Home » Eclipse Projects » Equinox » Exposing an API defined in a plugin to a normal non-OSGi based program
Exposing an API defined in a plugin to a normal non-OSGi based program [message #108124] Tue, 15 April 2008 03:41 Go to next message
I have an RCP application that defines some API classes through the
normal Eclipse plugin mechanism.
I would like also to expose some of these classes to a non-OSGi
application as part of the normal API for the product.
I have a factory class to create the root object from which everything
else is done (RuntimeFactory.createRuntime()). My thinking was that in
the case were Eclipse is running, the factory would just to do a normal
new RuntimeEngineImpl(), and in the case where it was not running to
start it using EclipseStarter.run(), and then return the application
object (which is the RuntimeEngineImpl()).
The difficulty is that the RuntimeEngineImpl object returned from the
Eclipse environment is of course different than the one expected by the
application, because even though the Jars are the same, the classloaders
are different.
So then, I tried removing the Eclipse plugin A entirely and setting the
various osgi class loader properties to refer to the "app" classloader
and thus get those classes in the plugin from the application's
classpath. This was looking very promising until the application
classloader tried to load a superclass of RuntimeEngineImpl from Eclipse
plugin B, which plugin B is defined normally using the Eclipse mechanism
(and is not in the app's classpath).
This is the point where I realized I need some help.
There must be an easy way to expose an API from an Eclipse app that I'm
missing here.
Got any ideas?
Francis
Re: Exposing an API defined in a plugin to a normal non-OSGi based program [message #108139 is a reply to message #108124] Tue, 15 April 2008 05:52 Go to previous message
> are different.
> missing here.
> Got any ideas?
> Francis
i think i had the same problem some days ago. Look at this thread
"ClassCastException when using BundleContext.getService()" from 07.
april 2008 05:09.
Its inside this mailinglist.
Gordian
Previous Topic:Dropins folder and installed features
Next Topic:Equinos OSGI Web-GUI
Current Time: Thu Jul 24 22:59:16 EDT 2025
Powered by FUDForum. Page generated in 0.06116 seconds
