Home » Eclipse Projects » Equinox » [p2] Re: any way to have the batch build generate the p2 descriptor files?
[p2] Re: any way to have the batch build generate the p2 descriptor files? [message #108363] Thu, 17 April 2008 15:14 Go to next message
Originally posted by: zx.us.ibm.com
This question is better for the Equinox newsgroup.
Francis Upton wrote:
> Sorry for not looking at the code and trying to figure this out myself,
> but I thought maybe someone would have a quick answer.
> I use the PDE build scripts and have not changed them for 3.4, I notice
> that in my generated products there is nothing p2 related. The
> generated apps work just fine.
> However, I want to actually generate the p2 file that says what's to be
> used, because for one of my products I want to withhold a plugin
> (because that plugin will be in the application's class path in order
> for me to expose it as an API to the application). (I also need to
> figure out a way to tell p2 which of these p2 files to use on startup --
> I'm using EclipseStarter, so I assume there is some property that I can
> set for this).
> Can the automated build generate this file somehow? Or is there a
> better way to solve this problem short of creating an entirely separate
> product with it's own copy of everything?
> Francis
Re: [p2] Re: any way to have the batch build generate the p2 descriptor files? [message #108413 is a reply to message #108363] Mon, 21 April 2008 06:31 Go to previous messageGo to next message
Well I figured out how to teach the headless build how to do to this,
and then realized the approach was completely wrong. The bundles.info
file really needs to be generated in-sutu at the first startup because
it actually has the paths to the bundles, so it's not something that can
be done at generation time.
I imagine that I could use some kind of more sophisticated p2
configurator to be able to withhold a bundle given a particular
execution, but I think I will hold off on this for the time being until
p2 gets further along.
In the meantime I will just create a different product (and thus
installation) for the case where I need to have the one plugin withheld.
Unless someone has a better idea.
Francis
>> myself, but I thought maybe someone would have a quick answer.
>> notice that in my generated products there is nothing p2 related. The
>> be used, because for one of my products I want to withhold a plugin
>> -- I'm using EclipseStarter, so I assume there is some property that I
>> can set for this).
>> separate product with it's own copy of everything?
>> Thanks,
>> Francis
Re: [p2] Re: any way to have the batch build generate the p2 descriptor files? [message #108439 is a reply to message #108363] Mon, 21 April 2008 13:41 Go to previous message
The current pde.build integration with p2 works as follows:
1) Make sure the p2.metadata.generator bundle & its dependencies exist in the build.
2) Set the property "generate.p2.metadata=true"
3) Set the following properties as appropriate:
p2.metadata.repo = file:${buildDirectory}/repo
p2.artifact.repo = file:${buildDirectory}/repo
p2.flavor = tooling
p2.publish.artifacts = true
and if you are not using a .product file:
p2.root.name
p2.root.version
The expected result of this is a p2 repo from which you can then install your stuff.
The build does not generate the bundle.info file that lists what plugins are to
be used. That is generated as part of the install operation. I don't know if
there is any way to switch between 2 such files other than perhaps having 2
different config directories in your product.
-Andrew
>> can set for this).
>> Thanks,
>> Francis
Previous Topic:P2 profile creation problem
Next Topic:P2: "No repository found at..." for local eclipse installation
Current Time: Fri Jul 25 21:43:33 EDT 2025
Powered by FUDForum. Page generated in 0.25107 seconds
