Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Temporality][CDO][Teneo]Delegating EStore and Root extends class
[Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #108304] Fri, 25 January 2008 16:29 Go to next message
I would like to open a discussion on the topic of sharing hook points into
the EStore and the Root extends class.
As you may already know if two features say CDO and Temporality are to be
used simultaneously we need to agree on a way to chain EStores.
Also we need figure out what to do about the Root extends class.
I believe Temporality could be all implemented from an EStore as long as the
following events are added to the EStore interface.
- creation event (the EObject is being instantiated.)
- get/set containment
Here's a document sketching out a possible solution for delegating EStores:
http://wiki.eclipse.org/images/a/ad/Delegatingestore.pdf
Here's a description of the Temporality project:
http://www.eclipse.org/modeling/emft/?project=temporality
Eike already opened a bug regarding the issue of delegating EStores:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197487
I will have a look at the CDO implementation to get a better understanding
of how it hooks itself in EMF.
Jean-Claude
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #108326 is a reply to message #108304] Sat, 26 January 2008 04:33 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
--------------050303060002020302090607
Hi Jean-Claude,
Comments below...
jc schrieb:
The EStore interface has a
| *public *EObject create(EClass eClass);|
But I could never figure out who/what/when is expected to call it. My
store implementation just throws an UOE. If an EStore represents some
sort of persistence container that is associated with a set of
*persistent* objects (i.e. a Resource or a ResourceSet) then I believe
that object creation always occurs outside of this container in a first
stage, i.e. object creation is always a *transient* operation. These
transient objects can only become persistent when they are added to
containment references of objects that are already persistent. With CDO
the persistent root objects are the Resources themselves (which really
implement EObject!).
So I even don't have an idea what the semantics of EStore.create(EClass)
should be.
It is possible to derive these events from other events
(set/unset/add/remove) in combination with knowledge about the
underlying model (containment references). This is also the way CDO
implements EStore.
You should start with the classes CDOObjectImpl, CDOStore and
CDOStateMachine.
Please ask me if you need assistance ;-)
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
<html>
<head>
http-equiv="Content-Type">
</head>
Hi Jean-Claude,<br>
<br>
Comments below...<br>
<br>
<br>
jc schrieb:
<blockquote cite="mid:fndkc0$rfp$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
The EStore interface has a <br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #108388 is a reply to message #108326] Sat, 26 January 2008 08:48 Go to previous messageGo to next message
--------------090402000707010705080207
Eike,
Comments below.
Eike Stepper wrote:
> Hi Jean-Claude,
> Comments below...
> jc schrieb:
>> Hi,
> first stage, i.e. object creation is always a *transient* operation.
> These transient objects can only become persistent when they are added
> to containment references of objects that are already persistent. With
> CDO the persistent root objects are the Resources themselves (which
> really implement EObject!).
> EStore.create(EClass) should be.
This is one of the problems of defining an API without the direct
interaction with the associated users of the API. Given that a factory
typically creates things, it wasn't entirely obvious to me how this
ought to be used and given that it doesn't make so much sense for the
shared factory to be associated with only one store, it doesn't seem
terribly useful. Note that data graphs and data objects have create
methods and that the APIs were designed to support folks who were
implementing some lazy SDO stuff, so likely they hooked the data graph
to a store could funnel all creation to that store.
> implements EStore.
Yes, change in containers is implicit in changes to containment references.
> CDOStateMachine.
I think Eike's done a great job building a meaningful implementation
around these APIs. It's interesting how he's got it set up to use a
dynamic type of implementation to back the data until the object becomes
associated with a store and at that point the data is transferred over.
Very innovative...
> Regards,
> Eike Stepper
<html>
<head>
</head>
Eike,<br>
<br>
Comments below.<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid:fneupe$5ft$1@build.eclipse.org" type="cite">
Hi Jean-Claude,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
</pre>
</blockquote>
<title></title>
</style>
<meta http-equiv="Content-Type" content="text/html; ">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = --><!-- = Further information: http://www.java2html.de = -->
<tbody>
<tr>
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #108620 is a reply to message #108304] Mon, 28 January 2008 08:29 Go to previous messageGo to next message
Hi JC,
I'm very interested in your project.
I'm using CDO right now and I played with your project as well.
Unfortunately, like you mention, it is kind of incompatible.
It will be fantastic if both of you could come up with a solution to be able
to use both at the same time.
I'm not sure (do not remember) if CDO assume to retrieve it's EStore from
eObject.eStore().
If yes.. it will be almost the only modification.
Simon
"jc" <jccote@gmail.com> wrote in message
news:fndkc0$rfp$1@build.eclipse.org...
> the following events are added to the EStore interface.
> EStores:
> Thanks
> Jean-Claude
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #110500 is a reply to message #108388] Wed, 30 January 2008 10:05 Go to previous messageGo to next message
Hi Eike,
As I suspected you have the same hooks in your CDOObjectImpl base class
(Root Implements Class) as I do in my base class TemporalBaseEObjectImpl.
That is you trap getting/setting the container and creation.
creation
private static final ContextTracer TRACER = new
ContextTracer(OM.DEBUG_OBJECT, CDOObjectImpl.class);
public CDOObjectImpl()
state = CDOState.TRANSIENT;
eContainer = null;
no caching
* Don't cache non-transient features in this CDOObject's {@link
#eSettings()}.
protected boolean eIsCaching()
return false;
getting/setting container
public InternalEObject eInternalContainer()
// Delegate to CDOStore
container = getStore().getContainer(this);
protected void eBasicSetContainer(InternalEObject newContainer, int
newContainerFeatureID)
getStore().setContainer(this, newContainer, newContainerFeatureID);
In CDOStore you added a setContainer method, in here you pass the request to
the correct version:
public void setContainer(InternalEObject eObject, InternalEObject
newContainer, int newContainerFeatureID)
InternalCDOObject cdoObject = getCDOObject(eObject);
if (TRACER.isEnabled())
TRACER.format("setContainer({0}, {1}, {2})", cdoObject, newContainer,
CDOID containerID =
(CDOID)((CDOViewImpl)cdoObject.cdoView()).convertObjectToID( newContainer);
CDOFeatureDelta delta = new CDOContainerFeatureDeltaImpl(containerID,
InternalCDORevision revision = getRevisionForWriting(cdoObject, delta);
revision.setContainerID(containerID);
revision.setContainingFeatureID(newContainerFeatureID);
public InternalEObject getContainer(InternalEObject eObject)
TRACER.format("getContainer({0})", cdoObject);
InternalCDORevision revision = getRevisionForReading(cdoObject);
CDOID id = revision.getContainerID();
return
(InternalEObject)((CDOViewImpl)cdoObject.cdoView()).convertI DToObject(id);
I did the same thing in TemporalBaseEObjectImpl, except that I'm not passing
it to my EStore however I could have. But the idea is the same. I trap
containment getting and setting and handle them.
creation
public TemporalBaseEObjectImpl(EClass eClass) {
super(eClass, new TemporalEStoreImpl(new EStoreEObjectImpl.EStoreImpl()));
TemporalUtil.initTemporal(this);
no caching
* Overriden to prevent base class from caching the values returned from
the EStore.
* We want to be able to control the retrieval of data through the getters.
protected boolean eIsCaching(){
return false;
* JCC: added this to support versioning of containment features.
* To version the containment reference we need to hook into the setter for
it.
* This method is overriden to give us access to the setting of the
containment reference.
* What this method does is try to find a version to delegate this setter
to. If a version
* is found it delegates the setter to it. If this is the version on which
it should be
* performed it does not delegate (it passes the request to its base class).
public NotificationChain eBasicSetContainer(InternalEObject newContainer,
int newContainerFeatureID,
NotificationChain msgs) {
if (((TemporalEStoreImpl) this.eStore()).isBypass() == false) {
InternalEObject version =
TemporalEStoreHandler.findVersionToDelegateMutatorTo(this, null);
if (version != null) {
return version.eBasicSetContainer(newContainer, newContainerFeatureID,
msgs);
return super.eBasicSetContainer(newContainer, newContainerFeatureID, msgs);
* To version the containment reference we need to hook into the getter for
it.
* This method is overriden to give us access to the getter of the
* What this method does is try to find a version to delegate this getter
to. If a version
* is found it delegates the getter to it. If this is the version on which
it should be
public InternalEObject eInternalContainer() {
TemporalEStoreHandler.findVersionToDelegateAccessorTo(this, null);
return version.eInternalContainer();
return super.eInternalContainer();
Since we have the same requirements we should try to come up with a new
EStore interface with the added setContainer and construction methods.
We should also establish a common base class that can be parametize to have
CDO or Temporality or (Temporality and CDO). Ideally it should also handle
Teneo however I don't know much about the base class used in Teneo.
Thoughts?
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fnfdmu$105$1@build.eclipse.org...
Eike,
Comments below.
Eike Stepper wrote:
Hi Jean-Claude,
Comments below...
public EObject create(EClass eClass);
But I could never figure out who/what/when is expected to call it. My store
implementation just throws an UOE. If an EStore represents some sort of
persistence container that is associated with a set of *persistent* objects
(i.e. a Resource or a ResourceSet) then I believe that object creation
always occurs outside of this container in a first stage, i.e. object
creation is always a *transient* operation. These transient objects can only
become persistent when they are added to containment references of objects
that are already persistent. With CDO the persistent root objects are the
Resources themselves (which really implement EObject!).
should be.
typically creates things, it wasn't entirely obvious to me how this ought to
be used and given that it doesn't make so much sense for the shared factory
to be associated with only one store, it doesn't seem terribly useful. Note
that data graphs and data objects have create methods and that the APIs were
designed to support folks who were implementing some lazy SDO stuff, so
likely they hooked the data graph to a store could funnel all creation to
that store.
(set/unset/add/remove) in combination with knowledge about the underlying
model (containment references). This is also the way CDO implements EStore.
CDOStateMachine.
I think Eike's done a great job building a meaningful implementation around
these APIs. It's interesting how he's got it set up to use a dynamic type
of implementation to back the data until the object becomes associated with
a store and at that point the data is transferred over. Very innovative...
Eike Stepper
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #110641 is a reply to message #110500] Wed, 30 January 2008 10:46 Go to previous messageGo to next message
Hi JC,
I think there are two intersting areas where we could contribute to EMF:
1) Provide a subclass of EStoreEObjectImpl that can delegate to
different EStore implementations so that the user/developer doesn't need
to exclusively choose in the genmodel. I must add that I see
degradations in performance and memory usage when I have to pull my
additional object state out of adapters...
2) Provide a stateless implementation of EStore that factors out the
handling of attach/detach due to containment references.
IMHO these areas are not depending on each other.
Is that what you propose?
Eike Stepper
jc schrieb:
> Hi Eike,
> creation
> eContainer = null;
> no caching
> #eSettings()}.
> @Override
> return false;
> CDOID containerID =
> return
> creation
> no caching
> the EStore.
> return false;
> it.
> to. If a version
> it should be
> msgs);
> it.
> to. If a version
> it should be
> Thoughts?
> Eike,
> Comments below.
> Eike Stepper wrote:
> Hi Jean-Claude,
> Comments below...
> jc schrieb:
> should be.
> that store.
> CDOStateMachine.
> Regards,
> Eike Stepper
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #111913 is a reply to message #110641] Fri, 08 February 2008 09:17 Go to previous messageGo to next message
Essentially yes.
I think both of these strategies are missing and would be an asset to EMF.
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:fnq658$qa8$17@build.eclipse.org...
> Hi JC,
> 1) Provide a subclass of EStoreEObjectImpl that can delegate to different
> EStore implementations so that the user/developer doesn't need to
> exclusively choose in the genmodel. I must add that I see degradations in
> performance and memory usage when I have to pull my additional object
> Regards,
> Eike Stepper
> jc schrieb:
>> Hi Eike,
>> creation
>> eContainer = null;
>> no caching
>> #eSettings()}.
>> @Override
>> return false;
>> to the correct version:
>> CDOID containerID =
>> delta);
>> return
>> passing it to my EStore however I could have. But the idea is the same. I
>> trap containment getting and setting and handle them.
>> creation
>> no caching
>> the EStore.
>> getters.
>> return false;
>> for it.
>> to. If a version
>> which it should be
>> class).
>> msgs);
>> msgs);
>> for it.
>> to. If a version
>> which it should be
>> class).
>> have CDO or Temporality or (Temporality and CDO). Ideally it should also
>> handle Teneo however I don't know much about the base class used in
>> Teneo.
>> Thoughts?
>> Eike,
>> Comments below.
>> Eike Stepper wrote:
>> Hi Jean-Claude,
>> Comments below...
>> jc schrieb:
>> Hi,
>> into
>> the
>> should be.
>> to be used and given that it doesn't make so much sense for the shared
>> factory to be associated with only one store, it doesn't seem terribly
>> useful. Note that data graphs and data objects have create methods and
>> that the APIs were designed to support folks who were implementing some
>> lazy SDO stuff, so likely they hooked the data graph to a store could
>> EStore.
>> references.
>> EStores:
>> understanding
>> CDOStateMachine.
>> Very innovative...
>> Regards,
>> Eike Stepper
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #111914 is a reply to message #108620] Fri, 08 February 2008 10:10 Go to previous message
Hi Simon,
CDOObjectImpl doesn't use the field
org.eclipse.emf.ecore.impl.EStoreEObjectImpl.eStore and it hopes that this
field gets removed (moved to a subclass). I think there's a Bugzilla for
this somewhere...
CDOObjectImpl uses the following approach:
private CDOStore getStore()
return cdoView().getStore();
I think the main problem with combining Jean-Claudes' and my framework is
the fact that you can only specify one class name in the genmodel for
"Root Extends Class". And of course an instance can have only one class
;-) Either solution for a more cooperative behaviour would have a negative
impact on footprint and performance...
Cheers
/Eike
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #614092 is a reply to message #108304] Sat, 26 January 2008 04:33 Go to previous message
Hi Jean-Claude,
Comments below...
jc schrieb:
should be.
implements EStore.
CDOStateMachine.
Eike Stepper
<html>
<head>
</head>
Hi Jean-Claude,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
</pre>
</blockquote>
<title></title>
</style>
<tbody>
<tr>
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #614096 is a reply to message #108326] Sat, 26 January 2008 08:48 Go to previous message
Eike,
Comments below.
Eike Stepper wrote:
> Hi Jean-Claude,
> Comments below...
> jc schrieb:
>> Hi,
> implements EStore.
> CDOStateMachine.
Very innovative...
> Regards,
> Eike Stepper
<html>
<head>
</head>
Eike,<br>
<br>
Comments below.<br>
<br>
Hi Jean-Claude,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
</pre>
</blockquote>
<title></title>
</style>
<tbody>
<tr>
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #614112 is a reply to message #108304] Mon, 28 January 2008 08:29 Go to previous message
Hi JC,
eObject.eStore().
Simon
> EStores:
> Thanks
> Jean-Claude
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #614345 is a reply to message #108388] Wed, 30 January 2008 10:05 Go to previous message
Hi Eike,
creation
eContainer = null;
no caching
#eSettings()}.
return false;
CDOID containerID =
return
creation
no caching
the EStore.
return false;
it.
to. If a version
it should be
msgs);
it.
to. If a version
it should be
Thoughts?
Eike,
Comments below.
Eike Stepper wrote:
Hi Jean-Claude,
Comments below...
should be.
that store.
CDOStateMachine.
Eike Stepper
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #614347 is a reply to message #110500] Wed, 30 January 2008 10:46 Go to previous message
Hi JC,
Eike Stepper
jc schrieb:
> Hi Eike,
> creation
> eContainer = null;
> no caching
> #eSettings()}.
> @Override
> return false;
> CDOID containerID =
> return
> creation
> no caching
> the EStore.
> return false;
> it.
> to. If a version
> it should be
> msgs);
> it.
> to. If a version
> it should be
> Thoughts?
> Eike,
> Comments below.
> Eike Stepper wrote:
> Hi Jean-Claude,
> Comments below...
> jc schrieb:
> should be.
> that store.
> CDOStateMachine.
> Regards,
> Eike Stepper
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #615463 is a reply to message #110641] Fri, 08 February 2008 09:17 Go to previous message
Essentially yes.
> Hi JC,
> Regards,
> Eike Stepper
> jc schrieb:
>> Hi Eike,
>> creation
>> eContainer = null;
>> no caching
>> #eSettings()}.
>> @Override
>> return false;
>> CDOID containerID =
>> delta);
>> return
>> creation
>> no caching
>> the EStore.
>> getters.
>> return false;
>> for it.
>> to. If a version
>> which it should be
>> class).
>> msgs);
>> msgs);
>> for it.
>> to. If a version
>> which it should be
>> class).
>> Teneo.
>> Thoughts?
>> Eike,
>> Comments below.
>> Eike Stepper wrote:
>> Hi Jean-Claude,
>> Comments below...
>> jc schrieb:
>> Hi,
>> into
>> the
>> should be.
>> EStore.
>> references.
>> EStores:
>> understanding
>> CDOStateMachine.
>> Very innovative...
>> Regards,
>> Eike Stepper
Re: [Temporality][CDO][Teneo]Delegating EStore and Root extends class [message #615464 is a reply to message #108620] Fri, 08 February 2008 10:10 Go to previous message
Hi Simon,
this somewhere...
Cheers
/Eike
Previous Topic:Making an EMF-Application extensible / non-standard way to access plug-in executableExtensions
Next Topic:Making an EMF-Application extensible / non-standard way to access plug-in executableExtensions
Current Time: Tue Jul 22 14:26:44 EDT 2025
Powered by FUDForum. Page generated in 0.05555 seconds
