Home » Language IDEs » C / C++ IDE (CDT) » Debugger isn't working(Debugger isn't setting breakpoints)
Debugger isn't working [message #1084514] Sun, 11 August 2013 13:44 Go to next message
So recently as I was working on my project, I had a severe bug show up and I need to figure out where it is. However, some of the settings for the editor got changed and the debugger has stopped working. Each breakpoint shows up as a "white" dot. It shows blue when I assign it, checked when I click debug, but right before my program's window pops up the breakpoints turn white.
Here's the output from GDB:
808,762 2-environment-cd "/home/mike/Bitwise BACKUP (copy)/Bitwise"
808,763 2^done
808,764 (gdb)
808,766 3-gdb-set breakpoint pending on
808,766 4-list-thread-groups
808,767 3^done
808,767 (gdb)
808,768 4^done,groups=[{id="i1",type="process"}]
808,768 (gdb)
808,769 5-gdb-set detach-on-fork off
808,769 5^done
808,769 (gdb)
808,771 6-enable-pretty-printing
808,771 6^done
808,771 (gdb)
808,773 7-gdb-set python print-stack none
808,774 7^done
808,774 (gdb)
808,776 8-gdb-set print object on
808,776 8^done
808,777 (gdb)
808,778 9-gdb-set print sevenbit-strings on
808,778 9^done
808,778 (gdb)
808,779 10-gdb-set host-charset UTF-8
808,780 10^done
808,780 (gdb)
808,781 11-gdb-set target-charset UTF-8
808,781 11^done
808,782 (gdb)
808,783 12-gdb-set target-wide-charset UTF-32
808,784 12^done
808,784 (gdb)
808,786 13source .gdbinit
808,786 &"source .gdbinit\n"
808,786 &".gdbinit: No such file or directory.\n"
808,787 13^error,msg=".gdbinit: No such file or directory."
808,787 (gdb)
808,788 14-gdb-set target-async off
808,788 14^done
808,789 (gdb)
808,790 15-gdb-set auto-solib-add on
808,790 15^done
808,790 (gdb)
808,795 16-file-exec-and-symbols --thread-group i1 "/home/mike/Bitwise BACKUP (copy)/Bitwise/Linux/B\
itwise"
808,889 16^done
808,889 (gdb)
808,891 17-data-evaluate-expression --thread-group i1 "sizeof (void*)"
808,904 17^done,value="4"
808,905 (gdb)
808,906 18-interpreter-exec --thread-group i1 console "show endian"
808,906 ~"The target endianness is set automatically (currently little endian)\n"
808,906 18^done
808,906 (gdb)
808,926 19-break-insert --thread-group i1 -f "\"/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bitwise\
.cpp\":130"
808,927 20-break-insert --thread-group i1 -d -f "\"/home/mike/Bitwise BACKUP/Bitwise/src/BLevelProce\
ssor.cpp\":68"
808,927 21-break-insert --thread-group i1 -d -f "\"/home/mike/Bitwise BACKUP/Bitwise/src/Bitwise.cpp\
\":1"
808,927 22-break-insert --thread-group i1 -d -f "\"/home/mike/BitWise BACKUP/Bitwise/src/Game/Class/\
BPlayer.cpp\":63"
808,927 23-break-insert --thread-group i1 -d -f "\"/home/mike/Bitwise BACKUP/Bitwise/src/BLevelProce\
ssor.cpp\":84"
808,975 19^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x0806e8ec",func="m\
ain(int, char**)",file="../src/Bitwise.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/B\
itwise.cpp",line="130",times="0",original-location="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bit\
wise.cpp:130"}
808,976 (gdb)
808,977 &"No source file named /home/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp.\n"
808,977 20^done,bkpt={number="2",type="breakpoint",disp="keep",enabled="n",addr="<PENDING>",pending=\
"\"/home/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp\":68",times="0",original-location="\"/h\
ome/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp\":68"}
808,977 (gdb)
808,978 &"No source file named /home/mike/Bitwise BACKUP/Bitwise/src/Bitwise.cpp.\n"
808,978 21^done,bkpt={number="3",type="breakpoint",disp="keep",enabled="n",addr="<PENDING>",pending=\
"\"/home/mike/Bitwise BACKUP/Bitwise/src/Bitwise.cpp\":1",times="0",original-location="\"/home/mike/\
Bitwise BACKUP/Bitwise/src/Bitwise.cpp\":1"}
808,978 (gdb)
808,978 &"No source file named /home/mike/BitWise BACKUP/Bitwise/src/Game/Class/BPlayer.cpp.\n"
808,978 22^done,bkpt={number="4",type="breakpoint",disp="keep",enabled="n",addr="<PENDING>",pending=\
"\"/home/mike/BitWise BACKUP/Bitwise/src/Game/Class/BPlayer.cpp\":63",times="0",original-location="\\
"/home/mike/BitWise BACKUP/Bitwise/src/Game/Class/BPlayer.cpp\":63"}
808,979 (gdb)
808,979 &"No source file named /home/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp.\n"
808,980 23^done,bkpt={number="5",type="breakpoint",disp="keep",enabled="n",addr="<PENDING>",pending=\
"\"/home/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp\":84",times="0",original-location="\"/h\
ome/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp\":84"}
808,980 (gdb)
808,992 24-break-insert --thread-group i1 -t -f main
808,996 24^done,bkpt={number="6",type="breakpoint",disp="del",enabled="y",addr="0x0806e75f",func="ma\
in(int, char**)",file="../src/Bitwise.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bi\
twise.cpp",line="117",times="0",original-location="main"}
808,996 (gdb)
808,998 25-inferior-tty-set --thread-group i1 /dev/pts/1
808,998 25^done
808,998 (gdb)
809,006 26-exec-run --thread-group i1
809,007 =thread-group-started,id="i1",pid="5443"
809,008 27-list-thread-groups --available
809,010 =thread-created,id="1",group-id="i1"
809,010 26^running
809,010 *running,thread-id="all"
809,010 (gdb)
809,015 =library-loaded,id="/lib/ld-linux.so.2",target-name="/lib/ld-linux.so.2",host-name="/lib/ld-\
linux.so.2",symbols-loaded="0",thread-group="i1"
809,019 &"Error in re-setting breakpoint 1: Function \"/home/mike/Bitwise BACKUP (copy)/Bitwise/src/\
Bitwise.cpp:130\" not defined.\n"
809,027 =breakpoint-modified,bkpt={number="1",type="breakpoint",disp="keep",enabled="n",addr="<PENDI\
NG>",pending="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bitwise.cpp:130",times="0",original-locat\
ion="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bitwise.cpp:130"}
809,064 =library-loaded,id="/usr/lib/SFML/libsfml-graphics.so.1.6",target-name="/usr/lib/SFML/libsfm\
l-graphics.so.1.6",host-name="/usr/lib/SFML/libsfml-graphics.so.1.6",symbols-loaded="0",thread-group\
="i1"
809,065 =library-loaded,id="/usr/lib/SFML/libsfml-window.so.1.6",target-name="/usr/lib/SFML/libsfml-\
window.so.1.6",host-name="/usr/lib/SFML/libsfml-window.so.1.6",symbols-loaded="0",thread-group="i1"
809,065 =library-loaded,id="/usr/lib/SFML/libsfml-system.so.1.6",target-name="/usr/lib/SFML/libsfml-\
system.so.1.6",host-name="/usr/lib/SFML/libsfml-system.so.1.6",symbols-loaded="0",thread-group="i1"
809,065 =library-loaded,id="/usr/lib/i386-linux-gnu/libstdc++.so.6",target-name="/usr/lib/i386-linux\
-gnu/libstdc++.so.6",host-name="/usr/lib/i386-linux-gnu/libstdc++.so.6",symbols-loaded="0",thread-gr\
oup="i1"
809,065 =library-loaded,id="/lib/i386-linux-gnu/libm.so.6",target-name="/lib/i386-linux-gnu/libm.so.\
6",host-name="/lib/i386-linux-gnu/libm.so.6",symbols-loaded="0",thread-group="i1"
809,066 =library-loaded,id="/lib/i386-linux-gnu/libgcc_s.so.1",target-name="/lib/i386-linux-gnu/libg\
cc_s.so.1",host-name="/lib/i386-linux-gnu/libgcc_s.so.1",symbols-loaded="0",thread-group="i1"
809,066 =library-loaded,id="/lib/i386-linux-gnu/libc.so.6",target-name="/lib/i386-linux-gnu/libc.so.\
6",host-name="/lib/i386-linux-gnu/libc.so.6",symbols-loaded="0",thread-group="i1"
809,066 =library-loaded,id="/lib/i386-linux-gnu/libpthread.so.0",target-name="/lib/i386-linux-gnu/li\
bpthread.so.0",host-name="/lib/i386-linux-gnu/libpthread.so.0",symbols-loaded="0",thread-group="i1"
809,066 =library-loaded,id="/usr/lib/libGLEW.so.1.5",target-name="/usr/lib/libGLEW.so.1.5",host-name\
="/usr/lib/libGLEW.so.1.5",symbols-loaded="0",thread-group="i1"
809,066 =library-loaded,id="/usr/lib/i386-linux-gnu/libjpeg.so.8",target-name="/usr/lib/i386-linux-g\
nu/libjpeg.so.8",host-name="/usr/lib/i386-linux-gnu/libjpeg.so.8",symbols-loaded="0",thread-group="i\
1"
809,066 =library-loaded,id="/lib/i386-linux-gnu/libpng12.so.0",target-name="/lib/i386-linux-gnu/libp\
ng12.so.0",host-name="/lib/i386-linux-gnu/libpng12.so.0",symbols-loaded="0",thread-group="i1"
809,067 =library-loaded,id="/usr/lib/libSOIL.so.1",target-name="/usr/lib/libSOIL.so.1",host-name="/u\
sr/lib/libSOIL.so.1",symbols-loaded="0",thread-group="i1"
809,067 =library-loaded,id="/usr/lib/i386-linux-gnu/libfreetype.so.6",target-name="/usr/lib/i386-lin\
ux-gnu/libfreetype.so.6",host-name="/usr/lib/i386-linux-gnu/libfreetype.so.6",symbols-loaded="0",thr\
ead-group="i1"
809,067 =library-loaded,id="/usr/lib/libGL.so.1",target-name="/usr/lib/libGL.so.1",host-name="/usr/l\
ib/libGL.so.1",symbols-loaded="0",thread-group="i1"
809,067 =library-loaded,id="/usr/lib/i386-linux-gnu/libX11.so.6",target-name="/usr/lib/i386-linux-gn\
u/libX11.so.6",host-name="/usr/lib/i386-linux-gnu/libX11.so.6",symbols-loaded="0",thread-group="i1"
809,067 =library-loaded,id="/usr/lib/i386-linux-gnu/libXrandr.so.2",target-name="/usr/lib/i386-linux\
-gnu/libXrandr.so.2",host-name="/usr/lib/i386-linux-gnu/libXrandr.so.2",symbols-loaded="0",thread-gr\
oup="i1"
809,068 =library-loaded,id="/lib/i386-linux-gnu/libz.so.1",target-name="/lib/i386-linux-gnu/libz.so.\
1",host-name="/lib/i386-linux-gnu/libz.so.1",symbols-loaded="0",thread-group="i1"
809,073 =library-loaded,id="/usr/lib/tls/libnvidia-tls.so.325.15",target-name="/usr/lib/tls/libnvidi\
a-tls.so.325.15",host-name="/usr/lib/tls/libnvidia-tls.so.325.15",symbols-loaded="0",thread-group="i\
1"
809,073 =library-loaded,id="/usr/lib/libnvidia-glcore.so.325.15",target-name="/usr/lib/libnvidia-glc\
ore.so.325.15",host-name="/usr/lib/libnvidia-glcore.so.325.15",symbols-loaded="0",thread-group="i1"
809,073 =library-loaded,id="/usr/lib/i386-linux-gnu/libXext.so.6",target-name="/usr/lib/i386-linux-g\
nu/libXext.so.6",host-name="/usr/lib/i386-linux-gnu/libXext.so.6",symbols-loaded="0",thread-group="i\
1"
809,073 =library-loaded,id="/lib/i386-linux-gnu/libdl.so.2",target-name="/lib/i386-linux-gnu/libdl.s\
o.2",host-name="/lib/i386-linux-gnu/libdl.so.2",symbols-loaded="0",thread-group="i1"
809,073 =library-loaded,id="/usr/lib/i386-linux-gnu/libxcb.so.1",target-name="/usr/lib/i386-linux-gn\
u/libxcb.so.1",host-name="/usr/lib/i386-linux-gnu/libxcb.so.1",symbols-loaded="0",thread-group="i1"
809,073 =library-loaded,id="/usr/lib/i386-linux-gnu/libXrender.so.1",target-name="/usr/lib/i386-linu\
x-gnu/libXrender.so.1",host-name="/usr/lib/i386-linux-gnu/libXrender.so.1",symbols-loaded="0",thread\
-group="i1"
809,074 =library-loaded,id="/usr/lib/i386-linux-gnu/libXau.so.6",target-name="/usr/lib/i386-linux-gn\
u/libXau.so.6",host-name="/usr/lib/i386-linux-gnu/libXau.so.6",symbols-loaded="0",thread-group="i1"
809,074 =library-loaded,id="/usr/lib/i386-linux-gnu/libXdmcp.so.6",target-name="/usr/lib/i386-linux-\
gnu/libXdmcp.so.6",host-name="/usr/lib/i386-linux-gnu/libXdmcp.so.6",symbols-loaded="0",thread-group\
="i1"
809,112 ~"[Thread debugging using libthread_db enabled]\n"
809,112 ~"Using host libthread_db library \"/lib/i386-linux-gnu/libthread_db.so.1\".\n"
809,144 =library-loaded,id="/lib/i386-linux-gnu/libselinux.so.1",target-name="/lib/i386-linux-gnu/li\
bselinux.so.1",host-name="/lib/i386-linux-gnu/libselinux.so.1",symbols-loaded="0",thread-group="i1"
809,152 =library-unloaded,id="/lib/i386-linux-gnu/libselinux.so.1",target-name="/lib/i386-linux-gnu/\
libselinux.so.1",host-name="/lib/i386-linux-gnu/libselinux.so.1",thread-group="i1"
809,202 =breakpoint-modified,bkpt={number="6",type="breakpoint",disp="del",enabled="y",addr="0x0806e\
75f",func="main(int, char**)",file="../src/Bitwise.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/B\
itwise/src/Bitwise.cpp",line="117",times="1",original-location="main"}
809,206 *stopped,reason="breakpoint-hit",disp="del",bkptno="6",frame={addr="0x0806e75f",func="main",\
args=[{name="mn",value="1"},{name="arg",value="0xbffff374"}],file="../src/Bitwise.cpp",fullname="/ho\
me/mike/Bitwise BACKUP (copy)/Bitwise/src/Bitwise.cpp",line="117"},thread-id="1",stopped-threads="al\
l",core="1"
809,206 =breakpoint-deleted,id="6"
809,206 (gdb)
809,240 27^done,groups=[{id="1",type="process",description="/sbin/init",user="root",cores=["2"]},{id\
="2",type="process",description="[kthreadd]",user="root",cores=["1"]},{id="3",type="process",descrip\
tion="[ksoftirqd/0]",user="root",cores=["0"]},{id="6",type="process",description="[migration/0]",use\
r="root",cores=["0"]},{id="7",type="process",description="[watchdog/0]",user="root",cores=["0"]},{id\
="8",type="process",description="[migration/1]",user="root",cores=["1"]},{id="10",type="process",des\
cription="[ksoftirqd/1]",user="root",cores=["1"]},{id="11",type="process",description="[watchdog/1]"\
,user="root",cores=["1"]},{id="12",type="process",description="[migration/2]",user="root",cores=["2"\
]},{id="14",type="process",description="[ksoftirqd/2]",user="root",cores=["2"]},{id="15",type="proce\
ss",description="[watchdog/2]",user="root",cores=["2"]},{id="16",type="process",description="[migrat\
ion/3]",user="root",cores=["3"]},{id="18",type="process",description="[ksoftirqd/3]",user="root",cor\
es=["3"]},{id="19",type="process",description="[watchdog/3]",user="root",cores=["3"]},{id="20",type=\
"process",description="[cpuset]",user="root",cores=["2"]},{id="21",type="process",description="[khel\
per]",user="root",cores=["2"]},{id="22",type="process",description="[kdevtmpfs]",user="root",cores=[\
"3"]},{id="23",type="process",description="[netns]",user="root",cores=["2"]},{id="25",type="process"\
,description="[sync_supers]",user="root",cores=["1"]},{id="26",type="process",description="[bdi-defa\
ult]",user="root",cores=["0"]},{id="27",type="process",description="[kintegrityd]",user="root",cores\
=["3"]},{id="28",type="process",description="[kblockd]",user="root",cores=["3"]},{id="29",type="proc\
ess",description="[ata_sff]",user="root",cores=["3"]},{id="30",type="process",description="[khubd]",\
user="root",cores=["3"]},{id="31",type="process",description="[md]",user="root",cores=["3"]},{id="36\
",type="process",description="[khungtaskd]",user="root",cores=["0"]},{id="37",type="process",descrip\
tion="[kswapd0]",user="root",cores=["3"]},{id="38",type="process",description="[ksmd]",user="root",c\
ores=["3"]},{id="39",type="process",description="[khugepaged]",user="root",cores=["3"]},{id="40",typ\
e="process",description="[fsnotify_mark]",user="root",cores=["2"]},{id="41",type="process",descripti\
on="[ecryptfs-kthrea]",user="root",cores=["3"]},{id="42",type="process",description="[crypto]",user=\
"root",cores=["3"]},{id="51",type="process",description="[kthrotld]",user="root",cores=["2"]},{id="5\
3",type="process",description="[binder]",user="root",cores=["3"]},{id="72",type="process",descriptio\
n="[deferwq]",user="root",cores=["1"]},{id="73",type="process",description="[charger_manager]",user=\
"root",cores=["1"]},{id="75",type="process",description="[devfreq_wq]",user="root",cores=["3"]},{id=\
"203",type="process",description="[scsi_eh_0]",user="root",cores=["3"]},{id="215",type="process",des\
cription="[scsi_eh_1]",user="root",cores=["0"]},{id="221",type="process",description="[scsi_eh_2]",u\
ser="root",cores=["1"]},{id="223",type="process",description="[scsi_eh_3]",user="root",cores=["3"]},\
{id="224",type="process",description="[kworker/u:4]",user="root",cores=["3"]},{id="226",type="proces\
s",description="[scsi_eh_4]",user="root",cores=["2"]},{id="227",type="process",description="[scsi_eh\
_5]",user="root",cores=["2"]},{id="229",type="process",description="[kworker/u:7]",user="root",cores\
=["2"]},{id="280",type="process",description="[jbd2/sdb6-8]",user="root",cores=["1"]},{id="281",type\
="process",description="[ext4-dio-unwrit]",user="root",cores=["2"]},{id="466",type="process",descrip\
tion="upstart-udev-bridge --daemon",user="root",cores=["2"]},{id="468",type="process",description="/\
sbin/udevd --daemon",user="root",cores=["1"]},{id="582",type="process",description="/sbin/udevd --da\
emon",user="root",cores=["1"]},{id="583",type="process",description="/sbin/udevd --daemon",user="roo\
t",cores=["1"]},{id="761",type="process",description="upstart-socket-bridge --daemon",user="root",co\
res=["1"]},{id="763",type="process",description="[kvm-irqfd-clean]",user="root",cores=["1"]},{id="79\
4",type="process",description="rsyslogd -c5",user="syslog",cores=["0","2","3"]},{id="795",type="proc\
ess",description="[hd-audio0]",user="root",cores=["3"]},{id="889",type="process",description="/sbin/\
getty -8 38400 tty4",user="root",cores=["1"]},{id="897",type="process",description="/sbin/getty -8 3\
8400 tty5",user="root",cores=["1"]},{id="909",type="process",description="/sbin/getty -8 38400 tty2"\
,user="root",cores=["3"]},{id="910",type="process",description="/sbin/getty -8 38400 tty3",user="roo\
t",cores=["1"]},{id="912",type="process",description="/sbin/getty -8 38400 tty6",user="root",cores=[\
"3"]},{id="917",type="process",description="acpid -c /etc/acpi/events -s /var/run/acpid.socket",user\
="root",cores=["3"]},{id="925",type="process",description="whoopsie",user="whoopsie",cores=["3"]},{i\
d="927",type="process",description="/usr/sbin/irqbalance",user="root",cores=["3"]},{id="934",type="p\
rocess",description="cron",user="root",cores=["3"]},{id="935",type="process",description="atd",user=\
"daemon",cores=["0"]},{id="938",type="process",description="php-fpm: master process (/etc/php5/fpm/p\
hp-fpm.conf)",user="root",cores=["1"]},{id="940",type="process",description="php-fpm: pool www",user\
="www-data",cores=["2"]},{id="942",type="process",description="php-fpm: pool www",user="www-data",co\
res=["0"]},{id="943",type="process",description="php-fpm: pool www",user="www-data",cores=["0"]},{id\
="944",type="process",description="php-fpm: pool www",user="www-data",cores=["0"]},{id="959",type="p\
rocess",description="/usr/sbin/cupsd -F",user="root",cores=["2"]},{id="980",type="process",descripti\
on="[iprt]",user="root",cores=["0"]},{id="1034",type="process",description="/usr/sbin/winbindd",user\
="root",cores=["3"]},{id="1089",type="process",description="/usr/sbin/winbindd",user="root",cores=["\
2"]},{id="1090",type="process",description="/usr/sbin/apache2 -k start",user="root",cores=["2"]},{id\
="1150",type="process",description="dbus-daemon --system --fork --activation=upstart",user="messageb\
us",cores=["0"]},{id="1179",type="process",description="/usr/sbin/modem-manager",user="root",cores=[\
"1"]},{id="1183",type="process",description="avahi-daemon: running [mike-gx620.local]",user="avahi",\
cores=["1"]},{id="1184",type="process",description="avahi-daemon: chroot helper",user="avahi",cores=\
["2"]},{id="1197",type="process",description="/usr/sbin/bluetoothd",user="root",cores=["3"]},{id="12\
70",type="process",description="/sbin/getty -8 38400 tty1",user="root",cores=["0"]},{id="1272",type=\
"process",description="[krfcommd]",user="root",cores=["0"]},{id="1275",type="process",description="N\
etworkManager",user="root",cores=["0","1","3"]},{id="1278",type="process",description="/usr/lib/poli\
cykit-1/polkitd --no-debug",user="root",cores=["0","1"]},{id="1282",type="process",description="/sbi\
n/dhclient -d -4 -sf /usr/lib/NetworkManager/nm-dhcp-client.action -pf /var/run/sendsigs.omit.d/netw\
ork-manager.dhclient-eth1.pid -lf /var/lib/dhcp/dhclient-6e8635a1-1bbf-4ead-9bd1-d9ecd91fffec-eth1.l\
ease -cf /var/run/nm-dhclient-eth1.conf eth1",user="root",cores=["0"]},{id="1299",type="process",des\
cription="/opt/teamviewer8/tv_bin/teamviewerd -f",user="root",cores=["0","1","2"]},{id="1300",type="\
process",description="lightdm",user="root",cores=["2","3"]},{id="1307",type="process",description="/\
usr/bin/X :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch",user="root",cores=["3"]},\
{id="1316",type="process",description="lightdm --session-child 12 15",user="root",cores=["0"]},{id="\
1319",type="process",description="/usr/lib/accountsservice/accounts-daemon",user="root",cores=["0","\
2"]},{id="1342",type="process",description="/usr/sbin/console-kit-daemon --no-daemon",user="root",co\
res=["0","1","2","3"]},{id="1417",type="process",description="gnome-session --session=gnome",user="m\
ike",cores=["0","1","2"]},{id="1445",type="process",description="/usr/sbin/dnsmasq --no-resolv --kee\
p-in-foreground --no-hosts --bind-interfaces --pid-file=/var/run/sendsigs.omit.d/network-manager.dns\
masq.pid --listen-address=127.0.0.1 --conf-file=/var/run/nm-dns-dnsmasq.conf --cache-size=0 --proxy-\
dnssec",user="nobody",cores=["0"]},{id="1453",type="process",description="[flush-8:16]",user="root",\
cores=["0"]},{id="1536",type="process",description="/opt/teamviewer8/tv_bin/wine/bin/wineserver",use\
r="mike",cores=["2"]},{id="1546",type="process",description="/usr/bin/ssh-agent /usr/bin/dbus-launch\
 --exit-with-session gnome-session --session=gnome",user="mike",cores=["3"]},{id="1549",type="proces\
s",description="/usr/bin/dbus-launch --exit-with-session gnome-session --session=gnome",user="mike",\
cores=["2"]},{id="1550",type="process",description="//bin/dbus-daemon --fork --print-pid 5 --print-a\
ddress 7 --session",user="mike",cores=["2"]},{id="1561",type="process",description="/usr/lib/gnome-s\
ettings-daemon/gnome-settings-daemon",user="mike",cores=["0","1"]},{id="1563",type="process",descrip\
tion="/usr/bin/gnome-keyring-daemon --start --components=ssh",user="mike",cores=["0","1","2"]},{id="\
1575",type="process",description="/usr/lib/upower/upowerd",user="root",cores=["1","2"]},{id="1632",t\
ype="process",description="/usr/lib/gvfs/gvfsd",user="mike",cores=["3"]},{id="1641",type="process",d\
escription="/usr/lib/gvfs//gvfs-fuse-daemon -f /home/mike/.gvfs",user="mike",cores=["1","2","3"]},{i\
d="1713",type="process",description="/usr/lib/gnome-settings-daemon/gsd-printer",user="mike",cores=[\
"2","3"]},{id="1715",type="process",description="/usr/bin/gnome-shell",user="mike",cores=["0","1","2\
","3"]},{id="1717",type="process",description="/usr/lib/i386-linux-gnu/colord/colord",user="colord",\
cores=["1","3"]},{id="1732",type="process",description="/usr/bin/pulseaudio --start --log-target=sys\
log",user="mike",cores=["0"]},{id="1734",type="process",description="/usr/lib/rtkit/rtkit-daemon",us\
er="rtkit",cores=["0","1","3"]},{id="1741",type="process",description="/usr/lib/pulseaudio/pulse/gco\
nf-helper",user="mike",cores=["1"]},{id="1743",type="process",description="/usr/lib/i386-linux-gnu/g\
conf/gconfd-2",user="mike",cores=["3"]},{id="1748",type="process",description="nautilus -n",user="mi\
ke",cores=["1"]},{id="1749",type="process",description="/usr/bin/python /usr/bin/blueman-applet",use\
r="mike",cores=["2"]},{id="1751",type="process",description="nm-applet",user="mike",cores=["0","1"]}\
,{id="1752",type="process",description="/opt/google/chrome/chrome --no-startup-window",user="mike",c\
ores=["0","1","2","3"]},{id="1760",type="process",description="/opt/google/chrome/chrome --no-startu\
p-window",user="mike",cores=["1"]},{id="1761",type="process",description="/opt/google/chrome/chrome-\
sandbox /opt/google/chrome/chrome --type=zygote",user="mike",cores=["2"]},{id="1763",type="process",\
description="/opt/google/chrome/chrome --type=zygote",user="mike",cores=["2"]},{id="1767",type="proc\
ess",description="/opt/google/chrome/nacl_helper_bootstrap /opt/google/chrome/nacl_helper --reserved\
_at_zero=0x0000000040000000 --r_debug=0x0000000040000000",user="mike",cores=["0"]},{id="1771",type="\
process",description="/usr/lib/gvfs/gvfs-gdu-volume-monitor",user="mike",cores=["3"]},{id="1773",typ\
e="process",description="/usr/lib/udisks/udisks-daemon",user="root",cores=["1"]},{id="1775",type="pr\
ocess",description="udisks-daemon: not polling any devices",user="root",cores=["1"]},{id="1780",type\
="process",description="/usr/lib/gvfs/gvfs-gphoto2-volume-monitor",user="mike",cores=["3"]},{id="178\
2",type="process",description="/usr/lib/gvfs/gvfs-afc-volume-monitor",user="mike",cores=["1","2"]},{\
id="1785",type="process",description="/usr/lib/gvfs/gvfsd-trash --spawner :1.10 /org/gtk/gvfs/exec_s\
paw/0",user="mike",cores=["0"]},{id="1789",type="process",description="/opt/google/chrome/chrome --t\
ype=zygote",user="mike",cores=["2"]},{id="1822",type="process",description="/opt/google/chrome/chrom\
e --type=renderer --lang=en-GB --force-fieldtrials=AsyncDns/AsyncDnsA/AutocompleteDynamicTrial_2/Def\
aultControl/ForceCompositingMode/disable/InfiniteCache/No/Prerender/PrerenderEnabled/Test0PercentDef\
ault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-New-Install-Uniformity-Trial/Control/U\
MA-Session-Randomized-Uniformity-Trial-5-Percent/group_05/UMA-Uniformity-Trial-1-Percent/group_59/UM\
A-Uniformity-Trial-10-Percent/group_07/UMA-Uniformity-Trial-20-Percent/group_04/UMA-Uniformity-Trial\
-5-Percent/group_14/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-p\
review --disable-webgl --disable-pepper-3d --disable-gl-multisampling --disable-accelerated-composit\
ing --disable-accelerated-2d-canvas --disable-accelerated-video-decode --channel=1752.0.1981372842",\
user="mike",cores=["0","1","2"]},{id="1830",type="process",description="/opt/google/chrome/chrome --\
type=renderer --lang=en-GB --force-fieldtrials=AsyncDns/AsyncDnsA/AutocompleteDynamicTrial_2/Default\
Control/ForceCompositingMode/disable/InfiniteCache/No/Prerender/PrerenderEnabled/Test0PercentDefault\
/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-New-Install-Uniformity-Trial/Control/UMA-S\
ession-Randomized-Uniformity-Trial-5-Percent/group_05/UMA-Uniformity-Trial-1-Percent/group_59/UMA-Un\
iformity-Trial-10-Percent/group_07/UMA-Uniformity-Trial-20-Percent/group_04/UMA-Uniformity-Trial-5-P\
ercent/group_14/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-previ\
ew --disable-webgl --disable-pepper-3d --disable-gl-multisampling --disable-accelerated-compositing \
--disable-accelerated-2d-canvas --disable-accelerated-video-decode --channel=1752.1.1031076998",user\
="mike",cores=["0","1","3"]},{id="1839",type="process",description="/usr/lib/gnome-shell/gnome-shell\
-calendar-server",user="mike",cores=["1","2","3"]},{id="1844",type="process",description="/usr/lib/t\
elepathy/mission-control-5",user="mike",cores=["0","3"]},{id="1848",type="process",description="/usr\
/lib/gnome-online-accounts/goa-daemon",user="mike",cores=["0","3"]},{id="1885",type="process",descri\
ption="/usr/bin/obex-data-server --no-daemon",user="mike",cores=["3"]},{id="1892",type="process",des\
cription="/usr/lib/gvfs/gvfsd-burn --spawner :1.10 /org/gtk/gvfs/exec_spaw/1",user="mike",cores=["2"\
]},{id="1926",type="process",description="/usr/lib/gvfs/gvfsd-metadata",user="mike",cores=["2"]},{id\
="1949",type="process",description="/usr/lib/gnome-disk-utility/gdu-notification-daemon",user="mike"\
,cores=["0","3"]},{id="1964",type="process",description="gnome-screensaver",user="mike",cores=["1","\
2","3"]},{id="1965",type="process",description="zeitgeist-datahub",user="mike",cores=["1"]},{id="197\
2",type="process",description="/usr/bin/zeitgeist-daemon",user="mike",cores=["0","1"]},{id="1980",ty\
pe="process",description="/usr/lib/zeitgeist/zeitgeist-fts",user="mike",cores=["2","3"]},{id="1987",\
type="process",description="/bin/cat",user="mike",cores=["2"]},{id="1996",type="process",description\
="/usr/lib/evolution/e-addressbook-factory",user="mike",cores=["1","2"]},{id="2019",type="process",d\
escription="/usr/bin/python /usr/lib/ubuntuone-client/ubuntuone-syncdaemon",user="mike",cores=["1"]}\
,{id="2053",type="process",description="bash /usr/bin/steam",user="mike",cores=["2"]},{id="2064",typ\
e="process",description="bash /home/mike/.local/share/Steam/steam.sh",user="mike",cores=["0"]},{id="\
2065",type="process",description="tee /tmp/dumps/mike_stdout.txt",user="mike",cores=["1"]},{id="2155\
",type="process",description="/home/mike/.local/share/Steam/ubuntu12_32/steam",user="mike",cores=["0\
","1","2","3"]},{id="2298",type="process",description="update-notifier",user="mike",cores=["0","2","\
3"]},{id="2526",type="process",description="/usr/lib/deja-dup/deja-dup/deja-dup-monitor",user="mike"\
,cores=["0","2","3"]},{id="2919",type="process",description="/usr/sbin/apache2 -k start",user="www-d\
ata",cores=["2"]},{id="2920",type="process",description="/usr/sbin/apache2 -k start",user="www-data"\
,cores=["3"]},{id="2921",type="process",description="/usr/sbin/apache2 -k start",user="www-data",cor\
es=["2"]},{id="2922",type="process",description="/usr/sbin/apache2 -k start",user="www-data",cores=[\
"3"]},{id="2923",type="process",description="/usr/sbin/apache2 -k start",user="www-data",cores=["2"]\
},{id="4844",type="process",description="[kworker/1:2]",user="root",cores=["1"]},{id="4853",type="pr\
ocess",description="[kworker/3:1]",user="root",cores=["3"]},{id="4854",type="process",description="[\
kworker/1:0]",user="root",cores=["1"]},{id="4856",type="process",description="[kworker/0:0]",user="r\
oot",cores=["0"]},{id="4857",type="process",description="[kworker/2:2]",user="root",cores=["2"]},{id\
="4937",type="process",description="[kworker/3:2]",user="root",cores=["3"]},{id="4938",type="process\
",description="[kworker/1:1]",user="root",cores=["1"]},{id="4968",type="process",description="[kwork\
er/0:1]",user="root",cores=["0"]},{id="4979",type="process",description="[kworker/2:0]",user="root",\
cores=["2"]},{id="5054",type="process",description="/opt/google/chrome/chrome --type=renderer --lang\
=en-GB --force-fieldtrials=AsyncDns/AsyncDnsA/AutocompleteDynamicTrial_2/DefaultControl/ForceComposi\
tingMode/disable/InfiniteCache/No/OmniboxStopTimer/UseStopTimer/Prerender/PrerenderEnabled/Prerender\
FromOmnibox/OmniboxPrerenderEnabled/SendFeedbackLinkLocation/alt-location/Test0PercentDefault/group_\
01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-New-Install-Uniformity-Trial/Control/UMA-Session-\
Randomized-Uniformity-Trial-5-Percent/group_05/UMA-Uniformity-Trial-1-Percent/group_59/UMA-Uniformit\
y-Trial-10-Percent/group_07/UMA-Uniformity-Trial-20-Percent/group_04/UMA-Uniformity-Trial-5-Percent/\
group_14/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --disable-webgl --disabl\
e-pepper-3d --disable-gl-multisampling --disable-accelerated-compositing --disable-accelerated-2d-ca\
nvas --disable-accelerated-video-decode --channel=1752.277.1151322154",user="mike",cores=["0","1","3\
"]},{id="5070",type="process",description="[kworker/3:0]",user="root",cores=["3"]},{id="5072",type="\
process",description="[kworker/0:2]",user="root",cores=["0"]},{id="5073",type="process",description=\
"[kworker/2:1]",user="root",cores=["2"]},{id="5428",type="process",description="gdb --interpreter mi\
2 --nx",user="mike",cores=["2"]},{id="5443",type="process",description="/home/mike/Bitwise BACKUP (c\
opy)/Bitwise/Linux/Bitwise",user="mike",cores=["1"]},{id="6490",type="process",description="/usr/lib\
/dconf/dconf-service",user="mike",cores=["0","1","3"]},{id="8319",type="process",description="dbus-l\
aunch --autolaunch=6c8911fe4bcb6e2acadc1c3400000007 --binary-syntax --close-stderr",user="root",core\
s=["3"]},{id="8320",type="process",description="//bin/dbus-daemon --fork --print-pid 5 --print-addre\
ss 7 --session",user="root",cores=["2"]},{id="8326",type="process",description="/usr/lib/dconf/dconf\
-service",user="root",cores=["0","3"]},{id="8343",type="process",description="/usr/bin/zeitgeist-dae\
mon",user="root",cores=["2","3"]},{id="8349",type="process",description="/usr/lib/zeitgeist/zeitgeis\
t-fts",user="root",cores=["2"]},{id="8351",type="process",description="zeitgeist-datahub",user="root\
",cores=["2"]},{id="8357",type="process",description="/bin/cat",user="root",cores=["2"]},{id="8359",\
type="process",description="/usr/lib/gvfs/gvfsd",user="root",cores=["2"]},{id="8361",type="process",\
description="/usr/lib/gvfs//gvfs-fuse-daemon -f /root/.gvfs",user="root",cores=["1","3"]},{id="8507"\
,type="process",description="/usr/lib/gvfs/gvfsd-network --spawner :1.10 /org/gtk/gvfs/exec_spaw/3",\
user="mike",cores=["1","2"]},{id="8516",type="process",description="/usr/lib/gvfs/gvfsd-dnssd --spaw\
ner :1.10 /org/gtk/gvfs/exec_spaw/5",user="mike",cores=["0"]},{id="8883",type="process",description=\
"[jbd2/sdc5-8]",user="root",cores=["1"]},{id="8884",type="process",description="[ext4-dio-unwrit]",u\
ser="root",cores=["1"]},{id="8903",type="process",description="/sbin/mount.ntfs /dev/sdc1 /media/E -\
o rw,nosuid,nodev,uhelper=udisks,uid=1000,gid=1000,dmask=0077,fmask=0177",user="root",cores=["0"]},{\
id="10190",type="process",description="/usr/lib/xfce4/xfconf/xfconfd",user="mike",cores=["1"]},{id="\
15230",type="process",description="/usr/lib/gvfs/gvfsd-computer --spawner :1.10 /org/gtk/gvfs/exec_s\
paw/6",user="mike",cores=["0"]},{id="15572",type="process",description="/usr/lib/geoclue/geoclue-mas\
ter",user="mike",cores=["3"]},{id="15574",type="process",description="/usr/lib/ubuntu-geoip/ubuntu-g\
eoip-provider",user="mike",cores=["2","3"]},{id="15596",type="process",description="/usr/lib/gvfs/gv\
fsd-http --spawner :1.10 /org/gtk/gvfs/exec_spaw/8",user="mike",cores=["2","3"]},{id="30897",type="p\
rocess",description="/home/mike/Desktop/eclipse/eclipse",user="mike",cores=["0","1","2","3"]}]
809,247 28-list-thread-groups
809,248 (gdb)
809,248 28^done,groups=[{id="i1",type="process",pid="5443",executable="/home/mike/Bitwise BACKUP (co\
py)/Bitwise/Linux/Bitwise",cores=["1"]}]
809,248 (gdb)
809,269 29-list-thread-groups i1
809,270 29^done,threads=[{id="1",target-id="Thread 0xb572ea40 (LWP 5443)",name="Bitwise",frame={leve\
l="0",addr="0x0806e75f",func="main",args=[{name="mn",value="1"},{name="arg",value="0xbffff374"}],fil\
e="../src/Bitwise.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bitwise.cpp",line="117\
"},state="stopped",core="1"}]
809,271 (gdb)
809,284 30-stack-info-depth --thread 1 11
809,284 30^done,depth="1"
809,284 (gdb)
809,327 31-list-thread-groups
809,327 32-thread-info 1
809,328 31^done,groups=[{id="i1",type="process",pid="5443",executable="/home/mike/Bitwise BACKUP (co\
809,329 (gdb)
809,332 32^done,threads=[{id="1",target-id="Thread 0xb572ea40 (LWP 5443)",name="Bitwise",frame={leve\
809,333 (gdb)
810,529 33-exec-continue --thread 1
810,530 33^running
810,530 *running,thread-id="all"
810,530 (gdb)
810,597 =library-loaded,id="/usr/lib/i386-linux-gnu/libXcursor.so.1",target-name="/usr/lib/i386-linu\
x-gnu/libXcursor.so.1",host-name="/usr/lib/i386-linux-gnu/libXcursor.so.1",symbols-loaded="0",thread\
-group="i1"
810,597 =library-loaded,id="/usr/lib/i386-linux-gnu/libXfixes.so.3",target-name="/usr/lib/i386-linux\
-gnu/libXfixes.so.3",host-name="/usr/lib/i386-linux-gnu/libXfixes.so.3",symbols-loaded="0",thread-gr\
oup="i1"
810,837 *stopped,reason="signal-received",signal-name="SIGSEGV",signal-meaning="Segmentation fault",\
frame={addr="0xb7f4ccd4",func="sf::Font::GetCharacterSize() const",args=[],from="/usr/lib/SFML/libsf\
ml-graphics.so.1.6"},thread-id="1",stopped-threads="all",core="2"
810,838 (gdb)
810,864 34-stack-info-depth --thread 1 11
810,864 35-thread-info 1
811,062 34^done,depth="10"
811,063 (gdb)
811,065 35^done,threads=[{id="1",target-id="Thread 0xb572ea40 (LWP 5443)",name="Bitwise",frame={leve\
l="0",addr="0xb7f4ccd4",func="sf::Font::GetCharacterSize() const",args=[],from="/usr/lib/SFML/libsfm\
l-graphics.so.1.6"},state="stopped",core="2"}]
811,066 (gdb)
811,104 36-stack-list-frames --thread 1 1 3
811,105 36^done,stack=[frame={level="1",addr="0xb7f5ace9",func="sf::String::Render(sf::RenderTarget&\
) const",from="/usr/lib/SFML/libsfml-graphics.so.1.6"},frame={level="2",addr="0xb7f4cc5c",func="sf::\
Drawable::Draw(sf::RenderTarget&) const",from="/usr/lib/SFML/libsfml-graphics.so.1.6"},frame={level=\
"3",addr="0xb7f57c90",func="sf::RenderTarget::Draw(sf::Drawable const&)",from="/usr/lib/SFML/libsfml\
-graphics.so.1.6"}]
811,105 (gdb)
811,266 37-stack-list-frames --thread 1
811,266 38-list-thread-groups
811,270 37^done,stack=[frame={level="0",addr="0xb7f4ccd4",func="sf::Font::GetCharacterSize() const",\
from="/usr/lib/SFML/libsfml-graphics.so.1.6"},frame={level="1",addr="0xb7f5ace9",func="sf::String::R\
ender(sf::RenderTarget&) const",from="/usr/lib/SFML/libsfml-graphics.so.1.6"},frame={level="2",addr=\
"0xb7f4cc5c",func="sf::Drawable::Draw(sf::RenderTarget&) const",from="/usr/lib/SFML/libsfml-graphics\
.so.1.6"},frame={level="3",addr="0xb7f57c90",func="sf::RenderTarget::Draw(sf::Drawable const&)",from\
="/usr/lib/SFML/libsfml-graphics.so.1.6"},frame={level="4",addr="0x08070403",func="B_BasicString::Dr\
aw",file="../Source/Text/BBasicString.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/BGui/Source/Te\
xt/BBasicString.cpp",line="101"},frame={level="5",addr="0x08075c37",func="B_BasicPanel::Draw",file="\
../Source/Panels/BBasicPanel.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/BGui/Source/Panels/BBas\
icPanel.cpp",line="170"},frame={level="6",addr="0x08079912",func="BUICore::RenderCore",file="../Sour\
ce/BUICore.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/BGui/Source/BUICore.cpp",line="98"},frame\
={level="7",addr="0x08072aa0",func="BUI_PerformCoreDraw",file="../Source/System/BGUI.cpp",fullname="\
/home/mike/Bitwise BACKUP (copy)/BGui/Source/System/BGUI.cpp",line="99"},frame={level="8",addr="0x08\
06fc56",func="DisplayHandle",file="../src/Bitwise.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/Bi\
twise/src/Bitwise.cpp",line="219"},frame={level="9",addr="0x0806f599",func="main",file="../src/Bitwi\
se.cpp",fullname="/home/mike/Bitwise BACKUP (copy)/Bitwise/src/Bitwise.cpp",line="205"}]
811,270 (gdb)
811,271 38^done,groups=[{id="i1",type="process",pid="5443",executable="/home/mike/Bitwise BACKUP (co\
py)/Bitwise/Linux/Bitwise",cores=["2"]}]
811,271 (gdb)
811,327 39-stack-list-frames --thread 1 0 3
811,329 39^done,stack=[frame={level="0",addr="0xb7f4ccd4",func="sf::Font::GetCharacterSize() const",\
="/usr/lib/SFML/libsfml-graphics.so.1.6"}]
811,330 (gdb)
811,977 40-gdb-exit
811,981 40^exit
811,995 =thread-exited,id="1",group-id="i1"
811,995 =thread-group-exited,id="i1"
812,011 41-data-evaluate-expression $_exitcode
It also shows some "Red" text in the console window about not being able to find some files.
Is there a way I can re-nable it?
Re: Debugger isn't working [message #1084899 is a reply to message #1084514] Mon, 12 August 2013 03:36 Go to previous messageGo to next message
The debugger tries to set the breakpoint in the file "/home/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp" which does not exist.
Did you open the wrong file in the editor and set the breakpoint there?
Re: Debugger isn't working [message #1084920 is a reply to message #1084899] Mon, 12 August 2013 04:10 Go to previous messageGo to next message
Well according to my system when I type in "/home/mike/Bitwise BACKUP/Bitwise/src/BLevelProcessor.cpp" within terminal the source file does exist. Unless it's reading the wrong path, because the the folder has been backed up and renamed.
I got it work with breakpoints on the same project files, but now the issue when I go to debug an object instance from a library it gives me "no source file" and the debugger then exits.
The breakpoints will run all the way up to the object from one of my libraries, then it stops and the program exits. However,it runs normally without the debugger enabled.
Eclipse's Indexer can't find the Libraries source files, so it gives me a bunch of warnings about "Unable to resolve <file>.h" and the functions don't seem to be recognized, but the code compiles fine. Even after I rebuild the index.
By setting absolute paths into the CPP file, eclipse is able to recognize the functions and definitions. The Debugger is now working, but I would really like to have the path within the workspace and not the absolute path in the system.
The Include Paths for BGUI are defined in the C++ Build Settings.
This works:
#ifdef linux
	#include "/home/mike/Bitwise/BGui/Include/BUI_System/BGUI.h"
	#include "/home/mike/Bitwise/BGui/Include/BUI_Misc/BBasicImage.h"
	#include "/home/mike/Bitwise/BGui/Include/BUI_System/BUICommands.h"
	#include "/home/mike/Bitwise/BGui/Include/BUI_Buttons/BBasicCheckBox.h"
	#include "/home/mike/Bitwise/BGui/Include/BUIControl.h"
	#include "/home/mike/Bitwise/BGui/Include/BUI_Buttons/BBasicButton.h"
	#include "/home/mike/Bitwise/BGui/Include/BUI_Panels/BBasicPanel.h"
	#include "/home/mike/Bitwise/BGui/Include/BUI_Text/BBasicString.h"
#else
#endif
This doesn't:
	#include "BUI_System/BGUI.h"
	#include "BUI_Misc/BBasicImage.h"
	#include "BUI_System/BUICommands.h"
	#include "BUI_Buttons/BBasicCheckBox.h"
	#include "BUIControl.h"
	#include "BUI_Buttons/BBasicButton.h"
	#include "BUI_Panels/BBasicPanel.h"
	#include "BUI_Text/BBasicString.h"
[Updated on: Mon, 12 August 2013 04:57] by Moderator
Re: Debugger isn't working [message #1085029 is a reply to message #1084920] Mon, 12 August 2013 07:02 Go to previous messageGo to next message
Well, the file does exist on the harddisk but the application was build with a different file (I guess not from backup). So the debug info is different and the debugger will not recognize the file. If you want to use a different path you have to configure path settings in the Debug Launch Configuration.
.. but now the issue when I go to debug an object instance from a library it gives me "no source file" and the debugger then exits.
Anything in the gdb traces console?
Re: Debugger isn't working [message #1085064 is a reply to message #1085029] Mon, 12 August 2013 07:57 Go to previous message
The debugger itself is working fine now. The issue was indeed the path, when I backed up the previous versions I didn't leave it at the original workspace, but I named it to something else. Instead I used the backup folder which had to have it's settings reset in order for the debugger to properly read the source files.
The issue now however, is not the debugger, but the includes. Even though Eclipse has the settings stored in the C++ Includes within the Project's C++ Build Settings, to a local library's include folder(inside the workspace itself).
It complains it cannot find the files, so when I go to look up the functions/declarations it doesn't know them. If I assign an absolute path from the root of the drive, it works, if I just tell it to use the BUI_<folder> it does not even though it's told to read the files within the BGui/Include/ folder.
Previous Topic:included C++11 flag but still getting code errors
Next Topic:Error in final launch sequence Failed to execute MI command
Current Time: Sun Jun 01 12:37:10 EDT 2025
Powered by FUDForum. Page generated in 0.23570 seconds
