Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP contributes invalid menu extension with 3.3
TPTP contributes invalid menu extension with 3.3 [message #106948] Tue, 31 July 2007 15:56 Go to next message
I just upgraded to Eclipse 3.3 and the new TPTP from Europa. Now every time
I use the context menu in the Package Explorer I get a series of errors
indicating TPTP is contributing an invalid menu extension:
From the log:
!ENTRY org.eclipse.ui 4 4 2007-07-31 14:23:39.201
!MESSAGE Plug-in 'org.eclipse.tptp.monitoring.instrumentation.ui'
contributed an invalid Menu Extension (Path:
'org.eclipse.jdt.ui.source.menu' is invalid):
org.eclipse.tptp.monitoring.instrumentation.ui.CbeExceptionA ddAction1
org.eclipse.tptp.monitoring.instrumentation.ui.CbeEntryExitD eleteAction
org.eclipse.tptp.monitoring.instrumentation.ui.CbeExceptionA ddAction2
org.eclipse.tptp.monitoring.instrumentation.ui.CbeEntryExitA ddAction
!MESSAGE Plug-in 'org.eclipse.tptp.trace.arm.ui' contributed an invalid Menu
Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid):
org.eclipse.tptp.trace.arm.ui.ArmRemovection
org.eclipse.tptp.trace.arm.ui.ArmAddAction
Sure hope there's an easy way to fix this.
-Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #106990 is a reply to message #106948] Wed, 01 August 2007 07:38 Go to previous messageGo to next message
Hi Kenneth,
This problem was resolved under defect
https://bugs.eclipse.org/bugs/show_bug.cgi?id=182734 and release in TPTP
4.4.0.1:
http://www.eclipse.org/tptp/home/downloads/
This release should be the current Europa release. When did you download
Europa? Can you confirm you are running TPTP 4.4.0.1?
Paul
"Kenneth Evans" <evans@aps.anl.gov> wrote in message
news:f8o46b$2pp$1@build.eclipse.org...
> time I use the context menu in the Package Explorer I get a series of
> errors indicating TPTP is contributing an invalid menu extension:
> From the log:
> Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid):
> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107077 is a reply to message #106990] Wed, 01 August 2007 13:02 Go to previous messageGo to next message
Paul,
I installed a clean Eclipse 3.3 yesterday, and got TPTP via the Europa
update site. The TPTP plug-ins include 4.4.0, 4.1.200, 4.2.0, and 4.4.90.
The problem is in Monitoring Implementation UI, which is in feature TPTP
Monitoring Tools Project (4.4.0).
To disable that requires also disabling TPTP Profiling for Web Applications
(4.4.0) and TPTP Tracing and Profiling Tools Project (4.3.100).
I just did a scan for updates on TPTP Monitoring Tools Project and got no
updates found from 3 different sites.
-Ken
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:f8prc5$oj5$1@build.eclipse.org...
> Hi Kenneth,
> 4.4.0.1:
> Paul
>> Hi,
>> From the log:
>> Thanks,
>> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107222 is a reply to message #107077] Thu, 02 August 2007 06:09 Go to previous messageGo to next message
Hi Ken,
Looks like you have the most recent updates. Please reopen 182734 with
your comments.
Paul
news:f8qebk$svk$1@build.eclipse.org...
> Paul,
> Applications (4.4.0) and TPTP Tracing and Profiling Tools Project
> (4.3.100).
> -Ken
>> Hi Kenneth,
>> 4.4.0.1:
>> Paul
>>> Hi,
>>> From the log:
>>> Thanks,
>>> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107587 is a reply to message #107222] Mon, 06 August 2007 02:27 Go to previous messageGo to next message
I installed Eclipse 3.3 SDK and then TPTP from Europa Discovery site using
"Search for new features to install". Then I did a "Search for updates of
the currently installed features" and found TPTP 4.4.0.1. I took the
default mirror that was selected for me. After installing the TPTP 4.4.0.1
update, the "invalid menu extension" error messages did not occur in the log
any more. The version of TPTP Monitoring Tools Project feature after
installing TPTP 4.4.0.1 is 4.4.0.v200706132116-7U7R_7-watmDA97KFbmUlBcq0yXH
and the version of the org.eclipse.tptp.monitoring.instrumentation.ui plugin
is 4.4.0.v200707070100.
Ken, are these the steps you followed and are these the versions you have
installed?
Dave
news:f8sahk$r4u$1@build.eclipse.org...
> Hi Ken,
with
> your comments.
> Paul
> > Paul,
4.4.90.
> > (4.3.100).
no
> > -Ken
> >> Hi Kenneth,
TPTP
> >> 4.4.0.1:
download
> >> Paul
> >>> Hi,
every
> >>> From the log:
invalid
invalid
> >>> Thanks,
> >>> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107600 is a reply to message #107222] Mon, 06 August 2007 19:34 Go to previous messageGo to next message
I have managed to get the update to the 4.4.0.1 version, and that fixes the
problem. The results are similar to those reported by Dave.
The only thing I did differently was to set Window | Preferences | Install /
Update to equivalent -> compatible. (I did this for another reason than
this problem.) After that I got the updates. Since the "equivalent"
setting should have given me 4.4.0.1 over 4.4.0.0 in the first place (one
would think), it is not clear if this result was from cause and effect or
something else.
Note:
1. I did not get the 4.4.0.1 version when I did the initial update through
Europa. It is hard to explain this.
2. It said there were no updates available on 3 different mirror sites
afterwards. Unless the mentioned setting change affected this result, this
is also hard to explain.
It seems as though the updates may not be current on several of the mirrors
is the only explanation I see (apart from a bug in the update mechanism,
entirely possible).
The updates certainly did not work as they should have. I repeat that this
was a newly installed, clean Eclipse 3.3 before the first Europa update when
I got TPTP the first time.
-Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107764 is a reply to message #107600] Tue, 07 August 2007 14:56 Go to previous messageGo to next message
Ken,
I did not change Install/Update preferences. The "Valid updates" option is
still set to "equivalent".
Regarding your notes 1 & 2, if I understand your scenario correctly, you
were trying to install the TPTP 4.4.0.1 update from the Europa update site.
I believe the behaviour you see is explained by the fact the TPTP 4.4.0.1
update is not available on the Europa or Eclipse update sites. It is
currently only available on the TPTP update site
(http://eclipse.org/tptp/updates/).
Dave
news:f98b6e$ak1$1@build.eclipse.org...
the
> something else.
> Note:
this
mirrors
> entirely possible).
this
when
> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #108236 is a reply to message #107764] Thu, 09 August 2007 13:58 Go to previous message
Seems like a less than optimal situation ;-)
-Ken
Previous Topic:[TPTP AGR] Path to Logger file in standard mode
Next Topic:Log view - Analyze selection: 90% CPU usage
Current Time: Sun Jul 27 15:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.24688 seconds
