Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » JUnit Test on JET Transform
JUnit Test on JET Transform [message #106726] |
Thu, 10 January 2008 19:18  |
I want to run a JUnit test on a JET2 template by running the transform,
but whenever I try to run the transform inside of my test i.e.
-JET2Platform.runTransformOnObject(...)
-Compare results with expected output
-assertTrue
The problem is that the transformation is not being run. I tried to run
it within a Job, but I still had no luck. Any ideas would be greatly
appreciated:
Job job = new Job("SD .NET Generation") {
protected IStatus run(final IProgressMonitor monitor) {
Map variablesMap = initializeInputs();
JET2Platform.runTransformOnObject("project.transform", null,
variablesMap, monitor);
return Status.OK_STATUS;
Re: JUnit Test on JET Transform [message #108115 is a reply to message #107841] |
Thu, 24 January 2008 11:30  |
Roshan:
I'm not an XMLUnit expert, but here's a suggestion on JUnit testing JET
transformation results...
1) Run the JET transformation using a TestSetup extension. See:
http://junit.sourceforge.net/javadoc/junit/extensions/TestSe tup.html
JET uses this technique in some if its JUnits:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/tests/org.eclipse.jet.tests/src/org/eclipse/jet /tests/parser/resources/ResourceTemplateInputTest.java?revis ion=1.1&root=Modeling_Project&view=markup
2) With a TestSetup, individual tests in the JUnit class can than verify
individual file contents. If you have XML content to verify, the XMLUnit
would be a handy tool.
3) For Unit testing your XPath expressions, one possibility is to create a
template (and a ws:file action) that writes calculated values, and then
write a JUnit test to verify these values. If you don't want this template
run in normal circumstances, you could run it only if a particular XPath
variable is defined, and define that variable when you run the JUnit test.
Paul
"Roshan Soni" <roshan.soni1@gmail.com> wrote in message
news:288c21f6c2cc29d097162f4a2fafe771$1@www.eclipse.org...
> You're right it was a problem with my launch configuration and when I
> properly setup my launch to run the correct plugin. I was orignally
> running the same transform as my project and so my unit tests were not
> running, but changing it to run the org.eclipse.sdk.ide product runs my
> transformation and test.
> Now I have a different question. On the basis of unit testing I want to
> test my xpath. what would you say is a good test for the xpath in the
> template snippet below? I was want to use XMLUnit to test because all of
> my output is xml.
> <c:when test="string($someControl/@attribute1) != 'true'">
> <c:setVariable select="$composite_widget/@attribute1" var="myParent" />
> </c:when>
> Roshan
Re: JUnit Test on JET Transform [message #613979 is a reply to message #106726] |
Thu, 10 January 2008 19:21  |
Roshan,
Please use the M2T newsgroup for JET2 questions. I've added it to the
"to" list of the reply so there's no need to repost.
Roshan Soni wrote:
> transform, but whenever I try to run the transform inside of my test i.e.
> -assertTrue
> run it within a Job, but I still had no luck. Any ideas would be
> greatly appreciated:
Re: JUnit Test on JET Transform [message #614041 is a reply to message #106849] |
Thu, 17 January 2008 18:06  |
Thanks Paul,
This is the type of test I want to run, but cannot get it to work. I have
a test class that runs this code as the test (I'll make it more robust
once I can get the transformation working in the test). When I run this
test I get the exception below. If I run my transform normally through my
launch file I do not receive any errors and I have output generated.
public void testTransform() throws Exception
IStatus status = JET2Platform.runTransformOnObject("com.tools.transform",
null, variablesMap, new NullProgressMonitor());
assertTrue("setUpAllTests", status.isOK());
try {
ResourcesPlugin.getWorkspace().run(new IWorkspaceRunnable() {
public void run(IProgressMonitor monitor) throws CoreException {
// TODO Auto-generated method stub
}}, new NullProgressMonitor());
} catch (CoreException e) {
fail(e.getMessage());
java.lang.ExceptionInInitializerError
at com.tools.test.AttachEventTest.testTransform(AttachEventTest .java:26)
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
at org.eclipse.jet.JET2Platform.<clinit>(JET2Platform.java:76)
... 19 more
Re: JUnit Test on JET Transform [message #614052 is a reply to message #107594] |
Mon, 21 January 2008 11:12  |
Roshan:
A quick look at the NPE suggests it happens if the JET plug-in has not been
started by Eclipse. How are you launching your JUnits?
You should be using an Eclipse launch configuration of type "JUnit Plug-in
Test".
Paul
news:7a10174e4db0877148ecce9616b7be55$1@www.eclipse.org...
> Thanks Paul,
> public void testTransform() throws Exception {
> try {
> at
> at
> at
> at
> at
> at
> ... 19 more
Re: JUnit Test on JET Transform [message #614059 is a reply to message #107742] |
Tue, 22 January 2008 14:28  |
my output is xml.
</c:when>
Roshan
Re: JUnit Test on JET Transform [message #614078 is a reply to message #107841] |
Roshan:
Paul
> my output is xml.
> </c:when>
> Roshan
Current Time: Sat Jul 19 00:44:26 EDT 2025
Powered by FUDForum. Page generated in 0.07247 seconds
