Home » Eclipse Projects » BPMN 2.0 Modeler » Setting associationDirection for Associations
Setting associationDirection for Associations [message #1081100] Tue, 06 August 2013 16:18 Go to next message
Hi Bob,
It seems that we've lost the ability to assign the associationDirection for associations on the latest release.
I used to set it in the property tab of an association (none, one or both).
Do you confirm? Or am I too tired to see it? Smile
[Updated on: Tue, 06 August 2013 16:18] by Moderator
Re: Setting associationDirection for Associations [message #1081117 is a reply to message #1081100] Tue, 06 August 2013 16:48 Go to previous messageGo to next message
Hmm, I'm not seeing that. What is the build number you are using?
Re: Setting associationDirection for Associations [message #1081672 is a reply to message #1081117] Wed, 07 August 2013 10:33 Go to previous messageGo to next message
I was using 0.2.6.201307252208. Just updated to 0.2.6.201308062246 with no luck. Still can't see where I can change the association direction. The association properties sheet has two tabs: "Description" and "Risk/Mitigation Association". On the first I got a documentation field and in the second got a checkbox "Affects task".
Re: Setting associationDirection for Associations [message #1081781 is a reply to message #1081672] Wed, 07 August 2013 13:38 Go to previous messageGo to next message
Ah, now I get it! You have your project configured for one of the sample Target Runtimes which does not allow configuration of the Association Direction Smile
Right-click on the workspace project, then select "Properties" and configure the BPMN2 Target Runtime for "None". That should do it.
Re: Setting associationDirection for Associations [message #1081786 is a reply to message #1081781] Wed, 07 August 2013 13:46 Go to previous messageGo to next message
Yep that did it. Thanks!
Still wondering tough how this changed by itself (I wasn't even aware of this setting). I used to be able to access this property and all of a sudden it disappeared (most probably after an upgrade).
Re: Setting associationDirection for Associations [message #1081792 is a reply to message #1081786] Wed, 07 August 2013 13:52 Go to previous messageGo to next message
Hmm, I'm pretty sure this didn't just change by itself Wink
Re: Setting associationDirection for Associations [message #1081796 is a reply to message #1081786] Wed, 07 August 2013 13:56 Go to previous messageGo to next message
I can't seem to find in the BPMN specs the section talking about target runtimes and the disallowing of specific unsupported elements. could you please point me to it if it is there? Or is it something you guys invented?
This is just for my information, I may end up needing it in my project.
Thanks!
Re: Setting associationDirection for Associations [message #1081817 is a reply to message #1081796] Wed, 07 August 2013 14:32 Go to previous messageGo to next message
A "Target Runtime" is meant to encapsulate model extensions and provide custom rendering (Property Sheets, graphical shapes, etc.) for a specific BPMN2 execution engine. The jBPM runtime is an example of this. There are also two examples provided in the source code, although these are purely fictitious and serve only as mules to demonstrate various features of the editor's extension API.
The original editor project's mandate was that it be able to handle "generic BPMN 2.0" (whatever THAT is Wink ) and that it be extensible and flexible enough (by way of plug-ins) to handle ANY BPMN 2.0 model subset and/or extensions. That's why we have this concept of a "Target Runtime".
HTH,
Bob
Re: Setting associationDirection for Associations [message #1081820 is a reply to message #1081817] Wed, 07 August 2013 14:40 Go to previous messageGo to next message
Ok very interesting, thanks a lot! I'll look further into this when time comes.
Re: Setting associationDirection for Associations [message #1081837 is a reply to message #1081820] Wed, 07 August 2013 15:09 Go to previous messageGo to next message
FYI: A plugin developer guide as well as a user guide are in the works - this should help.
[Updated on: Wed, 07 August 2013 15:09] by Moderator
Re: Setting associationDirection for Associations [message #1082392 is a reply to message #1081837] Thu, 08 August 2013 10:06 Go to previous message
Yes that will definitely help, great idea!! I am looking forward. Do you have an ETA?
If you need people to proof read and to test run the tutorials in the manual, you can count me in!
[Updated on: Thu, 08 August 2013 10:08] by Moderator
Previous Topic:Splitting a big process into smaller ones
Next Topic:BPMN2Editor refresh behaviour
Current Time: Fri Jul 25 06:55:44 EDT 2025
Powered by FUDForum. Page generated in 0.13505 seconds
