Home » Modeling » EMF » Deserialization issue if attribute value is higher than 8000 characters
Deserialization issue if attribute value is higher than 8000 characters [message #1081721] Wed, 07 August 2013 11:52 Go to next message
We are experiencing an issue while loading a resource that contains an object with an attribute whose value is a string longer than 8000 characters. Our resource:
<?xml version="1.1" encoding="UTF-8"?>
<astcache_wiki:Page initialContent="... a string longer than 8000 characters ..." lineDelimiter="&#xA;">
  <codeSyncElement href="Wiki.notation#//@children.0"/>
</astcache_wiki:Page>
Loading this resource, we get an exception:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri ':&#xA;&#xA;    ![alt text][id]&#xA;&#xA;    [id]: /pat' not found. (platform:/resource/test/WikiCache.notation, 2, 10249)
The uri is actually a substring of the initialContent from the resource.
Any pointers to why this is happening?
Thank you in advance!
Re: Deserialization issue if attribute value is higher than 8000 characters [message #1081737 is a reply to message #1081721] Wed, 07 August 2013 12:16 Go to previous message
Mariana,
Comments below.
On 07/08/2013 6:01 PM, Mariana Gheorghe wrote:
> Hello,
> ![alt text][id]
> 2, 10249)
This sounds like purely a bug in SAX itself.
It sounds a bit familiar, but as I say, it sounds like a SAX bug.
Perhaps a newer/different JDK will avoid the problem.
Previous Topic:Accessing References inside model element
Next Topic:determine containment of EObject
Current Time: Sun Jul 20 23:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.03216 seconds
