
The one error you are getting about the extension point, I believe everyone
is getting.
Can you post your report?
Jason
"Paul Ziemann" <pziemann@neusta.de> wrote in message
news:69q7qd.3kd.ln@igate28.intern.neusta.de...
> Paul
>> Paul,
>> Jason
>>>Hello again,
>>>Best regards
>>>Paul
Re: birt-viewer in tomcat (2.0RC1) [message #109003 is a reply to message #108892] Fri, 13 January 2006 11:06 Go to previous messageGo to next message
Originally posted by: bo.hp.com
i have also a problem to start the runtime version of birt under tomcat
4.1.x.
my problem is that i can see the viewer in my browser but the report page
is empty.
what can i do to solve this...
best regards
guido
Re: birt-viewer in tomcat (2.0RC1) [message #109608 is a reply to message #108952] Mon, 16 January 2006 03:00 Go to previous message
Sorry, I guess I cannot do this. Maybe guido can? He seems to have the
same problem: the viewer is displayed but no result from the query.
Paul
> Paul,
> is getting.
> Jason
>>Hi,
>>Paul
>>>Paul,
>>>Jason
>>>>Hello again,
>>>>Best regards
>>>>Paul
Previous Topic:node selection and XML data sets
Next Topic:How to return the maximum age and associated name?
Current Time: Fri Nov 07 01:24:27 EST 2025
Powered by FUDForum. Page generated in 0.09072 seconds
