Home » Modeling » EMF » [Xcore] Using the same field name in subclasses
[Xcore] Using the same field name in subclasses [message #1080991] Tue, 06 August 2013 12:51 Go to next message
I have:
class TaskContext {
refers InputPort [] inputPorts opposite parent
refers EventPort[] eventPorts opposite eventParent
refers OutputPort [] outputPorts opposite parent
where:
class InputPort
String [1] name
refers DataType dataType
refers TaskContext parent opposite inputPorts
class EventPort extends InputPort {
refers TaskContext eventParent opposite eventPorts
class OutputPort
String [1] name
refers TaskContext parent opposite outputPorts
so...
I would like to have
class TaskContext {
refers EventPort[] eventPorts opposite parent
refers TaskContext parent opposite eventPorts
BUT the editor complains that I cannot 'There may not be two features
named parent'
-H
Re: [Xcore] Using the same field name in subclasses [message #1081004 is a reply to message #1080991] Tue, 06 August 2013 13:19 Go to previous messageGo to next message
Hugo,
Comments below.
On 06/08/2013 6:51 PM, Hugo A. Garcia wrote:
> Hi
> I have:
> class TaskContext {
> where:
> class InputPort
> String [1] name
> class OutputPort
> String [1] name
> so...
> class TaskContext {
> named parent'
No, you can't have that. An EventPort could be referenced by two
different TaskContexts, one via inputPorts and the other via
eventPorts. Opposites must be paired, and feature names must be unique...
> -H
Re: [Xcore] Using the same field name in subclasses [message #1081014 is a reply to message #1081004] Tue, 06 August 2013 13:35 Go to previous messageGo to next message
Comments at the bottom.
On 2013-08-06 19:19, Ed Merks wrote:
> Hugo,
> Comments below.
>> Hi
>> I have:
>> class TaskContext {
>> where:
>> class InputPort
>> String [1] name
>> class OutputPort
>> String [1] name
>> so...
>> class TaskContext {
>> named parent'
>> -H
ok... so I go a make a bidirectional refers in EventPort so that it can
use 'parent' from its super type InputPort?
-H
Re: [Xcore] Using the same field name in subclasses [message #1081028 is a reply to message #1081014] Tue, 06 August 2013 13:56 Go to previous message
Hugo,
Yes, the additional opposite feature you want to define in EventPort
must have a different name than "parent" which is used up by the super type.
>> Hugo,
>> Comments below.
>>> Hi
>>> I have:
>>> class TaskContext {
>>> where:
>>> class InputPort
>>> String [1] name
>>> class OutputPort
>>> String [1] name
>>> so...
>>> class TaskContext {
>>> named parent'
>> unique...
>>> -H
> can use 'parent' from its super type InputPort?
> -H
Previous Topic:EMF: Force load as a given type
Next Topic:EMF and XML: list serialization
Current Time: Mon Jul 21 02:46:58 EDT 2025
Powered by FUDForum. Page generated in 1.07453 seconds
