[Solved] [EMF-IncQuery Project Builder] : Errors running builder 'EMF-IncQuery Project Builder' [message #1083155] |
Fri, 09 August 2013 10:55  |
Configuration [IncQuery 0.7, Xtext 2.3.1, Eclipse Indigo, emf.mwe.core 1.1.1]
I've just installed IncQuey and I am encountering errors on saving IncQuery pattern files.
I've checked that org/eclipse/emf/mwe/core/resources/ResourceLoader.class was in plugin/org.eclipse.emf.mwe.core_1.1.1.v201108020506.jar and checked that others projects are not affected by this error but I have the following errors for IncQuery project only in the error message window of eclipse.
Someone may help me ?
Thanks a lot
Sincerely yours
!ENTRY org.eclipse.core.resources 4 2 2013-08-09 16:45:33.163
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/emf/mwe/core/resources/ResourceLoader
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getDeclaredConstructors(Unknown Source)
at com.google.inject.spi.InjectionPoint.forConstructorOf(InjectionPoint.java:243)
at com.google.inject.internal.ConstructorBindingImpl.create(ConstructorBindingImpl.java:96)
at com.google.inject.internal.InjectorImpl.createUninitializedBinding(InjectorImpl.java:629)
at com.google.inject.internal.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:845)
at com.google.inject.internal.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:772)
at com.google.inject.internal.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:256)
at com.google.inject.internal.InjectorImpl.getBindingOrThrow(InjectorImpl.java:205)
at com.google.inject.internal.InjectorImpl.getInternalFactory(InjectorImpl.java:853)
at com.google.inject.internal.FactoryProxy.notify(FactoryProxy.java:46)
at com.google.inject.internal.ProcessedBindingData.runCreationListeners(ProcessedBindingData.java:50)
at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:133)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at org.eclipse.xtext.xtext.ui.internal.Activator.createInjector(Activator.java:67)
at org.eclipse.xtext.xtext.ui.internal.Activator.getInjector(Activator.java:55)
at org.eclipse.xtext.ui.XtextExecutableExtensionFactory.getInjector(XtextExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:40)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:1)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:40)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:75)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:91)
at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.isValidUri(Storage2UriMapperImpl.java:97)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.computeUriForStorageInJarOrExternalClassFolder(Storage2UriMapperJavaImpl.java:160)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.internalGetUri(Storage2UriMapperJavaImpl.java:90)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.getUri(Storage2UriMapperImpl.java:80)
at org.eclipse.xtext.ui.containers.AbstractStorage2UriMapperClient.getUri(AbstractStorage2UriMapperClient.java:27)
at org.eclipse.xtext.ui.containers.JavaProjectsStateHelper$1.handle(JavaProjectsStateHelper.java:85)
at org.eclipse.xtext.ui.containers.JavaProjectsStateHelper$1.handle(JavaProjectsStateHelper.java:1)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:98)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:86)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:64)
at org.eclipse.xtext.ui.containers.JavaProjectsStateHelper.initContainedURIs(JavaProjectsStateHelper.java:91)
at org.eclipse.xtext.ui.containers.JavaProjectsState.doInitContainedURIs(JavaProjectsState.java:32)
at org.eclipse.xtext.ui.containers.AbstractAllContainersState.initContainedURIs(AbstractAllContainersState.java:147)
at org.eclipse.xtext.ui.containers.AbstractAllContainersState.isEmpty(AbstractAllContainersState.java:143)
at org.eclipse.xtext.resource.containers.ContainerState.isEmpty(ContainerState.java:32)
at org.eclipse.xtext.resource.containers.StateBasedContainer.isEmpty(StateBasedContainer.java:72)
at org.eclipse.xtext.resource.containers.StateBasedContainerManager.getVisibleContainers(StateBasedContainerManager.java:88)
at org.eclipse.xtext.resource.containers.StateBasedContainerManager.getVisibleContainers(StateBasedContainerManager.java:55)
at org.eclipse.incquery.tooling.core.generator.builder.xmi.XmiModelSupport.internalBuild(XmiModelSupport.java:90)
at org.eclipse.incquery.tooling.core.generator.builder.xmi.XmiModelSupport.build(XmiModelSupport.java:72)
at org.eclipse.incquery.tooling.core.generator.builder.EMFPatternLanguageBuilderParticipant.build(EMFPatternLanguageBuilderParticipant.java:143)
at org.eclipse.incquery.tooling.ui.builder.IncQueryProjectBuilder.doBuild(IncQueryProjectBuilder.java:130)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:141)
at org.eclipse.incquery.tooling.ui.builder.IncQueryProjectBuilder.incrementalBuild(IncQueryProjectBuilder.java:109)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:91)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.mwe.core.resources.ResourceLoader
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 67 more
!ENTRY org.eclipse.core.resources 4 2 2013-08-09 16:45:33.584
!STACK 0
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:161)
... 67 more
!ENTRY org.eclipse.core.resources 4 75 2013-08-09 16:45:33.596
!MESSAGE Errors occurred during the build.
!SUBENTRY 1 org.eclipse.incquery.tooling.ui 4 75 2013-08-09 16:45:33.596
!MESSAGE Errors running builder 'EMF-IncQuery Project Builder' on project 'org.uml.val.Ada2005'.
!STACK 0
... 67 more
!SUBENTRY 1 org.eclipse.xtext.ui.shared 4 75 2013-08-09 16:45:33.596
!MESSAGE Errors running builder 'Xtext Project Builder' on project 'org.uml.val.Ada2005'.
!STACK 0
... 67 more
!ENTRY org.eclipse.core.jobs 4 2 2013-08-09 16:45:34.127
!MESSAGE An internal error occurred during: "Updating editor state".
!STACK 0
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.isAffected(DefaultResourceDescriptionManager.java:133)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport.isReparseRequired(DirtyStateEditorSupport.java:451)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob$1.exec(DirtyStateEditorSupport.java:125)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob$1.exec(DirtyStateEditorSupport.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport$UpdateEditorStateJob.run(DirtyStateEditorSupport.java:118)
... 56 more
[Updated on: Sat, 10 August 2013 07:45] by Moderator
FUDForum. Page generated in 0.04387 seconds
