[teneo] problem with composition link [message #108130] |
Thu, 24 January 2008 12:13  |
Originally posted by: frederic.ventura.eurogiciel.fr
Hi Martin and everybody
I'have a problem with an application I'm working on.
It uses GMF, teneo and hibernate
my application works well while doing association link.
but as soon as I use a composition link, a lots of problems arrived.
FIRST CASE : if I create for example a player inside a team, all goes well.
But if i try to drag and drop the player out of the team to cut the
composition link, no error is raised, my player seems to be out of the
team in my diagram, but when i see in database, my player don't exist
anymore, it has been deleted.
SECOND CASE : I create a team from one side.
I create a player for the other side without link.
I try then to drag and drop the player inside my team to create my
composition link.
When I save to commit in database, an error occured and session is closed.
here you can found my output to see trace .
I hope someone will see where is the problem to help me
1035725 [main] DEBUG org.eclipse.emf.teneo.resource.StoreResource -
Validating contents of resource
platform:/resource/test/db_test/teneo.ProtoTournoi approx. 0 will be
checked
1035725 [main] DEBUG org.eclipse.emf.teneo.resource.StoreResource - Found
0 errors
org.eclipse.emf.teneo.hibernate.resource.HibernateResource - Saving
resource with uri: platform:/resource/test/db_test/teneo.ProtoTournoi
1035725 [main] DEBUG org.hibernate.transaction.JDBCTransaction - begin
1035725 [main] DEBUG org.hibernate.jdbc.ConnectionManager - opening JDBC
connection
org.hibernate.connection.DriverManagerConnectionProvider - total
checked-out connections: 0
org.hibernate.connection.DriverManagerConnectionProvider - using pooled
JDBC connection, pool size: 0
1035725 [main] DEBUG org.hibernate.transaction.JDBCTransaction - current
autocommit status: false
1035725 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction
begin
1035741 [main] DEBUG org.hibernate.event.def.AbstractSaveEventListener -
persistent instance of: ProtoTournoi.impl.TournoiImpl
org.hibernate.event.def.DefaultSaveOrUpdateEventListener - ignoring
persistent instance
org.hibernate.event.def.DefaultSaveOrUpdateEventListener - object already
associated with session: [Tournoi#1]
1035741 [main] DEBUG org.hibernate.event.def.AbstractFlushingEventListener
- flushing session
- processing flush-time cascades
1035741 [main] DEBUG org.hibernate.engine.Cascade - processing cascade
ACTION_SAVE_UPDATE for: Tournoi
1035741 [main] DEBUG org.hibernate.engine.Cascade - cascade
ACTION_SAVE_UPDATE for collection: Tournoi.joueur
1035741 [main] DEBUG org.hibernate.engine.Cascade - done cascade
1035741 [main] DEBUG org.hibernate.engine.Cascade - deleting orphans for
1035741 [main] DEBUG org.hibernate.engine.Cascade - deleting orphaned
entity instance: Joueur
1035741 [main] DEBUG org.hibernate.event.def.DefaultDeleteEventListener -
deleting a persistent instance
deleting [Joueur#2]
1035741 [main] DEBUG org.hibernate.impl.SessionImpl - setting cache mode
to: GET
to: NORMAL
to: GET
to: NORMAL
1035741 [main] DEBUG org.hibernate.engine.Cascade - done deleting orphans
ACTION_SAVE_UPDATE for collection: Tournoi.equipe
1035741 [main] DEBUG org.hibernate.engine.CascadingAction - cascading to
saveOrUpdate: Equipe
persistent instance of: Equipe
persistent instance
associated with session: [Equipe#equipe]
ACTION_SAVE_UPDATE for collection: Tournoi.match
ACTION_SAVE_UPDATE for collection: Tournoi.championnat
ACTION_SAVE_UPDATE for collection: Tournoi.stade
ACTION_SAVE_UPDATE for collection: Tournoi.ville
ACTION_SAVE_UPDATE for collection: Tournoi.historique
saveOrUpdate: Historique
persistent instance of: Historique
persistent instance
associated with session: [Historique#3]
ACTION_SAVE_UPDATE for collection: Tournoi.participant
ACTION_SAVE_UPDATE for collection: Tournoi.participer
1035741 [main] DEBUG org.hibernate.engine.Cascade - done processing
cascade ACTION_SAVE_UPDATE for: Tournoi
ACTION_SAVE_UPDATE for: Equipe
ACTION_SAVE_UPDATE for collection: Equipe.fairePartie
saveOrUpdate: Joueur
deleted instance of: Joueur
org.hibernate.event.def.DefaultSaveOrUpdateEventListener - saving
transient instance
1035741 [main] DEBUG org.hibernate.impl.SessionImpl - flushing to force
deletion of re-saved object: [Joueur#2]
1035741 [main] ERROR org.eclipse.emf.teneo.hibernate.HbMapperException -
Exception when saving resource ProtoTournoi
org.hibernate.ObjectDeletedException: deleted object would be re-saved by
cascade (remove deleted object from associations): [Joueur#2]
at org.hibernate.impl.SessionImpl.forceFlush(SessionImpl.java:1 014)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:165)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:94)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:507)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :499)
at
org.hibernate.engine.CascadingAction$5.cascade(CascadingActi on.java:218)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:268)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :216)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:16 9)
at
org.hibernate.engine.Cascade.cascadeCollectionElements(Casca de.java:296)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java: 242)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :219)
at org.hibernate.engine.Cascade.cascade(Cascade.java:130)
at
org.hibernate.event.def.AbstractFlushingEventListener.cascad eOnFlush(AbstractFlushingEventListener.java:131)
at
org.hibernate.event.def.AbstractFlushingEventListener.prepar eEntityFlushes(AbstractFlushingEventListener.java:122)
at
org.hibernate.event.def.AbstractFlushingEventListener.flushE verythingToExecutions(AbstractFlushingEventListener.java:65)
at
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:26)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
at
org.eclipse.emf.teneo.hibernate.HbSessionWrapper.flush(HbSes sionWrapper.java:161)
at
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:346)
at
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:348)
at
ProtoTournoi.diagram.part.ProtoTournoiDocumentProvider.doSav eDocument(ProtoTournoiDocumentProvider.java:617)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider$1SaveOperation.execute(AbstractDoc umentProvider.java:596)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider$DocumentProviderOperation.run(Abst ractDocumentProvider.java:66)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.executeOperation(AbstractDocumentP rovider.java:530)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.saveDocument(AbstractDocumentProvi der.java:579)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.performSave(DiagramDocumentEditor.java:8 25)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSave(DiagramDocumentEditor.java:646)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:143)
at org.eclipse.ui.internal.SaveableHelper$4.run(SaveableHelper. java:266)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:274)
at
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:253)
at
org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:148)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1345)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:3202)
at
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:3215)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:73)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.commands.ActionHandler.execute(ActionHandl er.java:119)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:429)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:165)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:470)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:821)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:879)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:568)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:510)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:114 1)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:975)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:971)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1285)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3772)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3672 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:291)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
1035741 [main] DEBUG org.hibernate.transaction.JDBCTransaction - rollback
1035741 [main] DEBUG org.hibernate.transaction.JDBCTransaction - rolled
back JDBC Connection
1035741 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction
completion
1035741 [main] DEBUG org.hibernate.jdbc.ConnectionManager - aggressively
releasing JDBC connection
1035741 [main] DEBUG org.hibernate.jdbc.ConnectionManager - releasing
JDBC connection [ (open PreparedStatements: 0, globally: 0) (open
ResultSets: 0, globally: 0)]
org.hibernate.connection.DriverManagerConnectionProvider - returning
connection to pool, pool size: 1
1035741 [main] DEBUG org.hibernate.impl.SessionImpl - after transaction
completion
1035741 [main] DEBUG org.hibernate.impl.SessionImpl - closing session
1035741 [main] DEBUG org.hibernate.jdbc.ConnectionManager - connection
already null in cleanup : no action
Re: [teneo] problem with composition link [message #108147 is a reply to message #108130] |
Thu, 24 January 2008 13:21   |
Hi Fred,
Possibly the problem (and workaround) is described here:
http://www.elver.org/hibernate/hibernate_details.html#cutpas te
the solution proposes annotations in the model, I would advice to set annotations in a separate xml
file because then you have one location where you can manage them. This is also described on the
elver.org website.
My feel is that the second case is also covered by/related to the above solution.
gr. Martin
> SECOND CASE : I create a team from one side. I create a player for the
> composition link. When I save to commit in database, an error occured
> checked
> Found 0 errors 1035725 [main] DEBUG
> JDBC connection
> current autocommit status: false
> begin
> - persistent instance of: ProtoTournoi.impl.TournoiImpl
> persistent instance
> already associated with session: [Tournoi#1]
> org.hibernate.event.def.AbstractFlushingEventListener - flushing session
> org.hibernate.event.def.AbstractFlushingEventListener - processing
> flush-time cascades
> - deleting a persistent instance
> - deleting [Joueur#2]
> mode to: GET
> mode to: NORMAL
> mode to: GET
> mode to: NORMAL
> orphans for collection: Tournoi.joueur
> to saveOrUpdate: Equipe
> - persistent instance of: Equipe
> persistent instance
> already associated with session: [Equipe#equipe]
> orphans for collection: Tournoi.equipe
> orphans for collection: Tournoi.match
> orphans for collection: Tournoi.championnat
> orphans for collection: Tournoi.stade
> orphans for collection: Tournoi.ville
> to saveOrUpdate: Historique
> - persistent instance of: Historique
> persistent instance
> already associated with session: [Historique#3]
> orphans for collection: Tournoi.historique
> orphans for collection: Tournoi.participant
> orphans for collection: Tournoi.participer
> to saveOrUpdate: Joueur
> - deleted instance of: Joueur
> transient instance
> - Exception when saving resource ProtoTournoi
> by cascade (remove deleted object from associations): [Joueur#2]
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> completion
> aggressively releasing JDBC connection
> completion
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] problem with composition link [message #108278 is a reply to message #108266] |
Fri, 25 January 2008 11:06  |
See here:
http://www.elver.org/hibernate/ejb3_format.html#xml
gr. Martin
fred wrote:
> Ok I've done my xml file like this (it is called test.persistence.xml):
> <?xml version="1.0" encoding="ISO-8859-1"?><!DOCTYPE persistence-mapping
> PUBLIC "-//APACHE//DTD Documentation V1.3//EN" "document-v13.dtd">
> <persistence-mapping xmlns="http://www.eclipse.org/emft/teneo"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <!-- Template for ProtoTournoi persistence mapping. -->
> <epackage namespace-uri="ProtoTournoi">
> <eclass name="Team">
> <property name="players">
> <one-to-many>
> <cascade>MERGE</cascade>
> <cascade>PERSIST</cascade>
> <cascade>REFRESH</cascade>
> <cascade>REMOVE</cascade>
> </one-to-many>
> </property>
> </eclass>
> </epackage>
> </persistence-mapping>
> But I don't see what I have to do to take it into account?
The Netherlands
Re: [teneo] problem with composition link [message #614080 is a reply to message #108130] |
Hi Fred,
elver.org website.
gr. Martin
> checked
> JDBC connection
> begin
> persistent instance
> flush-time cascades
> mode to: GET
> mode to: NORMAL
> mode to: GET
> mode to: NORMAL
> persistent instance
> persistent instance
> transient instance
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> completion
> completion
The Netherlands
Re: [teneo] problem with composition link [message #614084 is a reply to message #108197] |
Fri, 25 January 2008 09:33  |
These settings can only be used if you programmatically generate the hbm file. You can do this using
the HbHelper instance (see the relevant static methods there):
http://www.elver.org/hibernate/hbdatastore.html#Getting+the+ Hibernate+Mapping+XML
Btw, Teneo also works fine if you don't generate a hbm file, it will generate an in-. My preferred
way of working is to not use a hbm file but do all the changes in a separate annotations xml file.
gr. Martin
fred wrote:
> Thank's for informations ;-)
> I'm watching to all this but I don't see where (in teneo tutorial) I can
> do modifications to take this into account:
> persistenceOptions.SET_CASCADE_ALL_ON_CONTAINMENT to false
The Netherlands
Re: [teneo] problem with composition link [message #614085 is a reply to message #108209] |
Fri, 25 January 2008 09:34  |
(re-posted to complete a sentence)
file. You can do this using the HbHelper instance (see the relevant
generate an in-memory mapping. My preferred way of working is to not use a hbm file
gr. Martin
>> can do modifications to take this into account:
The Netherlands
Re: [teneo] problem with composition link [message #614088 is a reply to message #108225] |
Fri, 25 January 2008 10:59  |
<one-to-many>
</one-to-many>
</property>
</eclass>
</epackage>
Re: [teneo] problem with composition link [message #614089 is a reply to message #108266] |
See here:
gr. Martin
> <one-to-many>
> </one-to-many>
> </property>
> </eclass>
> </epackage>
The Netherlands
FUDForum. Page generated in 0.05008 seconds
