Home » Newcomers » Newcomers » confuse where to install(eclips juno for java developers)
confuse where to install [message #1083313] Fri, 09 August 2013 15:56 Go to next message
i have downloaded the jdk in the program files and extracted the eclipse file in my progam file (x86).i have windows 7 64 bit is it ok to install them in different folders or should i place the jdk in the program file(86) also .
thank you in advance
Re: confuse where to install [message #1083334 is a reply to message #1083313] Fri, 09 August 2013 16:35 Go to previous messageGo to next message
> file(86) also .
You can put them anywhere you like. All you need to do is ensure that
eclipse.ini references the JVM you've chosen.
How I do it...
I don't like to use the same JRE that my OS is using. So, I download my
own JDK (which apparently is what you've done). I set my installation up
like so:
C:\Users\russ\dev\jdk1.7.0_25
C:\Users\russ\dev\eclipse
In eclipse.ini, I insert the following line prior to the -vmargs option:
-vm
C:\Users\russ\dev\jdk1.7.0_25\bin\javaw.exe
Make sure the word-width of your Eclipse- and JDK downloads match, to
wit: both 64-bit or 32-bit, but not a mixture.
Hope this helps; best of luck.
Re: confuse where to install [message #1083335 is a reply to message #1083313] Fri, 09 August 2013 16:40 Go to previous messageGo to next message
oh and one more thing which one should i download . i need the eclipse juno but when i looked at the package it has sr1 and sr2
which one should i load.
thank you again
Re: confuse where to install [message #1083370 is a reply to message #1083335] Fri, 09 August 2013 17:31 Go to previous messageGo to next message
> juno but when i looked at the package it has sr1 and sr2 which one
> should i load.
> thank you again
SR2 would be later.
Re: confuse where to install [message #1084180 is a reply to message #1083370] Sun, 11 August 2013 01:05 Go to previous message
Kepler would be current.
Previous Topic:Eclipse: Kepler - Issue of JAXB Plugin
Next Topic:search and find
Current Time: Mon Jul 28 13:36:03 EDT 2025
Powered by FUDForum. Page generated in 0.09149 seconds
