Home » Eclipse Projects » Equinox » Relation between plugin activation and enabling/disabling Eclipse Feature
Relation between plugin activation and enabling/disabling Eclipse Feature [message #107944] Fri, 11 April 2008 02:30 Go to next message
Hi All,
What is the impact of enabling/disabling an Eclipse Feature version (through Help-->Software Updates-->Manage Configuration) on activation/deactivation/installation of plugins referenced by such a Feature?
e.g. Feature F1 version 1.0.0 references Plugin P1 version 1.0.0 and Feature F1 version 2.0.0 references Plugin P1 version 2.0.0. If F1 version 2.0.0 is disabled, F1 version 1.0.0 enabled, and a class from Plugin P1 is loaded, this class is loaded from P1 version 1.0.0.
How is it that plugin versions referenced by a Feature version that is disabled are not considered when plugin activation takes place?
Any pointers in understanding this would be most appreciated.
TIA,
Kind Regards,
-abhi
Re: Relation between plugin activation and enabling/disabling Eclipse Feature [message #108016 is a reply to message #107944] Sun, 13 April 2008 16:22 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
org.eclipse.update.configurator is listed in the config.ini as a startup
bundle. This bundle determines which bundles (aka plugins) contributed
by Update Manager (i.e via features, sites, extension directories etc)
should be passed to the runtime. Each feature contains an explicit list
of bundles. The features that are active are read and the list of the
bundles they contain passed to the runtime. Features which are inactive
do not have their bundles passed to the runtime.
So in the case you describe Feature 1.0 is active and therefore eclipse
knows about Plugin 1.0 and doesn't know about Plugin 2.0 so it loads
1.0. Plugin 2.0 was basically filtered out.
So while features don't define how the eclipse runtime loads bundles
they can define which bundles the eclipse runtime knows about.
P2 may change all this since it will replace update manager eventually.
-Peter
abhi wrote:
> Hi All,
> TIA,
> Kind Regards,
> -abhi
Re: Relation between plugin activation and enabling/disabling Eclipse [message #108349 is a reply to message #108016] Thu, 17 April 2008 10:06 Go to previous message
Hello Peter,
Thanks a lot for your input. In addition to clarifying the doubt, you have opened another avenue for me to explore (Eclipse P2).
Thanks a lot!
Best Regards,
-abhi
Previous Topic:NPE in my Servlet init kills http registry service...
Next Topic:P2 profile creation problem
Current Time: Fri Jul 25 08:40:26 EDT 2025
Powered by FUDForum. Page generated in 0.07068 seconds
