Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFStore(Using EMFStore as a data store ?)
EMFStore [message #1080566] Tue, 06 August 2013 01:20 Go to next message
We have an eclipse based application where the data has been modeled using EMF. I have tons of EMF models in my business logic and I want to save it some where so that I can load/search in future. The data is not very relational, but only contains references, containment, aggregations etc.Instead of saving them as plain XMI/XML, we want a better data storage mechanism (something like a DB?). Any thoughts/suggestions ?
I came across EMFStore and found it quite interesting for EMF Model serializing needs. Could someone help me to understand if EMFStore could be used as a data store alone and fits my specific use case ?
Thanks in advance for help.
-Murthy
Re: EMFStore [message #1080641 is a reply to message #1080566] Tue, 06 August 2013 03:47 Go to previous messageGo to next message
Murthy,
You should also have a look at Teneo and at CDO, both of which provide
support for persisting model instances in a DB. As far as I understand
it, EMFStore is more like CVS/SVN/Git in that it allows you to store
whatever file-based serialization you already have into a file-based
repository...
On 06/08/2013 7:20 AM, Murthy Bhat wrote:
> Hello,
> -Murthy
Re: EMFStore [message #1080728 is a reply to message #1080641] Tue, 06 August 2013 06:13 Go to previous messageGo to next message
Murthy,
@Ed: what you understood about EMFStore is wrong! ;-))
EMFStore is a model repository with the abstraction level being models
not files. It is intended to support multiple users changing one model
collaboratively including conflict detection and interactive merging.
The control flow for multiuser is indeed similar to CVS/SVN/GIT with
checkout, commit, update, etc. but everything based on models not on
files. For example a commit is sending a list of model changes to the
server.
It is certainly worthwhile to look at Teneo and CDO also, it all depends
on your requirements. Do not hesitate to contact me about your
requirements to find out if EMFStore is a match.
Maximilian
Am 06.08.2013 09:47, schrieb Ed Merks:
> Murthy,
> repository...
>> Hello,
>> -Murthy
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: EMFStore [message #1081306 is a reply to message #1080728] Wed, 07 August 2013 00:20 Go to previous messageGo to next message
Thank you Ed, Thank you Maximilian.
I am looking at Teneo and CDO right now and I would'nt mind giving EMFStore a shot as well. Below are my requirements.
We have a OSGi based web application(eclipse bundles running in Virgo) where we have EMF models on the server side. It is a collaborative environment where a model could be shared between two or more different sessions. Apart from the versioning/collaborative requirements, the basic requirement is to have a model(data) repository where we could run operations like Create, Read, Update, Delete, Search etc. Any thoughts/suggestions ?
-Murthy
Re: EMFStore [message #1081315 is a reply to message #1081306] Wed, 07 August 2013 00:35 Go to previous messageGo to next message
Hi Murthy,
Comments below...
Am 07.08.2013 06:20, schrieb Murthy Bhat:
I will give you some hints for CDO in the light of your requirements below.
CDO can be used with or without OSGi. With it the setup and configuration is a little easier.
I haven't tested CDO with Virgo.
With CDO your models can grow arbitrarily large on the server side because CDO clients support demand loading and
automatic memory management on the object granule.
CDO supports real-time collaboration.
CDO supports transparent temporality and branching.
> Delete,
CDO users seem to favour pessimistic object locking over conflict resolution. Both are possible, though.
> Search
CDO comes with a query framework that frees you from loading all objects onto the clients when searching for particular
objects. SQL and OCL are two of the supported query languages.
http://www.eclipse.org/cdo/documentation gives a functional and architectural overview of CDO. Please don't hesitate to
ask more questions (but please use the EMF newsgroup / forum).
Cheers
/Eike
http://www.esc-net.de
Re: EMFStore [message #1082059 is a reply to message #1081315] Wed, 07 August 2013 23:03 Go to previous message
Thank you Eike.
I will try out a simple example using CDO.
-Murthy
Previous Topic:Programmatically create *.ecorediag from *.ecore models
Next Topic:Using the EMF Client Platform
Current Time: Sat Jul 26 08:59:43 EDT 2025
Powered by FUDForum. Page generated in 0.03639 seconds
