Home » Modeling » EMF » EMF and XML: list serialization
EMF and XML: list serialization [message #1080994] Tue, 06 August 2013 13:01 Go to next message
I notice this behavior when I try to persist an EList into XML file:
if ALL contents are in the same resource, I'll see something like:
<myClass myList="uuid1 uuid2" />
if one or more contents are from antoher resource, I'll see:
<myClass>
<myList href="#uuid1" />
<myList href="myprotocoluri/#uuid3" />
</myClass>
Is there an option to serialize lists always with node element and href?
Very thanks.
Re: EMF and XML: list serialization [message #1081007 is a reply to message #1080994] Tue, 06 August 2013 13:21 Go to previous messageGo to next message
Try
org.eclipse.emf.ecore.xmi.XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE.
> <myClass>
> </myClass>
> Very thanks.
Re: EMF and XML: list serialization [message #1081438 is a reply to message #1081007] Wed, 07 August 2013 04:21 Go to previous messageGo to next message
Thanks Ed Merks for fast reply.
I've tried to use that option but the result was this:
<myClass myList="#uuid1 #uuid2" />
Now I'm debugging XML serializer.
Re: EMF and XML: list serialization [message #1081447 is a reply to message #1081438] Wed, 07 August 2013 04:36 Go to previous messageGo to next message
Tommaso,
Yes, I would expect that. In general it will use QName/URI pairs (where
the QName is optional and is needed only if the feature's type is
abstract in which case it must specify the non-abstract type of the
proxy that will be created).
Re: EMF and XML: list serialization [message #1081484 is a reply to message #1081447] Wed, 07 August 2013 05:30 Go to previous messageGo to next message
Ed Merks wrote on Wed, 07 August 2013 10:36
Tommaso,
I expected something like this, so the only solution that I could find is override
saveFeatures() of XMLSaveImpl to exclude case "SAME_DOC".
Thanks Merks for your time, but do you never go on holiday? Smile
Re: EMF and XML: list serialization [message #1081518 is a reply to message #1081484] Wed, 07 August 2013 06:19 Go to previous message
Tommaso,
Comments below.
>> Tommaso,
>> (where the QName is optional and is needed only if the feature's type
>> is abstract in which case it must specify the non-abstract type of
>> the proxy that will be created).
> is override
You have to be careful with that... I'm not sure it's okay to call that
(without additional specialization) if there really are cross document
references...
> Thanks Merks for your time, but do you never go on holiday? :)
Not often enough without my computer. :-P
Previous Topic:[Xcore] Using the same field name in subclasses
Next Topic:Accessing References inside model element
Current Time: Fri Jul 25 23:00:59 EDT 2025
Powered by FUDForum. Page generated in 0.25613 seconds
