Home » Eclipse Projects » Eclipse Platform » commonj.sdo plugin is unsigned
commonj.sdo plugin is unsigned [message #1083359] Fri, 09 August 2013 17:24 Go to next message
The commonj.sdo plugin is unsigned. I filed a bug about this ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=404622 ) back in March, but haven't heard anything. Is this a problem? If not, why is the plugin unsigned, and can this explanation be added to the plugin, so people don't worry about it?
Re: commonj.sdo plugin is unsigned [message #1083546 is a reply to message #1083359] Sat, 10 August 2013 00:36 Go to previous messageGo to next message
Jesse,
It's probably better to try on the eclipse.rt.eclipselink forum.
Re: commonj.sdo plugin is unsigned [message #1085256 is a reply to message #1083546] Mon, 12 August 2013 13:03 Go to previous message
OK, I've done so here. Thanks for the suggestion!
Previous Topic:Search Dialog check the Selected Resource Option by default.
Next Topic:Problem: ESelectionService for master-detail-parts
Current Time: Tue Jul 22 00:13:47 EDT 2025
Powered by FUDForum. Page generated in 0.05598 seconds
