Home » Archived » Eclipse Process Manager (Stardust) » Using Form(s) in a Portal View(How to use (multiple) forms in a portal view)
Using Form(s) in a Portal View [message #1082325] Thu, 08 August 2013 08:15 Go to next message
I need multiple forms in one view but the content of views is already loaded into a "ice:form", thus defining forms in the view leads to a faces exception ("Nested form found on the page").
Is there a way to overcome this problem?
The example view in the documentation Using the portal framework defines an "ice:form" tag. However, i got the same error with the given view-xhtml.
Simon
[Updated on: Thu, 08 August 2013 08:15] by Moderator
Re: Using Form(s) in a Portal View [message #1084886 is a reply to message #1082325] Mon, 12 August 2013 03:16 Go to previous message
Nesting of forms is not permitted, but one can add as many form as needed in a view, like:
<ice:outputHtml >
  <ice:outputHead>
  </ice:outputHead>
  <ice:outputBody>
    <ice:form id="#{EnterEmpDataBean.formId}">
    </ice:form>
    <ice:form id="myForm">
            </ice:form >
  </ice:outputBody>
</ice:outputHtml>
The code below will fail with:
javax.servlet.ServletException: java.lang.Exception: javax.faces.FacesException: Problem in renderResponse: Nested form found on the page. The form action element can not be nested
<ice:outputHtml >
  <ice:outputHead>
  </ice:outputHead>
  <ice:outputBody>
            </ice:form >
    </ice:form>
      </ice:outputBody>
</ice:outputHtml>
Previous Topic:Context initialization failed
Next Topic:Install trouble
Current Time: Fri Jul 25 04:55:42 EDT 2025
Powered by FUDForum. Page generated in 0.06952 seconds
