Home » Modeling » TMF (Xtext) » Appending string AND XEpression to body of method
Appending string AND XEpression to body of method [message #1082449] Thu, 08 August 2013 11:22 Go to next message
I want to generate the body of a method.
val ofunctionMethod = function.toMethod(name, returntype) [
body = op.body //op comes from somewhere above and op.body is an XExpression
What I want to do is
generate a method with in its body:
1) some fixed code: "String example = 2"
2) op.body (XExpression)
I've looked at examples that create a CompilationStrategy
body =  [it.append("String example = 2")]
But even when looking at the java files of this piece of code (eg: I know the code is expanded to Procedure1<ITreeIterator> etc>
I can't figure out how to append my XExpression to the body (if I first append the fixed code)
Any hints are appreciated
Update:
Currently I'm looking at NodeModelUtils to convert my XExpression to a string
and then append it.
Update:
Which is of course completely useless to my because it the code from the parse tree. (I need the compiled files (to java))
Update:
I am thinking of using XBaseCompiler to compile my XExpression to a string and then append it
Cheers
[Updated on: Thu, 08 August 2013 11:46] by Moderator
Re: Appending string AND XEpression to body of method [message #1082676 is a reply to message #1082449] Thu, 08 August 2013 18:49 Go to previous messageGo to next message
The last one may work, inject a compiler for it then use that to generate the output.
@Inject XbaseCompiler xbc
  body =  [ append('''String example = 2''')
	    xbc.compile(op.body, it, element.newTypeRef('void'))
(or something like that)
Re: Appending string AND XEpression to body of method [message #1082890 is a reply to message #1082676] Fri, 09 August 2013 02:57 Go to previous messageGo to next message
Hi.
I was trying something like that yes:
@Inject XbaseCompiler _compiler
body = [it.append('int x = 1;\n') _compiler.compile(op.body,it, op.newTypeRef(OMatrix))]
But I get errors much like in this forum post:
http://www.eclipse.org/forums/index.php/t/489735/
	at org.eclipse.xtext.xbase.compiler.TypeReferenceSerializer.serialize(TypeReferenceSerializer.java:90)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:342)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:338)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:334)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.appendVariableTypeAndName(XbaseCompiler.java:676)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:656)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:454)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.internalToJavaStatement(AbstractXbaseCompiler.java:297)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:485)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:430)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compile(AbstractXbaseCompiler.java:236)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compile(AbstractXbaseCompiler.java:107)
	at olang.jvmmodel.OlangJvmModelInferrer$5$1.apply(OlangJvmModelInferrer.java:251)
	at olang.jvmmodel.OlangJvmModelInferrer$5$1.apply(OlangJvmModelInferrer.java:1)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateExecutableBody(JvmModelGenerator.java:1101)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:873)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1880)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:288)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:1)
	at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
	at org.eclipse.xtext.xbase.compiler.LoopExtensions$1.apply(LoopExtensions.java:39)
	at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
	at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:42)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:292)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1852)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:211)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:202)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1835)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:183)
	at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:299)
	at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:229)
	at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:186)
	at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:162)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: Appending string AND XEpression to body of method [message #1082989 is a reply to message #1082890] Fri, 09 August 2013 05:59 Go to previous messageGo to next message
My code example was from an older version with Xtext 2.3 where it did work but I dropped that functionality and then later migrated to 2.4 so I haven't tried it under this version. That post seems to show different behaviour with 2.4
On the other hand, I don't know what's in your XExpression or if the OMatrix type has errors. Try a simple expression of '1' and hard code typeref of 'int' (which works), and then gradually change it till it fails and post back again.
Re: Appending string AND XEpression to body of method [message #1084211 is a reply to message #1082676] Sun, 11 August 2013 01:53 Go to previous messageGo to next message
in my experience, calling the xbase compiler directly in the compilation
strategy does not seem to work anymore in 2.4 ... I managed to achieve
the same result using a custom xbase compiler
(http://www.eclipse.org/forums/index.php/t/499616/)
from what I understand calling the xbase compiler directly does not work
because the xbase expression would not be processed by the new type
computer (see http://www.eclipse.org/forums/index.php/t/502103/ where I
got no answer though).
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Re: Appending string AND XEpression to body of method [message #1084952 is a reply to message #1084211] Mon, 12 August 2013 04:53 Go to previous messageGo to next message
It works great! I implemented my own extension to XBaseCompiler as you said and generated. I must say that I don't quite understand yet *why* it works..
nevertheless thanks!
Re: Appending string AND XEpression to body of method [message #1085082 is a reply to message #1084952] Mon, 12 August 2013 08:30 Go to previous message
> it works..
glad to know it works :)
from what I understand, with the new type system of 2.4 (which is rather
cool! :), the typing of expressions is dealt with by the framework when
you give an Xbase expression a logical container. That is why you must
do something like
body = o.body
in the inferrer.
If you don't do that, the Xbase expressions will not be typed.
So if you need to customize the compilation of Xbase expressions you
must provide a custom XbaseCompiler, and not manually use the
XbaseCompiler in a compilation strategy...
At least, that's how I understand it :)
cheers
Lorenzo
Previous Topic:Can you manipulate the AST (ECore model) (XExpression) to add and edit code
Next Topic:Recursive import of references
Current Time: Fri Sep 19 07:11:18 EDT 2025
Powered by FUDForum. Page generated in 0.04833 seconds
