Home » Archived » EPF » Problem with character + in a link
Problem with character + in a link [message #1074336] Fri, 26 July 2013 10:28 Go to next message
If a have a link in EPF that contains character "+", when publish in html, the character "+" is changed in "%20". And of course the link will become broken.
Do you know how to solve this problem?
Thank you.
Re: Problem with character + in a link [message #1078132 is a reply to message #1074336] Fri, 02 August 2013 11:22 Go to previous messageGo to next message
This is unusual.
I have faced issues with many characters working in the EPF (rich) text editor. %20 in HTML depicts a blank space. Are you sure that it is + that comes up as %20 in HTML?
Re: Problem with character + in a link [message #1082295 is a reply to message #1078132] Thu, 08 August 2013 07:13 Go to previous messageGo to next message
yes. You can reproduced too.
Go to an element and try to add in the description an URL link.
in the URL just put ++.
Then preview the element and right click on the link and click properties and you will see that the ++ is transformed in %20%20.
Re: Problem with character + in a link [message #1082520 is a reply to message #1082295] Thu, 08 August 2013 13:36 Go to previous messageGo to next message
Hope this helps - http://www.blooberry.com/indexdot/html/topics/urlencoding.htm
Re: Problem with character + in a link [message #1121078 is a reply to message #1082520] Mon, 30 September 2013 04:43 Go to previous message
Thanks for your reply.
Is not working. I tried this before.
%2A is wworking "*"
%2B not working just put space
%2C is woring ","
Any suggestions ?
Previous Topic:amd64 version of epf-composer?
Next Topic:publish method configuration using CI build (hudson)
Current Time: Thu Nov 06 12:24:53 EST 2025
Powered by FUDForum. Page generated in 0.04024 seconds
