Home » Archived » Test and Performance Tools Platform (TPTP) » AGR "thrashing"
AGR "thrashing" [message #107497] Fri, 03 August 2007 10:58 Go to next message
Hi All,
I used the AGR to call a menu item.
The menu item calls a class that implements IWorkbenchWindowActionDelegate.
This Delegate then instantiates a class that implements IWorkbenchAction.
The run method in this class displays a ProgressMonitorDialog and later
displays an ordinary Dialog that requests typed inputs from the user.
As soon as the Dialog is displayed, it "thrashes": it rapidly flashes
until I press the Cancel button. (I think that it is flashing between
the ProgressMonitorDialog ("progress bar") and the ordinary Dialog.
(This pattern works well in several existing plugins, it only causes a
problem in the AGR.)
The thrashing stops after I press "Cancel". Then I can type inputs into
the ordinary Dialog. The problem is the I can't run the Test after it
is recorded. It generates the following:
org.eclipse.core.CoreException
Line 41: The UI object with reference id 42 was not found
In advance, thanks for your help/suggestions.
Charlie
Re: AGR "thrashing" [message #107573 is a reply to message #107497] Sun, 05 August 2007 04:40 Go to previous messageGo to next message
Hi.
Occasionally I also get the "thrashing effect" that you are mentioning,
Charlie, but only in recoding mode.
In my case the dialogs that are flashing are one of my own dialogs,
extensions of JFace Dialog, and the AGR control box. The rapid
flickering of both boxes starts as soon as the JFace based dialog box is
produced and it eventually subsides, allowing me to continue with my
recording.
Nothing untoward is generated in either the test script or the object
mine and the test case be played back successfully.
The funny thing is that it does not happen *every* time one of my
dialogs is displayed.
Any idea anyone what the problem might be?
TIA,
B.
Charlie Kelly wrote:
> Hi All,
> Charlie
Re: AGR "thrashing" [message #107682 is a reply to message #107497] Tue, 07 August 2007 08:03 Go to previous messageGo to next message
Hi Charlie,
What OS are you recording and playing?
Paul
"Charlie Kelly" <Eclipse@CharlieKelly.com> wrote in message
news:f8vfqt$dvm$1@build.eclipse.org...
> Hi All,
> until I press the Cancel button. (I think that it is flashing between the
> the ordinary Dialog. The problem is the I can't run the Test after it is
> Charlie
Re: AGR "thrashing" [message #107695 is a reply to message #107682] Tue, 07 August 2007 09:28 Go to previous messageGo to next message
Hi Paul,
Windows XP.
Charlie
Paul Slauenwhite wrote:
> Hi Charlie,
> Paul
>> Hi All,
>> Charlie
Re: AGR "thrashing" [message #107709 is a reply to message #107573] Tue, 07 August 2007 09:31 Go to previous messageGo to next message
Hi Barbara,
The thrashing starts when my dialog is display; but it doesn't subside.
Charlie
Barbara Rosi-Schwartz wrote:
> Hi.
> recording.
> TIA,
> B.
>> Hi All,
>> later displays an ordinary Dialog that requests typed inputs from the
>> user.
>> into the ordinary Dialog. The problem is the I can't run the Test
>> after it is recorded. It generates the following:
>> Charlie
Re: AGR "thrashing" [message #107866 is a reply to message #107695] Wed, 08 August 2007 07:39 Go to previous messageGo to next message
Hi Charlie,
This could be caused by one of two reasons:
1) The Window Manager is confused about where the controller dialog was
during recording. It always will attempt to place the controller on top of
any new shells and it is giving it focus and then when the user tries to
select the dialog, losing focus and then trying to give focus back to the
controller, thus the 'thrashing' or flicker.
2) A SWT defect where the activate and deactivate events are not getting
fired correctly as we rely on these events to guide the process.
Please open an AGR defect
( https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting and
Test.Execution.AutoGUIRunner) to investigate this problem further. In the
meantime, I would suggest trying another AGR/SWT version to determine if
this problem is version specific.
Paul
news:f99s3n$qi2$1@build.eclipse.org...
> Hi Paul,
> Windows XP.
> Thanks
> Charlie
>> Hi Charlie,
>> Paul
>>> Hi All,
>>> IWorkbenchAction.
>>> Charlie
Re: AGR "thrashing" [message #108289 is a reply to message #107866] Fri, 10 August 2007 06:46 Go to previous messageGo to next message
Hi Paul.
I think your first reason is the most likely for myself, especially
since I see the problem typically when I change desktop in the middle of
a test (I have a number of virtual desktops and have to move between the
one in which I am doing the test and another in order to launch some
background activity that is needed for my test). The flickering occurs
when I return to the test desktop and a dialog is produced. I normally
click within the controller dialog, to give it focus without affecting
my test, and the flickering stops.
B.
> Hi Charlie,
> Paul
>> Hi Paul,
>> Windows XP.
>> Thanks
>> Charlie
>>> Hi Charlie,
>>> Paul
>>>> Hi All,
>>>> IWorkbenchAction.
>>>> Charlie
Re: AGR "thrashing" [message #108351 is a reply to message #108289] Fri, 10 August 2007 10:21 Go to previous messageGo to next message
Hi Paul and Barbara,
Please see my comments below.
Charlie
> Hi Paul.
> B.
>> Hi Charlie,
>> was during recording. It always will attempt to place the controller
>> on top of any new shells and it is giving it focus and then when the
>> user tries to select the dialog, losing focus and then trying to give
>> focus back to the controller, thus the 'thrashing' or flicker.
I launch an Eclipse application from the Run menu. This version of
Eclipse contains menu(s) that my code adds to the Eclipse menu bar.
When I select a menu item, the problem begins.
>> getting fired correctly as we rely on these events to guide the process.
>> and Test.Execution.AutoGUIRunner) to investigate this problem
>> further. In the meantime, I would suggest trying another AGR/SWT
>> version to determine if this problem is version specific.
I will file a defect.
>> Paul
>>> Hi Paul,
>>> Windows XP.
>>> Thanks
>>> Charlie
>>>> Hi Charlie,
>>>> Paul
>>>>> Hi All,
>>>>> IWorkbenchAction.
>>>>> the user.
>>>>> flashes until I press the Cancel button. (I think that it is
>>>>> flashing between the ProgressMonitorDialog ("progress bar") and the
>>>>> ordinary Dialog.
>>>>> causes a problem in the AGR.)
>>>>> Charlie
Re: AGR "thrashing" [message #108719 is a reply to message #108351] Mon, 13 August 2007 07:48 Go to previous message
Thanks Charlie.
news:f9hs9h$p1$1@build.eclipse.org...
> Charlie
>> Hi Paul.
>> I think your first reason is the most likely for myself, especially since
>> I see the problem typically when I change desktop in the middle of a test
>> (I have a number of virtual desktops and have to move between the one in
>> which I am doing the test and another in order to launch some background
>> activity that is needed for my test). The flickering occurs when I return
>> to the test desktop and a dialog is produced. I normally click within the
>> controller dialog, to give it focus without affecting my test, and the
>> flickering stops.
>> Thanks,
>> B.
>>> Hi Charlie,
>>> of any new shells and it is giving it focus and then when the user tries
>>> to select the dialog, losing focus and then trying to give focus back to
> Eclipse contains menu(s) that my code adds to the Eclipse menu bar. When I
>>> the meantime, I would suggest trying another AGR/SWT version to
>>> Paul
>>>> Hi Paul,
>>>> Windows XP.
>>>> Thanks
>>>> Charlie
>>>>> Hi Charlie,
>>>>> Paul
>>>>>> Hi All,
>>>>>> IWorkbenchAction.
>>>>>> user.
>>>>>> Charlie
Previous Topic:Process Memory size grows fast even when profiler is in the pause mode
Next Topic:Sending data from custom java agent
Current Time: Sat Jul 19 01:25:13 EDT 2025
Powered by FUDForum. Page generated in 0.06624 seconds
