Home » Language IDEs » ServerTools (WTP) » Programmatically Setting Environment Variables for TcServer(Programmatically Setting Environment Variables for TcServer)
Programmatically Setting Environment Variables for TcServer [message #1083280] Fri, 09 August 2013 14:50 Go to next message
I am writing a plugin to automatically setup TcServer (Tomcat) server instances in Eclipse. I have a requirement to add Environment variables programatically. It looks like the Environment variables are stored in launch files which I can edit through the DebugPlugin if they already exist. My problem is that the .launch files are not created until I double click on the server. Is there a way to programmatically do the same thing that the double click on the server does so I can generate that .launch file creation.
Any suggestions are appreciated.
Re: Programmatically Setting Environment Variables for TcServer [message #1085045 is a reply to message #1083280] Mon, 12 August 2013 07:29 Go to previous messageGo to next message
The code behind the Open Launch Configuration link on the server editor
page is able to programmatically create one if it doesn't already exist.
Larry
Re: Programmatically Setting Environment Variables for TcServer [message #1085942 is a reply to message #1085045] Tue, 13 August 2013 11:11 Go to previous messageGo to next message
Thanks Larry.
Do you know where I can find the code that opens the launch configuration page?
Re: Programmatically Setting Environment Variables for TcServer [message #1086600 is a reply to message #1085942] Wed, 14 August 2013 08:09 Go to previous messageGo to next message
On 8/13/2013 11:11 AM, Wendy Haley wrote:
> Thanks Larry.
> configuration page?
It's probably in the org.eclipse.wst.server.ui plug-in. You could try
searching for the string "Open launch configuration" and start following
the trail from there.
Larry
Re: Programmatically Setting Environment Variables for TcServer [message #1086751 is a reply to message #1086600] Wed, 14 August 2013 13:12 Go to previous message
I found the API I am looking for.
IServer.getLaunchConfiguration(true, null)
Thanks to everyone for suggestions.
[Updated on: Thu, 15 August 2013 08:40] by Moderator
Previous Topic:Weblogic Server Tool Installation
Next Topic:system_catalog.xml type errors
Current Time: Wed Jul 23 19:57:15 EDT 2025
Powered by FUDForum. Page generated in 0.04268 seconds
