Home » Modeling » EMF » Extend a Model via ExtendedMetaData Interface
Extend a Model via ExtendedMetaData Interface [message #1083047] Fri, 09 August 2013 07:49 Go to next message
I have a little problem to merge two EMF models.
Situation:
I have two Models generated from a XSD Schema. "Model B" extends "Model A" via the ExtendendMetaData interface. I created the Object "Method" from "Model B" and would like to include it in the "addData" Object of "Model A".
Code snippes from the XSD "Model A":
<xsd:complexType name="addData">
	<xsd:annotation>
		<xsd:documentation>Application specific data defined in external schemata </xsd:documentation>
	</xsd:annotation>
	<xsd:sequence>
		<xsd:element name="data" minOccurs="0" maxOccurs="unbounded">
			<xsd:complexType>
				<xsd:sequence>
					[b]<xsd:any namespace="##any"[/b] processContents="lax"/>
				</xsd:sequence>
				<xsd:attribute name="name" type="xsd:anyURI" use="required">
					<xsd:annotation>
						<xsd:documentation>Uniquely identifies the additional data element.</xsd:documentation>
					</xsd:annotation>
				</xsd:attribute>
				<xsd:attribute name="handleUnknown" use="required">
					<xsd:annotation>
							<xsd:documentation>Recommended processor handling for unknown data elements.
Specifies if the processor should try to preserve the additional data element, dismiss the element (e.g. because the data is invalid if not updated correctly) or use the processors default behaviour for unknown data.</xsd:documentation>
						</xsd:annotation>
						<xsd:simpleType>
							<xsd:restriction base="xsd:NMTOKEN">
								<xsd:enumeration value="preserve"/>
								<xsd:enumeration value="discard"/>
								<xsd:enumeration value="implementation"/>
							</xsd:restriction>
						</xsd:simpleType>
					</xsd:attribute>
				</xsd:complexType>
			</xsd:element>
		</xsd:sequence>
	</xsd:complexType>
My Code looks like this:
// Create DataType1 Object from ModelA
DataType1 dataType = ModelAFactory.createDataType1();
dataType.setName("myLINK");
dataType.setHandleUnknown(HandleUnknownType.IMPLEMENTATION);
// Create MethodType Object from ModelB
MethodType methodType = ModelBFactory.createMethodType();
methodType.setName("Iam a method");
// Bring it together
ExtendedMetaData extendedMetaData = ExtendedMetaData.INSTANCE;
Entry entry = FeatureMapUtil.createEntry(extendedMetaData.demandFeature("", "", true), methodType);
dataType.getAny().add(entry);
// Save Model as XML
URI fileUri = URI.createFileURI(new File(fbGen.getOutputpath() + "//Test.xml").getPath());
Resource res = resourceSet.createResource(fileUri);
// Add UTF-8 encoding option
Map<String, Object> options = new HashMap<String, Object>();
options.put(XMLResource.OPTION_ENCODING, "UTF-8");
options.put(XMLResource.OPTION_DECLARE_XML, Boolean.TRUE);
options.put(XMLResource.OPTION_EXTENDED_META_DATA, metadata );
// Save the content
res.getContents().add(fbGen.getPlcOpen());
res.save(options);
The result is:
          <data handleUnknown="implementation" name="myLINK">
            <_1:Method name="Iam a method">
              <interface>
                <localVars>
                  <variable name="Name">
                    <type>
                      <sINT/>
                    </type>
                    <initialValue/>
                    <documentation>
                      <xhtml>Mycomment</xhtml>
                    </documentation>
                  </variable>
                </localVars>
              </interface>
            </_1:Method>
          </data>
But it should looks like this:
          <data name="myLINK" handleUnknown="implementation">
            <Method name="Iam a method">
              <interface>
                <localVars>
                    <type>
                      <sINT/>
                    </type>
                    <initialValue/>
                    <documentation>
                    </documentation>
                  </variable>
                </localVars>
              </interface>
            </Method>
          </data>
Why is the prefix "_1" set before the "Method"? What can I do to generate the XML file correctly?
Greetz
Re: Extend a Model via ExtendedMetaData Interface [message #1083196 is a reply to message #1083047] Fri, 09 August 2013 12:01 Go to previous messageGo to next message
Max,
Comments below.
On 09/08/2013 3:41 PM, Max Power wrote:
> Hello,
> Situation:
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> use="required">
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> Entry entry =
> true), methodType);
Hmmm. Why doesn't the feature have a name? I.e., shouldn't it be
extendedMetaData.demandFeature("", "Method", true)?
> // Save the content
> res.save(options);
> The result is:
> <interface>
> <localVars>
> <type>
> <sINT/>
> </type>
> <initialValue/>
> <documentation>
> </documentation>
> </variable>
> </localVars>
> </interface>
> </_1:Method>
> </data>
> <interface>
> <localVars>
> <type>
> <sINT/>
> </type>
> <initialValue/>
> <documentation>
> </documentation>
> </variable>
> </localVars>
> </interface>
> </Method>
> </data>
Is there an xmlns declaration from _1?
> Greetz
Re: Extend a Model via ExtendedMetaData Interface [message #1083242 is a reply to message #1083196] Fri, 09 August 2013 13:37 Go to previous messageGo to next message
I have tried everything, with a name, without a name, but it had not effect on the result.
There is no xmlns declaration. It looks like an automatically generated prefix.
I'm not a big EMF expert, but maybe it has something to do with the open/save options?
Re: Extend a Model via ExtendedMetaData Interface [message #1083281 is a reply to message #1083242] Fri, 09 August 2013 14:49 Go to previous messageGo to next message
Max,
That's very odd. If
http://www.theserverside.com/news/1364302/Binding-XML-to-Java doesn't
solve the problem (e.g., use null for the first argument rather than "",
and use "Method" for the second argument) can you zip up the projects
(or some other reproducible test case) and attach them so I can have a
closer look?
On 09/08/2013 7:37 PM, Max Power wrote:
> Quote:
> Quote:
> generated prefix.
> open/save options?
Re: Extend a Model via ExtendedMetaData Interface [message #1085165 is a reply to message #1083281] Mon, 12 August 2013 10:41 Go to previous messageGo to next message
Hi Ed,
your link doesn't solve the problem.
Maybe you can take a look on my code.
Re: Extend a Model via ExtendedMetaData Interface [message #1087388 is a reply to message #1085165] Thu, 15 August 2013 11:13 Go to previous messageGo to next message
Has nobody an idea or a tip how I can solve the problem?
Re: Extend a Model via ExtendedMetaData Interface [message #1087423 is a reply to message #1087388] Thu, 15 August 2013 12:05 Go to previous messageGo to next message
Max,
Can you share a test case that I can modify to make it work correctly
(or to track down any associated bugs)? If you can't attach via the
newsgroup, open a bugzilla and attach it there.
Re: Extend a Model via ExtendedMetaData Interface [message #1090587 is a reply to message #1087423] Tue, 20 August 2013 07:02 Go to previous messageGo to next message
the attachment from my previous post includes contains a test case. If you execute the main class in the PLCOpen package the file model.xml is automatically generated.
The final xml file looks like this:
<project xmlns="plcopen.org/xml/tc6_0201">
  <types>
    <pous>
      <pou name="Pou Name">
        <addData>
          <data handleUnknown="implementation" name="3s-software.com/plcopenxml/pouinheritance">
            <_1:Inheritance>
              <Extends>MyType</Extends>
            </_1:Inheritance>
          </data>
        </addData>
      </pou>
    </pous>
  </types>
</project>
The Problem is the "_1:" prefix.
This is the important code snippet:
         * Create content
	ProjectType projectType = factory.createProjectType();
	TypesType typesType = factory.createTypesType();
	PousType pousType = factory.createPousType();
	AddData addData = factory.createAddData();
	PouType1 pouType1 = factory.createPouType1();
	pouType1.setName("Pou Name");
	// Add model extension code
	DataType1 dataType = factory.createDataType1();
	dataType.setName("3s-software.com/plcopenxml/pouinheritance");
	InheritanceType inhertitanceType = codesysFactory.createInheritanceType();
	inhertitanceType.setExtends("MyType");
        // Here is the problem!!!
	Entry entry = FeatureMapUtil.createEntry(extendedMetaData.demandFeature(null, "", true), inhertitanceType);
	addData.getData().add(dataType);
	pouType1.setAddData(addData);
	pousType.getPou().add(pouType1);
	typesType.setPous(pousType);
	projectType.setTypes(typesType);
	documentRoot.setProject(projectType);
I hope it is now clear!
Re: Extend a Model via ExtendedMetaData Interface [message #1091529 is a reply to message #1090587] Wed, 21 August 2013 12:19 Go to previous messageGo to next message
Max,
I'm not seeing attachments in Thunderbird. Maybe I see them in the web
forum; I'll check tomorrow.
On 20/08/2013 1:02 PM, Max Power wrote:
> Hello,
> <types>
> <pous>
> <addData>
> <_1:Inheritance>
> </_1:Inheritance>
> </data>
> </addData>
> </pou>
> </pous>
> </types>
> </project>
> * Create content
> // Here is the problem!!! ExtendedMetaData extendedMetaData
> Entry entry =
Re: Extend a Model via ExtendedMetaData Interface [message #1105718 is a reply to message #1091529] Tue, 10 September 2013 03:40 Go to previous message
Max,
Sorry for taking so long to follow up...
The problem here is that "Inheritance" is an anonymous complex type, so
it's not possible to serialize an instance of such a thing using an
xsi:type because that requires a named type. The serializer recognizes
this situation and determines the name of the enclosing element for that
complex type and uses that instead. But that element isn't a global
element declaration which further confuses the situation.
I'm not sure what to suggest, but the thing you're trying to
achieve---serialize an instance of Inheritance (an anonymous type) under
a wildcard---isn't achievable/expressible with the schemas you've defined.
On 21/08/2013 6:19 PM, Ed Merks wrote:
> Max,
> web forum; I'll check tomorrow.
>> Hello,
>> <?xml version="1.0" encoding="UTF-8"?>
>> <types>
>> <pous>
>> <addData>
>> <_1:Inheritance>
>> </_1:Inheritance>
>> </data>
>> </addData>
>> </pou>
>> </pous>
>> </types>
>> </project>
>> * Create content
>> Entry entry =
Previous Topic:Parsing of ecore models
Next Topic:Differentiate between default value of the class and a loaded object
Current Time: Wed Jul 23 18:31:42 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
