[Teneo] How to order containment reference? [message #1083040] |
Fri, 09 August 2013 07:40  |
I am using Teneo with EMF and have an EClass, which has a containment EReference on another EClass.
Works fine so far, but the values in the containment aren't sorted. I activate the orderer property and checked the database. There is a column ending with idx.
If I select the rows ordered by that idx all is fine, but how can I achieve it with Teneo?
Thanks for any advice.
Re: [Teneo] How to order containment reference? [message #1083057 is a reply to message #1083040] |
Fri, 09 August 2013 08:03   |
Hi John,
Normally ereferences are sorted by this idx column. So I am not sure if the idx column you refer to is for that ereference.
You can check the generated hbm (see the datastore api) to check which idx column is being used by the containment
ereference.
gr. Martin
On 08/09/2013 01:40 PM, John M. wrote:
> Hello,
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.04460 seconds
